Headlight Fuse Blowing
Posted 03 August 2008 - 04:16 PM
I've got a problem with my LX I am building as the headlight fuse blows every time I put the park lights on. I've unplugged the headlights and taillights as well as the park light plug underneath the bonnet. I've checked the parker wire for cuts on the insulation to see if it's shorting out on the body and the wire seems fine. I've also tried two switches to see if the switch is the problem but to know avail. Does anybody have any suggestions to what the problem is. The car is not currently running so it is a little difficult to get to an auto elecs who could probably fix the problem in about 5 minutes.
#2 _UNVSM8_
Posted 03 August 2008 - 04:35 PM
Ben
Posted 03 August 2008 - 04:38 PM
#4 _luv the uc_
Posted 03 August 2008 - 05:53 PM
Posted 04 August 2008 - 12:39 PM
Posted 04 August 2008 - 06:20 PM
The quicker the fuse blows, the closer the short is to the fuse.
#7 _torbirdie_
Posted 04 August 2008 - 06:48 PM
I dont think there is any logical reason for that to be true, but willing to be enlightened.Tip:
Actually, a bit puzzled here, obviously you have a fuse blowing, but the headlights are not protected by a fuse , unless you count the main fuseable link or have modified the wiring so there is one.
The parkers are on a fuse, but the headlamps should still work if this fuse goes, if they dont it means that somehow you have wired it up with the output of the parker fuse going to the headlight terminal.
If the headlamps still go, it means your method of connecting the wiring is possibly okay and there is just a short in the park light circuit somewhere.
Removing all the globes is a good start.
Id look at firstly disconnecting the park lights wires from the switch while keeping the fused supply connected. If it blows when you having those disconnected, then the problem is the switch or how you have it wired.
Failing that, you have to look for shorts in each wire to each lamp to suss out
Edited by torbirdie, 04 August 2008 - 06:49 PM.
Posted 04 August 2008 - 06:53 PM
Posted 04 August 2008 - 06:56 PM
Tip:
The longer the wire is to the short, the longer the fuse takes to heat up and pop.
#10 _SS Hatchback_
Posted 04 August 2008 - 07:17 PM
Other than if there is more than one wire coming from the dead side of the fuse then you may have to disconnect one of them at a time until it doesnt blow anymore leaving you with the wire that you mayhave to trace and find the short.
Posted 04 August 2008 - 07:54 PM
#12 _torbirdie_
Posted 05 August 2008 - 10:42 AM
I suppose so, due to a longer run of wire that the resistance will be higher and therefore the short circuit current will be slightly less, though with normal wire the difference would be probably measured in microseconds.
#13 _SS Hatchback_
Posted 05 August 2008 - 08:45 PM
Posted 05 August 2008 - 08:59 PM
It's visable if you watch the fuse as you fit it.
You sound like you might be a sparkie? Surely you have noticed?
#15 _SS Hatchback_
Posted 06 August 2008 - 06:26 PM
Posted 06 August 2008 - 08:51 PM
#17 _Chris M_
Posted 06 August 2008 - 09:44 PM
Kind of on topic, it's about impedance as well as resistance. Inductive impedance (which is like resistance to AC) goes up with length(same as resistance). Difference is, inductive impedance also goes up with frequency. The instant where the fuse is put in (or a switch turns on) is equivalent to a really high frequency, so that's why length has more of an effect than you might think. Now back to the bourbon for me...
Posted 07 August 2008 - 11:03 AM
Peter, I'm betting your problem is either a trailer plug connection, or the remains of the carnage caused when someone has hooked one up previously, or my first choice would be an aftermarket CD radio which has night illumination fitted, and someone has squashed the wiring for the night illumination against the metal of the dash when they've fitted the radio.
As for lengths of wire and proximity to fuses being a clue, it's not really. The fuse itself is a clue. If the fusible link inside the fuse is splattered all over the inside of the glass of the fuse and the glass is grey/white or silver (or cracked), then you can bet it's a pretty big short, especially if its happening with large rated fuses. If the centre of the fusible link inside the fuse is simply broken or a small section is melted and missing, it's more like a short somewhere near (but over) the rating of the fuse. A fuse that blows quickly and violently is just an indication of how bad the short is, not where it may be. It's amazing how much current can flow through even very small diameter wires and bits of corroded plugs or globe holders.
To save on fuses, especially if it's a big short, I'd suggest the following. Put all your wiring back together, and connect a 12 volt light bulb (eg a small dash light or indicator bulb - no larger) between the two contacts of the fuse (don't put a fuse in). Because you obviously have a short somewhere between the fuse output and the earth of the car, the light globe will glow until the short is removed. Wire the globe in, see it light up (presuming you still have the short), and remove connections and looms, globes, etc one by one until the globe goes out. The last thing you moved/removed will most likely be the culprit. The beauty of using a small 12 volt globe is that it's easy to see when it's lit, and also it limits the short circuit current to a safe level which should not harm any of the wiring no matter how long it takes you to trace the short.
Good luck. Let us know how you go.
#19 _torbirdie_
Posted 07 August 2008 - 11:50 AM
Chris, certainly inductance is a factor if we have coils of wire, but im thinking that is not the case...Kind of on topic, it's about impedance as well as resistance. Inductive impedance (which is like resistance to AC) goes up with length(same as resistance). Difference is, inductive impedance also goes up with frequency. The instant where the fuse is put in (or a switch turns on) is equivalent to a really high frequency, so that's why length has more of an effect than you might think. Now back to the bourbon for me...
If we put identical fuses at opposite ends of a large length of wire and short out one end, then the current that flows through each fuse will be the same(according to Kirchoff's law), and there is no reason why the fuse further away would take longer to blow than the one closest to the short.
edit:(as dangerous has said ^ its more the nature of the short that will depend on how long it takes, and this can be seen by the remains of what is in the glass holder)
Edited by torbirdie, 07 August 2008 - 11:55 AM.
Posted 07 August 2008 - 06:53 PM
#21 _SS Hatchback_
Posted 07 August 2008 - 09:00 PM
From what he was saying before , i dont think he has any wires connected to the headlights at all so it wont really help him much.I've had this problem before, as I said earlier try insulating the bodies of the headlights from the body of the car, some tape will do it. If this stops it from blowing the fuse you have an earthing problem. You say you are building the car, have you done paint work recently? Have a good look at your earths, but try the insulation first as it's a quick easy test.
#22 _Brewster_
Posted 07 August 2008 - 09:18 PM
Edited by Brewster, 07 August 2008 - 09:19 PM.
#23 _Chris M_
Torbirdie, even straight wire has some inductance. I agree about Kirchoffs current law, but it's the length of wire in the path to ground that we're looking at; it doesn't really matter where in that wire the fuse is positioned. Just putting a reason behind Rodomo's statement. I can do some calcs for you if you really want. PM me if you want more details or I'm if not being clear (or I'm babbling).
Either way, Danegerous has a great, simple idea with the light globe. I'm thinking he is the one with the practical solutions ( not me)
#24 _torbirdie_
Posted 07 August 2008 - 09:43 PM
I dont think the rest of the forum needs to hear more about ^ , so have sent a pm.Torbirdie, even straight wire has some inductance. I agree about Kirchoffs current law, but it's the length of wire in the path to ground that we're looking at; it doesn't really matter where in that wire the fuse is positioned. Just putting a reason behind Rodomo's statement. I can do some calcs for you if you really want. PM me if you want more details or I'm if not being clear (or I'm babbling).
You are right, dangerous has some ideas/solutions: light bulb is good, maybe even a 12V buzzer, so that it can be heard/not heard when poking around giggling the wires in the boot etc.
Edited by torbirdie, 07 August 2008 - 09:55 PM.
#25
Posted 07 August 2008 - 10:00 PM
The park lights are in the headlights, he says it blows a fuse as soon as he turns the park lights on. If however they are disconnected and still blowing a fuse when he turns them on, then in that case it won't help. It's got to be something simple, all the theorys and laws are really going a bit far for this. BTW, welcome back DEVILSADVOCATE AKA TORBIRDIE.
