New Fuel Sender
_76S.L.R_
Posted 06 September 2008 - 09:04 PM
Posted 07 September 2008 - 08:37 PM
I purchased a fuel sender from rares and have had no probs.
If you want to check your gauge in your dash you can try the resistor method.
It has been done before if you use the search tool I am sure you will find it.
The very basic outline is this.Pick up some resistors from your local electronics joint...will only cost you a couple of bucks.From memory they were
10 ohm 33 ohm 75 ohm.. ( I think 1 watt)??
Disconnect the sender wire from your tank and connect one end of the resistor to the wire and earth the other end of the resistor to your cars bodywork.
With the ignition in the on position the following should happen.
when done with the 10 ohm the gauge should read full.
when done with the 33 ohm the gauge should read approx half
when done with the 75 ohm the gauge should read empty.
Hope this helps..
Obey 1
_76S.L.R_
Posted 07 September 2008 - 09:16 PM
I'll go buy some tomorrow and give it a go.............Gday 76SLR..
Hope this helps..
Obey 1
_LH SLR 3300_
Posted 17 September 2008 - 06:36 PM
Posted 17 September 2008 - 08:35 PM
_LH SLR 3300_
Posted 20 September 2008 - 08:35 PM
