Ball Joints
_Lhover_
Posted 29 October 2008 - 11:43 AM
I have just pushed my new ball joints into my lower control arms.One was an extremely tight fit and the other was an easy fit, too loose for my liking.Has anyone here ever put small tack welds on the bottom outside edge of their ball joints to control arms ?.I imagine this would be okay if I don't get too much heat into the joint.I have never smashed a ball joint open so I don't know whats inside but I figure it would just be all steel ball and socket.They are new and haven't been greased yet.
Any thoughts.
Cheers Chuck.
Posted 29 October 2008 - 11:57 AM
_Lhover_
Posted 29 October 2008 - 01:03 PM
Posted 29 October 2008 - 01:46 PM
Posted 30 October 2008 - 06:45 PM
Posted 30 October 2008 - 11:06 PM
Posted 03 November 2008 - 02:10 PM
Aslong as you are decent with the welder, and dont need ten goes to get it tacked in properly, there wont be much heat transfer and it will be fine.
_1QUICK LJ_
Posted 21 November 2008 - 11:39 PM
i think you are a little confused between balljoints and suspension bushes. lol. its fine to tack in balljoints.balljoints are either rubber or eurathene inserted wat do u think will happen when u put the heat from a tack into it???if u think its not that much heat it is ive seen em seize because of this,u have to get ur wishbone balljoints resleeved not that expensive better then having it seized doin 100 on the highway.i know alot of ppl will say that wont happen had mine tacked for yrs thats wat my mate said until it seized on him and he couldnt steer.
_lx-304_
Posted 22 November 2008 - 08:14 AM
dave
Posted 22 November 2008 - 09:42 AM
i am a bit confused about the rubber insert comment,but tacking the balljoint is a good idea and could probably save your life as the original ones wrer riveted in and you dont want the bolts on the new one coming loose.the only thing you could possibly worry about is the boot,but as stated if you can weld then there is that much transfer.even if you pay someone $20 to do it,it could be the best money you spend.
dave
If installing new upper ball joints, they are usually supplied with bolts and nuts for fitment in lieu of rivets. No need to tack weld the upper ball joints. If you're worried about the nuts coming loose, use an appropriate type of Loctite.
Lower ball joints are a press fit and it may be beneficial to tac weld. Or best option would be to replace the arm in question.
_azureblueslr_
Posted 22 November 2008 - 11:53 AM
do not tack it heat transfer will be an issue
the ball joints are also held in place with spring pressure and will not drop out
just do it properly and replace the lower control arm with a good one
_lx-304_
Posted 22 November 2008 - 01:29 PM
dave
_azureblueslr_
Posted 22 November 2008 - 01:57 PM
ive built a fair few cars in my time and have always replaced the balljoints as part of the deal
if you torque the nuts up properly on the new balljoints and use the supplied spring washers + locktight you will never have a problem
i think the stories that go around about the nuts coming loose and the ball joint coming out are either just wives tales or the nuts were fitted by someone who did not know what they were doing and should not have been changing the ball joints in the first place
Posted 22 November 2008 - 06:13 PM
_Lhover_
Posted 28 November 2008 - 12:45 PM
Cheers Chuck.
Posted 28 November 2008 - 02:33 PM
