Changing to Commodore stud pattern
_AquaSLR5000_
Posted 19 November 2005 - 11:47 PM
_CHOPPER_
Posted 20 November 2005 - 01:22 PM
#2 Commodore discs will bolt straight on the front. The calipers won't. Hoppers kits are $1100 for the front. As for the rear, a Commodore diff would be the cheapest way to adapt. VK - VL BW diff has a rear track of 1440 MM, A9X rear track is 1443.2 MM. The other rear option is a 9" conversion.
Posted 20 November 2005 - 03:00 PM
Don't care to much as i think i might just put them on the rear anyway until i get new axels. I was going to posibly go the hopper's front kit and change to commo pattern as it dosn't cost anymore...
If they are legal what do you think of them any way?? are they safe??
Oh also if i do get them any idea what would be the best thickness to place the wheel in the best spot to fit the biggest rubber on the rear, std guards only lipped?
Got 245's on 15' volvo now the car is lowered but not super low.
_AquaSLR5000_
Posted 20 November 2005 - 09:26 PM
_CHOPPER_
Practical example:
If the rims on the car ATM are UC SLE alloys ( 13x6" with +25 offset ) and you want 17x8" rims with +43 offset AND you want the inside edge of the rim to sit EXACTLY where the inside edge of the UC SLE rims sit, then you would need 43.5 MM spacers.
_CHOPPER_
Posted 20 November 2005 - 09:27 PM
Hoppers Stoppers, in Hoppers Crossing, Melbourne. Kits start at $1100 for the front ONLY.Hoppers Kits???????, who, what,
where.
Posted 21 November 2005 - 06:05 PM
Is there much if any differance in later model BMW / Commodore offset and stud patter??
Just checking but if i go commodore because of the offset difference compared to torana these wheels won't illigally increase my track(if i get the wheel in the same position using the right size spacer)?
thanks chop
_CHOPPER_
Posted 25 November 2005 - 06:44 PM
BMW rims ranged from +22 to +47. Stud pattern is the same, however the centre bore is around 74 MM, compared to 69.5 MM for the Commodore. Ideally, you would use a rim with the same centre bore as the hub. It won't matter with most older vehicles, but does matter on all Nissans built after 1990 and BMW's.
To increase the track by one inch by using +43 Commodore rims on the Torry ( compared to using 13x5.5" stock rims ), you would need to use 33 MM spacers. What fits under the guards depends on tyre width and how low/high the car sits.
_Jewboy_
Posted 25 November 2005 - 07:52 PM
Posted 26 November 2005 - 02:05 PM
_CHOPPER_
Posted 26 November 2005 - 07:48 PM
Posted 27 November 2005 - 09:08 AM
_CHOPPER_
Posted 27 November 2005 - 12:19 PM
_ToranaGuy_
Posted 29 November 2005 - 12:07 AM
Should also work out cheaper than the Vn diff i was thinking about. No cutting of axels and so on, just R & R suspension mountings and fit to torry.
CHOPPER, that's really cool info. Here i was worried about if i go a hoppers kit i didn't have many options to get the same bolt patter on the rear! I'm going to have to ring around and price the mods to a Vk - Vl diff.
ToranaGuy
Posted 04 December 2005 - 07:34 AM
if only i didnt buy a house at that time
oh well.
_Cane_It_
Posted 10 December 2005 - 09:08 PM
_CHOPPER_
Posted 11 December 2005 - 12:27 PM
_Bruce Burnout_
Posted 27 December 2005 - 01:22 AM
_CHOPPER_
Posted 27 December 2005 - 08:19 AM
