HP block ? 179 with 186 crank
24 replies to this topic
#1 _squirralien_
_squirralien_
Posted 20 July 2008 - 01:24 AM
Hi,, I am sorry if there are posts for this question but I have done a few searches and come up with nothing.
I have been offered a HP block which I believe is a 179, the engineer that is doing a friends machine work on his block said that if you put a 186 crank in the HP block then it will be a 186 ? so I take it from that the bore is the same and just the crank is different.
the block only has HP on it where it would normally have 179 or 186. the block is thought to be a standard bore which is going to be verified.
A very helpful forum member has offered his thoughts and information that he has heard around the place and I would like some feedback on the following, not for critisism but for varification or correction,,,
"179 and 186 cranks are same stroke but 179HP cranks are forged steel not cast steel...putting a 186 crank in a 179 is a step backwards.....BUT a 179 block was spose to be canadian cast or something thus allowing it to be bored further.....060 will give you around 186 i think and alegedly you can go 120 over would give you 202 with only a 3" stroke(202 is 3.25").....these 179 blocks are good for strokers as they say you can get close to 250 cubes out of a red......again all hearsay so do some searching on the forum first"
I really apreciate this info but just want to invite more information to verify or correct before I go getting the wrong engine, I really want a 186 but if the 179 is a 186 with a different crank and says HP not 179 ill settle for that but I don't want to just beleive what I have been told buy a guy that wants to sell the item, I was going o until I got the above info so its time to ask of the oh mighty forums knowledge base.
Also if someone can inform me or point me in the right direction to learn more about a stroker say for the HP block /186 ? or is it something that I would be best without for a street car.
Thanks again for the above offered information and any forthcoming info, I hate to ask so much but I am tackling a large build in my books and know little about the pro's and con's of the 186 and models around this motor, well basically mechanicals in general. I feel :fool:
#2 Zook
Zook
  • 1,536 posts
Posted 20 July 2008 - 08:51 AM
Try here for a stroker kit:
http://www.pro-stroke.com.au/
I think the basic kit is about $2000.
I'm putting a Ford 221 cranked 186 (about 235ci) into my LC and have the engine here in bits if you need photos of what needs to done machining-wise.
#3 _waratah_
_waratah_
Posted 20 July 2008 - 09:47 AM
try this for general info on building a holden 6
http://www.gmh-toran...showtopic=24737
#4 yel327
  • 13,739 posts
Posted 20 July 2008 - 09:57 AM
A HP cast block is just an early 179. All early Holden sixes (prior to mid 1967) has forged cranks, and they are all the same stroke including 186 - only the 202 has a bigger stroke. You can turn the 179 into a 186 by boring it 60 thou oversize. You would be better off with a 186 block if you want 186 cubes though. In fact if you want more cubes and torque (and power) use a 202.
There are lots of myths about the HP 179. Most of them are BS. It is just am early 179. Note that early 308 blocks also have HP on the side and it means nothing either. No early Holden sixes were cast in Canada.
#5 _revmaniac_
_revmaniac_
Posted 20 July 2008 - 10:36 AM
was ANYTHING ever cast in canada??? or is this one of those old tall tales we hear so often?
#6 yel327
  • 13,739 posts
Posted 20 July 2008 - 11:05 AM
Yes. Type 2 HK GTS327 engines, HK-HT 307 engines, plus most of HT and HG engines and all HQ 350 engines. No other Holden stuff that I know of. Not sure whether the centres of the 10 and 12 bolt diffs from HK-HG were USA or Canadian cast.
#7 _squirralien_
_squirralien_
Posted 20 July 2008 - 12:29 PM
I have seriously considered the 202 block but wanted to try and stay with the LC series motor for the XU-1, the hard thing is I want a block that is original or 20 thou over max,,, it appears that most are either 40 or 60 over, so I need to either keep looking or except 40 over or 202,
sounds like the HP (179) isn't for me, pitty it was a good deal I thought.
Im off to read through the links offered above.
Thanks for the feedback
IF I was to go the way of the 202 block, which is the best 202 to go for, red, blue or black, I have heard the black was a troublesome beast ? is there a red or is it orange or is red orange or orange red ?
Is the lc XU-1 motor original painted orange or red, red like red not an orange red ?
Edited by squirralien, 20 July 2008 - 12:33 PM.
#8 _gstar_
_gstar_
Posted 20 July 2008 - 01:24 PM
lc xu1 engine is rocket red not orange - red
black and blue had superior heads and delivered the most HP, also had starfire rods and counterweighted cranks.
your best bet is to use blue/black crank and rods and making sure everything from clutch to pressure plate to flywheel to the balancer is perfectly balanced with whatever block you so desire to use.
#9 yel327
  • 13,739 posts
Posted 20 July 2008 - 05:57 PM
Agree with gstar. Use a blue/black crank and rods all balanced in a rope seal red 202 block with head to suit the carbies. That is triple webers/dellortos use 12 port head off black EFI of Yella terra 12 port, or other carbs use modified red head.
Squirrelalien, if you want a standard bore 186P block, call Greg on 02 49598999. I'm sure there is a few in his yard, one in a blue HK Kingswood wagon that i'm pretty sure is standard bore. There's also a really good HK Kingswood sedan that may also be original bore. These engines will probably have to go 30 or 40 thou as you'll have trouble finding smaller pistons for a 186 nowadays plus after 40 years the bores wil probably be worn past 20 thou. One other possibility is to use a blue/black 202 crank and rods as above with the mains turned down to suit the 186, and then you should be able to get smaller pistons. This is really silly though as it would be heaps cheaper to use a 202 block unless you really want to keep a 186 in it.
#10 _squirralien_
_squirralien_
Posted 21 July 2008 - 11:49 AM
I will give him a call today, I think someone else gave me his number but I was trying to avoid the frieght issue, the company I use because they are cheaper always lays a duck egg if I can't tell them the weight. and who knows the weight of a block, not many.
I am running out of options and getting sick of taking heads off to find they are 40 or 60 over, I know its to be expected and its what I have to do if I want to find one but I don't have to enjoy it. and im not, Im wanting to stick with 186 to keep it in with what the LC XU-1 had originally.
#11 _squirralien_
_squirralien_
Posted 21 July 2008 - 11:54 AM
he is closed today I will try tomorrow
#12 _threeblindmice_
_threeblindmice_
Posted 21 July 2008 - 12:58 PM
Is the crank weight, much different in the blue and black compared to the red,and does this effect the performance?
#13 warrenm
warrenm
  • 2,126 posts
  • Car:1972 LJ Torana
Posted 22 July 2008 - 09:01 AM
Red crank= 19 or 20 kg
Blue/Black=27kg
The red crank will spin up quicker due to less rotating mass but the blue/black will be smoother due to the counter weights.
Warren
#14 _squirralien_
_squirralien_
Posted 22 July 2008 - 10:32 AM
what has to be done to get a blue or black crank in to a red 186.
#15 yel327
  • 13,739 posts
Posted 22 July 2008 - 10:44 AM
Grind the mains down to 186 size (or possibly align bore the block to suit bigger bearings), and if the 186 is a neoprene rear main (which I think they all are) grind the seal journal down to the neoprene size (blue/black are rope seal). Then make sure the camshaft you use is for a 202 (all new cams should be) with the scallops to clear the rod bolts.
#16 _threeblindmice_
_threeblindmice_
Posted 22 July 2008 - 10:47 AM
squirralien have you driven a good worked 186 in a Torana ?
#17 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 22 July 2008 - 12:11 PM
All Chevs in early holdens were Canadian.
The one "myth" that I will always stand by is the quality of the iron in the HP blocks over the lower grade metal in the later blocks. The HP is less likely to "chuck" and is more resilient. This is the reason you use em for strokers.
Before anyone says it was the crank you needed, they were steel in ALL early reds.......
Does someone want to drill a few blocks and collect the shavings for metalurgical analysis?
Grant..
#18 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 22 July 2008 - 12:25 PM
hmm. I might use my HP as a basis for the blown motor for the LJ...
Tim
#19 nzxu1
nzxu1
  • 276 posts
Posted 22 July 2008 - 01:04 PM
l have a brand new 186 short engine and head from 1966 vintage if you're interested though l live in New Zealand . l've never looked but l dare say it has a steel crank in it too .
#20 _squirralien_
_squirralien_
Posted 22 July 2008 - 01:56 PM
Thanks yel327,
threeblindmice,, no I haven't even heard one running apart from youtube and thats crap for engine audio and unfortunately I don't know anyone near me with one.
nzxu1 I have sent you a PM
#21 yel327
  • 13,739 posts
Posted 22 July 2008 - 03:39 PM
Grant..
There's another myth - ie "All Chevs in early Holdens were Canadian". Type 1 HK GTS 327 engines (short water pump) were cast in Tonnawanda, New York hence the T prefix to the North American part of the engine number. The first type 350 manual engines in HT were also Tonnawanda cast but I can't remember exactly which (if any) HG 350 manual engines were US sourced. All 307's, type 2 327, HT and HG 350 auto plus some of the manual HT/G engines and all HQ 350 were Canadian. The large journal 327's fitted to CKD Impalas etc were also Tonnawanda even past release of type 2 327 in HK, but prior to HK I think they were all Canadian cast - my '57 Chev blue flame is Canadian too. Holden complianced C20/K20/C30 trucks had Flint, Michigan cast engines from memory.
I think you'll find that all early Holden 6 cyl blocks prior to mid HR were cast in the same foundry and from the same cast iron. So while the HP may be different material to say a HK-HG 186, it won't be any different to any other 179 from a HD or late EH. I wonder if Holden had cast FRED or something like that into the side if people would have invented so much stuff about HP 179 and 308 blocks? Dr Terry knows a lot more on this subject than me so he might add more or correct any mistakes if he reads this post.
Edited by yel327, 22 July 2008 - 03:48 PM.
#22 piquet
piquet
  • 857 posts
Posted 22 July 2008 - 04:44 PM
I am as far as i am aware the only person racing a n LC XU1 in Historic touring cars So I ahve to use a 186.
Seems to get along OK . Does 1min 58 at phillip island and 1.28's at Sandown.
Just off the tail of the 202 XU1's.
The 186 lacks a bit in top end but spuns up a bit sfaster that the 202. All out Hp there is not a lot in it.
Roller cam Holden 6's engies in Historics are getting over 300HP (normally aspirated) and flat tappet engines just under 300, mine had about 275 at the flywheel so it wasn't too far off the pace HP wise.
just dont go too wild with the camshaft and not too big on the ports for the head and they go really well
Dont want to give too much away on the open web.
#23 _4.2SLRLVJ_
_4.2SLRLVJ_
Posted 22 July 2008 - 06:24 PM
I have a HP engine block in my shed. It ihas the head but I am not sure of the condition. I am sure it is a complete engine. It has been there for ages. PM me if anyone is interested.
#24 _threeblindmice_
_threeblindmice_
Posted 23 July 2008 - 12:39 PM
Piquet ,what carbies are you running ? As you probably guessed I'm a 186 fan .
#25 piquet
piquet
  • 857 posts
Posted 24 July 2008 - 04:53 PM
3 x 45 mm webers with HM9C extractors and a 2.5" side exit exhaust
The head is the answer get that right and they fly\cheers
piquet
