LH SL/R5000 Fine or Coarse spline axles?
#1 _Big T_
Posted 08 December 2008 - 11:52 AM
Did the LH SL/R5000 (L31) come with fine or coarse spline axles? Diff code is GU7 (Banjo).
I have searched but cant seem to find an answer.
Cheers,
T
Posted 08 December 2008 - 12:39 PM
Posted 08 December 2008 - 12:48 PM
#4 _Yella SLuR_
Posted 08 December 2008 - 07:21 PM
Posted 08 December 2008 - 09:56 PM
Tim
#6 _azureblueslr_
Posted 09 December 2008 - 09:41 AM
l34 option came with fine spline
my lh slr has the original centre and its course
check your parts books and they will tell you
#7 _The Baron_
Posted 09 December 2008 - 10:22 AM
My guess would be
LH=coarse for all except L34.
LX=coarse for 6's and fine for V8
UC= fine for all?
Probably rolling changes not defined by models.
Posted 09 December 2008 - 10:46 AM
LH/LX V8 LSD Fine Spline
LH V8 Non LSD Coarse Spline
LX V8 Non LSD Coarse Spline until introduction of RTS early 1977
LX 6 cylinder was the same all coarse until RTS then all fine
LX 4 cylinder had the fine spline with the intro of Sunbird ake RTS around Aug 1976.
Production dates on components may appear before these dates.
Perhaps the early 1974 SLR 5000's had coarse LSD but have never seen this.
Posted 09 December 2008 - 09:23 PM
#10 _azureblueslr_
Posted 10 December 2008 - 09:46 AM
the lh slr 5000 l31 only came with a course spline lsd
they did not come with fine spline lsd
big t . the proper dif for your car is a 278 lsd course spline
it is the same code as my lh slr 5000 gu7 in lh slr5000 = 278 lsd cdourse spline
Posted 10 December 2008 - 07:12 PM
#12 _azureblueslr_
Posted 10 December 2008 - 08:53 PM
the lh slr 5000 l31 only came with course spline lsd not fine splineThe parts catalogues say different. The LH and LX list the same part numbers for the 5L gears, and there is no different part number for the L34 either in the supplement of the revised catalogue. It lists the 253 banjo as being coarse spline though, so my statement about the only V8 LSD coarse spline being in HK-HG was wrong as 253 Toranas had them too.
i have one in my garage and it has the original centre which is course spline 278 lsd
ive done a lot of research on this matter and to be blunt anyone that says the lh slr5000 came with a fine spline is wacking thier wanger
Edited by azureblueslr, 10 December 2008 - 09:02 PM.
Posted 10 December 2008 - 09:07 PM
Posted 11 December 2008 - 06:20 AM
#15 _azureblueslr_
Posted 11 December 2008 - 07:56 AM
my car is a 6-74. the main ratio for the lh slr5000 is 2.78 gu7 which would be why the parts book only lists that ratio
you could however get the gu4 option but i have never seen an lh slr5000 with this
i have been told that the later l34,s had fine spline though so maybe this is were the confusion starts ,they may have changed from course to fine on the l34 in the later models
also note that you could get a dealer ordered l34 motor fitted to your l31 lh slr5000 which is not in any parts books as far as io know but also adds to the confusion with these cars and the discrepencies between what the parts books say and what some of the cars have fitted
it also gets a bit funny with these cars becouse if you had the money and connections you could pretty much get your car built with any combination of mechanicals /accesories you wanted ,eg l34 motors/flairs/console or no and diff ratio,s etc
#16 _azureblueslr_
Posted 11 December 2008 - 08:01 AM
this further complicates things ,ford was a master of this
Posted 11 December 2008 - 08:26 AM
Posted 11 December 2008 - 10:03 AM
Early LH catalogue shows only 2 x sets of sun gears: LSD and not LSD. this would indicate all diffs were coarse spline.
Later LH catalogue lists coarse spline, coarse spline LSD and fine spline LSD, with the fine spline LSD for 5L only.
L34 supplement only lists what is unique to L34, and the only axle components listed are the diff housing and the axles themselves.
This all would indicate that at release all 5 litre optioned SLR's were coarse spline. However by the time L34 was released 5 litre cars had fine spline centres. I must admit I was surprised by the early 5L cars having coarse spline diffs (especially since fine splines were introduced during LJ). I suppose on reflection it's not too big a stretch to see Holden doing it though, as all the barge ass HT-HG Broughams were coarse spline banjos and these were the same 308 as the LH plus the HK Broughams were an even torquier 307 with the same diff. The coarse spline banjo was also standard or optional fitment on plenty of other HK-HG 307 and 308 Monaros, Premiers etc.
The reason I put faith in the L34 publication is I think it was used for homologation and had to be right, otherwise the L34 would have been racing with coarse spline axles. I talked to Dr Terry about this and he said if the early 5L cars had coarse spline axles then there must have been an update bulletin when the axles switched to fine spline (as he is adamant every 5L LH he has worked on were fine spline). He is going to have a look and see if he can find a copy of such a bulletin.
#19 _darrenmark1_
Posted 19 December 2008 - 07:18 PM
#20 _Rob 5000_
Posted 19 December 2008 - 07:25 PM
#21 _Yella SLuR_
Posted 03 January 2009 - 09:32 PM
#22
Posted 03 January 2009 - 09:51 PM
Interesting topic nevertheless.
#23 _PRO-192_
Posted 06 January 2009 - 06:21 PM
micko
#24 _Big T_
Posted 13 January 2009 - 01:07 PM
Damn, Big T opened this can of worms and ran it seems...
hehehe, something like that. A bloke called me thru the QTCC to find out the answer. I scribbled his number down on a piece of paper and some one has thrown it out so Im waiting for him to call me back.
I think I will just advise him to rip out an axle and check it himself....... Not that a I doubt any of the knowledge here, it just seems that there is no definative answer.
#25
Posted 07 January 2015 - 04:41 PM
Holy thread resurrection batman!!
What do people make of this extract from the LH parts manual. This manual is dated September 1975.
What are the 3 various axles types listed?
