red 202 blowing ALOT of oil out the dipstick
_202LX_
Posted 08 December 2008 - 01:17 PM
Posted 08 December 2008 - 01:24 PM
Posted 08 December 2008 - 01:27 PM
_202LX_
Dont talk about the old girl like that! Besides , i need to have that engine in to get my defect offmotor's f*ckt, time for a 308! LOL
Edited by 202LX, 08 December 2008 - 01:28 PM.
Posted 08 December 2008 - 01:34 PM
_jabba_
Posted 08 December 2008 - 01:37 PM
_202LX_
Posted 08 December 2008 - 02:02 PM
_Drag lc_
Posted 08 December 2008 - 02:23 PM
when you had the 2 plugs out of r/cover was it breathing heavy from them? while running
Thanks hayden
_202LX_
Posted 08 December 2008 - 02:33 PM
_Drag lc_
Posted 08 December 2008 - 02:59 PM
Thanks Hayden
_202LX_
Posted 08 December 2008 - 03:01 PM
The engine isnt allblocked up, i pulled it all apart and put new gaskets in it before i put in in the torana
Posted 08 December 2008 - 03:36 PM
_202LX_
Posted 08 December 2008 - 03:40 PM
Posted 08 December 2008 - 06:06 PM
Don't do the oil filter.
Edited by rodomo, 08 December 2008 - 06:08 PM.
Posted 08 December 2008 - 09:22 PM
how do you check to see if the PCV is working properly?
Squeeze the hose after the valve and see if the revs drop.
and what is a leakdown test?
Just run a compression test first.
Edited by ALX76, 08 December 2008 - 09:24 PM.
_202LX_
Posted 18 December 2008 - 06:18 PM
Posted 18 December 2008 - 07:00 PM
Place the bolt in one end, put a hose clamp holding it. Put the other end over the dipstick tube (with dipstick removed) and put hose clamp over and tighten it. Wala, problem solved
Dip stick tube is on the wrong side of a 202, crank blows oil strait up it.
_bon_scott_
Posted 18 December 2008 - 07:03 PM
_202LX_
Posted 18 December 2008 - 07:16 PM
Get a piece of 5/16" fuel line about 2" long, two hose clamps and a bolt that fits snuggly inside the hose.
Whats the worst that can happen if i did this? Where would my oil go?
Posted 18 December 2008 - 07:20 PM
#21
_oldjohnno_
Posted 18 December 2008 - 07:30 PM
Clean out the pcv valve or replace it. If it's sticky you could have a lot of air being pulled through at idle, probably also rough running and inconsistent idle speed. It should also have either a vented filler cap (like the old reds etc had) or a hose from the rocker cover to the air filter as on the later engines. This is just to allow fresh air to enter the engine to replace the air pulled through the pcv valve. If you have neither of these you could end up with enough vacuum in the engine to dislodge cork gaskets..Sorry this isn't going to help the OP, but is sort of related to the topic. My engine is creating a lot of vacuum inside the rocker cover, enought that if I pull the front seal out it will whistle if its still half in. Doesn't seem to be causing any issues and isn't breathing out so just wondering what it is
#22
_bon_scott_
Posted 18 December 2008 - 11:06 PM
Ah thankyou, I've been baffled for ages as to why it had vacuum inside the thing. I don't remember if the pcv is actually fitted anymore because the rocker cover i have is only 2 hole and I think the one pipe connects to something else and the other hole is just sealed. I've got a nice new rocker cover to go on with a breather so I'll chuck that on, cheers!
#23
Posted 19 December 2008 - 10:00 AM
Did a compression test. Got 180 on 4 cyls, 175 on 1, and 170 on the other. Now what do i do???
Did you do this wet or dry?
Couple of things, first, if the above figures are dry and a wet test bumps them up I would think there is alot of blowby past the rings.
How old is the motor? Does it use oil or burn oil?
Is the PCV system working?
IS the dipstick sealing?
#24
_202LX_
Posted 19 December 2008 - 10:14 AM
#25
Posted 19 December 2008 - 10:28 AM
IMO your readings would seem ok for a dry test but it does not hurt to do it properly.
