How much for a bore and hone?
14 replies to this topic
#1 Com_VC
Com_VC
  • 411 posts
Posted 17 August 2008 - 11:14 AM
Hi,
Was just wondering what the going rate is for a bore and hone. I've got a standard bore 202 that i'm looking at taking out to 30 or 40 thou so I can fit some new pistons. Also is a torque plate bore and hone a must?
I'm in Melbourne, south east suburbs around Dandenong, Frankston and Cranbourne area so if anyone can recommend somewhere around there that would be good.
#2 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 22 August 2008 - 05:13 PM
depends on what power you are searching for if your goign big then torque plate is the way to go
not sure of any engine builders down that way
cavehill engines in lilydale do it i think
and speed works in ringwood probably do
#3 MRLXSS
  • 12,416 posts
Posted 22 August 2008 - 05:20 PM
A hone (or maybe it was a bore) when i inquired a few years back, was about $80 a cylinder i think. Prices would have gone up in that time i reckon...
Ring around a few places and see. Warby engines in Cranny do a good job.
#4 rodomo
  • 18,053 posts
Posted 23 August 2008 - 12:01 AM
I saw Stu tonight. $242 for a V8.
(03) 97395878
#5 _gstar_
_gstar_
Posted 23 August 2008 - 12:02 AM
i paid that for a 202!
#6 rodomo
  • 18,053 posts
Posted 23 August 2008 - 12:04 AM
Mods, can we have an emoticon that says "snigger"? :huh:
#7 Com_VC
Com_VC
  • 411 posts
Posted 23 August 2008 - 09:59 AM
rodomo is that with a torque plate?
#8 mr5000
mr5000
  • 3,455 posts
  • Car:77 lx 4door
Posted 23 August 2008 - 10:08 AM
haha i like stu hes helped me out a few times whne i was going through rocker arms like they were going out of fashion
if your short on cash but probably better off going to ian at lilydale engines but make sure you hassle him and need it asap other wise it will get lost in the bermuda triangle hes got there i heard from a mates boss he lost a ford 250 crank in there once hahaha
Edited by staind91, 23 August 2008 - 10:12 AM.
#9 rodomo
  • 18,053 posts
Posted 23 August 2008 - 08:02 PM
I might be wrong but isn't a torque plate something you buy and bolt on?
This price wouldn't include that.
#10 rodomo
  • 18,053 posts
Posted 23 August 2008 - 08:04 PM
Ian has my respect too as an engine builder but I don't know how he finds anything in there.
Unless things have changed in 20 yrs? :huh:
#11 _gtr161_
_gtr161_
Posted 23 August 2008 - 09:11 PM
Just picked up my 2600s from the engine builers....$2000
basically it got the works
chem clean & check
block decked
bore and hone 161 + 0.60"
flat top pistons n rings
close n hone rods
fit pistons to rods
complete balance
r & r cam bearings
r & r welsh plugs
r & r cam & crank gears
machine flyheel
new harmonic
new crow cam hyd 32/78
new lifters
new clutch kit
main bearings
complete gasket kit
head to follow...I'll either do the port valve job on the original head ($1100) or reco a yella terra 161 head i have (cost $550 + serv $300)
Edited by gtr161, 23 August 2008 - 09:21 PM.
#12 Com_VC
Com_VC
  • 411 posts
Posted 24 August 2008 - 09:25 AM
It�s a thick plate that bolts to the deck and it gets torqued up to head bolt specs so that there is no distortion whilst boring + honing. It keeps the cylinder walls straight.
#13 rodomo
  • 18,053 posts
Posted 24 August 2008 - 10:23 AM
I was thinking of one of these jiggers:
http://cgi.ebay.com....1QQcmdZViewItem
Call Stu on (03) 97395878 b.h.
#14 _moot_
_moot_
Posted 24 August 2008 - 10:45 AM
some times a 40-60thou over bore might be dearer as they have to bore the block twice.you cant rip a virgin bore motor out to 60thou in one hit. so its best to ask your machine shop
#15 TerrA LX
Posted 24 August 2008 - 11:15 AM
Not quite right, the torque plate is for the bolts to distort the bore so when you hone it the finish replicates the head clamped in place.
