Difference between VN 5L and VS 5L Engines
8 replies to this topic
#1 gooley
gooley
  • 529 posts
  • Name:Jason
  • Car:Holden Torana LC 1970 Coupe
Posted 03 July 2008 - 07:41 PM
Just wondering whats the difference between these type of engines
i ask because my mate keeps saying to my other mate that his VS 5L engine is better than the VN 5L engine....i think he might be referring to more Kw etc...
i didnt think there would be much difference
#2 _lx-304_
_lx-304_
Posted 03 July 2008 - 08:01 PM
i didnt think there was a difference.my motor is out of a 94 model vq statesman and still only had 165kw then.what year is vs.if there was a difference it could only be 20kw any way.you could get nearly this with a good exhaust and take the fan off.i would by from 94 on as 89/90 is a little old.either way it will be a little power plant with any 5 litre in it.
#3 _lx-304_
_lx-304_
Posted 03 July 2008 - 08:04 PM
just did a search,different blocked heads,something about the manifold,anyway results in 17kw difference
#4 _UNVSM8_
_UNVSM8_
Posted 03 July 2008 - 08:35 PM
lesson i learnt is the distributor is different..
#5 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 03 July 2008 - 09:22 PM
VN were 165kw from the factory
VS series 2 introduced cold air induction giving an extra 3kw
Half way through the VR range the strker option on HSV was introduced, all blocks after that point were built to allow them to be stroked. Basically theres no difference in a stock VN to VS 304. VT however were 179kw from the factory standard and had a roller cam. They also had sequential injection, requiring a different distributer. They are a much smoother engine.
#6 _gtrtorana_
_gtrtorana_
Posted 03 July 2008 - 09:23 PM
I believe the series 3 VS ute and VT 5ltrs have a roller cam instead of flat tappet cam and you can fit a 355 crank in the later blocks without internal block relieving. I also heared the VN heads are better though but whether this is fact or fiction, I'm not sure.
#7 Dr Terry
Dr Terry
  • 3,326 posts
Posted 04 July 2008 - 10:45 AM
Hi Guys.
Yes, the 5.0 V8 from VN to VS was virtually unchanged except for the cold air intake added for VSII & III, as well as the reliefs in the block for VR onwards to allow for the stroker crank if needed.
As REDA9X has said, the VTI 5.0 had a different distributor for the sequential injection as well as a roller cam. These engines were also fitted to VSIII from Nov 1998 onwards. Note, not all VSIII had them, only Nov 1998 on.
Dr Terry.
#8 yel327
  • 13,698 posts
Posted 04 July 2008 - 03:28 PM
Just to add to Terry's and other comments, you'll pick the pre "stroker" introduction by the 5.0L casting on the side. Once the stroker was introduced (with rod reliefs) the casting boss is blank.
#9 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 05 July 2008 - 09:35 AM
Hi
I own a VN motor in my torana VR motor in my ute and have a VS as a spare and only things i have found different is oxygen sencer, dissy, computer, injecters and fuel rail.
Chears Neil
