^ If done correctly alot less things should go wrong with HEI compared to points. Otherwise why would it be such a good upgrade.
Well it depends on your application:
There appears to be a lot of problems with some sorting out their power supplies, which is just a once only thing.
Electronic ignition is basically zero maintenance, but that doesnt equate to 100% reliablity. Two components, the reluctor coil and the module can fail basically at any given time, and there is no easy roadside fix.
Points sytems need adjustment every 5000km and possibly will fail beyond 10000km. But once set, they are right to go and wont be the source of any random break downs in the between times.
Also I've heard that you should run a 30A cable to the coil, so you need a 30A rated relay/wire/fuse.
You heard wrong. 15A wire will be fine, current draw is ~7A. Its not going to hurt to use 30A wire though and any relay should be up to the task.
