This is something that needs to be sorted out asap..
Basically the R33 5 speed gearbox has an electronic drive.
I have 2 options..
First is to wire it up to the VL electronic speedo that I have grafted into the UC dash...Head ache.
Second is to convert to a mechanical speedo drive and use the UC speedo with a custom cable. To do this I believe I need to use a VL turbo 5 speed drive unit. It's the MX7 pinion assembly part number is 32702-02G17. I called nissan and they said it would be about $50.
There's one one ebay for $180 buy it now. Either this guy is a tosser or it's the wrong part from nissan.
I'll keep searching as I need a working speedo for the engineer to do a brake test in a few weeks...
R33 speedo drive question
_studricho_
, Nov 13 2008 09:33 AM
5 replies to this topic
_studricho_
Posted 13 November 2008 - 09:33 AM
Posted 13 November 2008 - 09:39 AM
Does your engine management computer require speed input?
_studricho_
Posted 13 November 2008 - 11:56 AM
No, only if it's an auto set up which my car has the manual.
_UNVSM8_
Posted 13 November 2008 - 12:07 PM
i'd wire up ur the VL speedo as it will probably be more accurate..
_studricho_
Posted 13 November 2008 - 02:35 PM
I was thinking that myself this arvo...
_studricho_
Posted 18 November 2008 - 10:34 PM
Well I've decide to get the speedo drive unit from nissan. Came in today and it's the whole unit for $49. I'll see if it fits tomorrow. I also have a modified speedo cable coming..I'll keep you guys posted.
