LCGTR Opel box
_1971LCGTR_
Posted 06 July 2008 - 09:26 PM
Posted 06 July 2008 - 10:22 PM
I would leave the Opel and have it repaired if you have a genuine car.
"Cheers"
Alf
Posted 06 July 2008 - 10:31 PM
need M20 linkages
can use LC console but you need to remount slightly to rhs of current position
and you may need to grind a bit out underneath on lhs, there is a curved section below gearstick that may need to be enlarged
also clutchplate is different
Posted 07 July 2008 - 08:45 AM
To change from an Opel 4-speed to an Aussie 4-speed, you will need
Gearbox with linkages, bellhousing etc.
Clutch pate
Tailshaft & yoke
Crossmember
Speedo cable
The console is different but you can just move the original one, slightly.
By the way, it's only a small point, but an Opel is also an M20, so it's best to refer to the newer gearbox as an 'Aussie 4-speed'.
Dr Terry.
_threeblindmice_
Posted 07 July 2008 - 09:50 AM
Posted 07 July 2008 - 10:23 AM
_oz772_
Posted 07 July 2008 - 11:32 AM
_1971LCGTR_
Posted 07 July 2008 - 07:06 PM
_tuffgong_
Posted 08 July 2008 - 06:43 AM
cheers john
_LC870_
Posted 08 July 2008 - 08:30 AM
You must use a tailshaft out of a LC - LJ , factory automatic car or 3 speed car ( auto or manual ) .These tailshafts are all the same length as an aussie 4 speed one.
I hope this clears things up for you .
Regards LC870 .
_oz772_
Posted 08 July 2008 - 10:04 AM
Thanks. I thought that may have been the case.The Opel tailshaft is about 4 inches longer due to the Opel gearbox being much shorter than an Aussie 4 speed box , and therefore cannot be interchanged .
Regards LC870 .
