VR/VS Starter motor
_MAWLER_
Posted 24 February 2006 - 02:17 PM
I'm looking at buying VR/VS starter motor for my 308 and was just wanting to know a little bit more about them before I stepped out and bought one.
Are they are straight bolt and wire up fit?
How do they relate in size and configuration to normal starter - ie, placement of solenoid, overall size, etc.
I have heard the term reduction geared - does this refer to all VR/VS starter motors or only certain ones?
What does reduction geared mean anyway?
Are they a BOSCH unit?
Is anyone using one, and how have they found them to be.
Thanks in advance for all the help,
Cheers,
Liam.
_J&S Racing_
Posted 24 February 2006 - 08:19 PM
#1 they are a bolt in fit but need 2 long bolts not 1 long and 1 short like std, they do wire up the same.
#2 they are smaller in size and the solonoid is closer to the block.
#3 not sure about the reduction gear ones, but i have what they call a hi torque.
#4 mine is a Bosch and i think they all are.
#5 i run a 10.1+ comp and it's not to bad at starting it up, it's a bit harder once engine is at running temp. otherwise trouble free.
I hope this helps.
_Jewboy_
Posted 24 February 2006 - 11:21 PM
_J&S Racing_
Posted 25 February 2006 - 10:37 AM
_MAWLER_
Posted 27 February 2006 - 11:59 AM
So I have to make sure I get a V8 one so it will bolt straight up without having to fiddle like you have Jewboy.
Actually, now that you mention it J&S, I've heard em referred to as Hi Torque gear reduction starters so they must all be the same sort of thing. I suppose you just have to scrounge up another long bolt from somewhere, they don't come with them in the box I'm guessing.
Cheers,
_TORANASS_
Posted 27 February 2006 - 01:06 PM
1 question: are auto and manual vs v8 starters the same?
John
_J&S Racing_
Posted 27 February 2006 - 04:16 PM
The starter motor for manual and Auto should be the same.
_Jewboy_
Posted 27 February 2006 - 08:49 PM
_MAWLER_
Posted 28 February 2006 - 07:42 AM
Peaec,
_J&S Racing_
Posted 28 February 2006 - 06:09 PM
_Jewboy_
Posted 28 February 2006 - 08:56 PM
_MAWLER_
Posted 01 March 2006 - 08:08 AM
_J&S Racing_
Posted 01 March 2006 - 03:33 PM
_2wild4u_
Posted 01 March 2006 - 10:24 PM
_MAWLER_
Posted 02 March 2006 - 09:33 AM
So looks like I'm going to need to get a gear reduction starter then and I would prefer to buy a new one than have an old one rebuilt. I would also prefer to get a stock item like off the VS rather than an aftermarket type from Super Plus which is from who knows where.
That is awesome news 2wild4u, and the part no. is a great help too cos I know a bloke... Can you give a bit of info on your heat shield, because I was planning to use some of that heat proof stuff that looks like it was off a NASA ship because I'm sure heat soak is a problem.
Cheers,
_2wild4u_
Posted 04 March 2006 - 10:15 AM
_MAWLER_
Posted 05 March 2006 - 02:32 PM
Thanks for that.
Liam.
Posted 28 August 2017 - 06:37 PM
This is an awesome replacement for the stock starter, including bolts it is 3.7 kg versus 7.4 kg - nice weight save.
Downside is that according to Covs the bolts aren't supplied by GMH anymore and RSP don't stock them - they are getting hard to find.
Bosch product details here:
https://au.bosch-aut.../starter-bxh136
Starter BXH136
Product No. F 042 200 057
Code : BXH136
Replaces
GMC (GENERAL MOTORS CORP.) 92047110
HOLDEN 92047110
HOLDEN BXH126
HOLDEN F005M00012
HSV (HOLDEN SPECIAL VEHICLES) F005M00012
Posted 02 September 2017 - 06:41 PM
The BXH 136 can be found quite cheaply new. I got mine off eBay. Started list price $197. Seller discount 10%. eBay voucher discount 20%. Free postage and hey presto it's $142 delivered to my door.
You do need new bolts. I was hopeful that two long bolts for the old style starter would be ok but no go. They are significantly different.
I did the wrecker ring around without much luck. Bought Holdents last pair of new ones for $40.
The bolts are apparently available at Bursons etc.
There is a big size difference and the solenoid is on top rather than the side. Keeps it further away from the pipes.
The solenoid position change may or may not cause some small issues. If you still have factory wiring it's probably no issue. I use an Alfa Romeo body length cable for my boot mounted battery. The cable has an angled end so needed some re routing to keep it off the pipes. No biggie. Also had to redo my earth cable from the starter mounting bolt to chassis (was on the short bolt).
Did have an issue though.
After I finished I went to start the car and ..... nothing. No click, no crank. Checked I hadn't left the solenoid wire off, checked the battery was reconnected and ...... nothing. Fark!
Got serious and got the test light out. Maybe with wrestling the wiring I had broken or dislodged something? Power to the starter? Check. Power to the solenoid on cranking? Check. Try to start again and nothing. Bugger, dead starter new out of the box. Can't believe my bad luck.
In frustration and hope I try a couple more times and leave it keyed on for a few loooong seconds and it suddenly comes to life. Starts uneventfully next few times including a hot start.
It cranks hard and the car fires straight away. Much improved. Well worth the $182 and hour of my time.
Posted 02 September 2017 - 10:38 PM
Couldn't get bloody bolt though. None at Holden , repco or bursons up here
Ended up buying some arp ones from summit
#21
Posted 06 September 2017 - 04:13 PM
Great information guys. Noted the appropriate info for when I get around to it. Cheers Ron
#22
Posted 24 October 2017 - 10:48 PM
The replacement turned up pretty quickly and has been fine.
#23
Posted 25 October 2017 - 11:13 AM
Unusual for Bosch. Just to confirm about the bolts, are the two that you had to buy the same as any V8 Commodore that uses the small starter?
Edited by Shiney005, 25 October 2017 - 11:14 AM.
