308HT engine number
17 replies to this topic
#1 _xr81966_
_xr81966_
Posted 17 December 2008 - 01:11 PM
Hi guys and girls , im new to this site so dont laugh :tease: . My son recently purchased a 308 red motor for his WB ute project and it has the HT prefix stamped on it . The full engine number is HT68585 and i think the letter R after the numbers . Now does anyone know if this motor was out of an LH/LX Torana ? Any help would be appreciated . Thanks Tony
#2 Rockoz
Rockoz
  • 4,054 posts
  • Name:Rob
Posted 17 December 2008 - 01:35 PM
will swap you for a motor out of a WB Statesman
#3 GML-31
Posted 17 December 2008 - 01:43 PM
there would be lots of people who may be chasing a HT block, so if he doesnt mind I am sure someone will do a deal in your favour
#4 _@milco@_
_@milco@_
Posted 17 December 2008 - 02:29 PM
i had a HT is most likey out of a lh or lx SLR5000 ( date code on the size can verify which model/year) you can get a pretty penny for them as they are sought after if the date match's with in a few months of a SLR5000 i also beleive they came in SL tagged 308 toranas as well.
#5 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 17 December 2008 - 03:05 PM
Did 308's come out in sl's?
#6 _brutass08_
_brutass08_
Posted 17 December 2008 - 03:55 PM
Hey Tony as the guys say it sounds like it is out of a lx torana , but would have to match casting numbers to ensure it is all good , I also have a blue 308 and turbo 400 that has just come out of a running statesman that got wrecked for parts , so if he is interested in swapping and cash etc give me ring , I live in Bunbury , cheers Brutass.0466362530
Edited by brutass08, 17 December 2008 - 03:57 PM.
#7 yel327
  • 13,717 posts
Posted 17 December 2008 - 05:16 PM
The R on the end can mean two things. If the whole number is in factory stamps it means the number has been accidently stamped twice in the factory so the R is tacked onto one of the engines to mean REPEAT eg HL68685 might have been stamped and someone hung over stuffed up and stamped HT68585 so the R is added. This means it's an original LH/LX 308 block and to the owner of the original car it came from it's worth substantial money.
If the stamps don't look factory it means the block has been decked and an engine shop has stamped the R there to mean the number has been restamped. If this is the case the block is worth no more than any other 308.
There has also been some XU-1 and L34 engines turn up with an R on the engine pad too, but the meaning for these is unclear at this stage. However for all other Holden engines the R means as above.
#8 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 17 December 2008 - 05:40 PM
Engine number HT68585 is an early/mid1977 range engine number, so from an LX. The cast date will give some idea if the number is original or a restamp.
#9 _xr81966_
_xr81966_
Posted 17 December 2008 - 06:05 PM
Thanks for all the info . Where would we find the cast date ? Is that stamped inside the motor ? The motor is complete and running and we do not wish to pull it down . Thanks for the offers to sell/swap but i only wanted to find out if in fact it came from a Torana or not . A mate of mine said he thought it might have come from one .
#10 _darrenmark1_
_darrenmark1_
Posted 17 December 2008 - 06:41 PM
Mate the date cast is inbetween the manifold and timing cover, Should be somthing like 5F6 or something like that.
#11 arrimar
arrimar
  • 3,134 posts
Posted 17 December 2008 - 06:43 PM
just below the thermostat outlet on the right hand side there'll be a clock and a few digits cast.
#12 yel327
  • 13,717 posts
Posted 17 December 2008 - 07:14 PM
True, but usually the original number has been restamped if an R is placed on the end so the casting date won't help. If this is the case and the engine belonged to your car I suppose you'd live with it. But if it doesn't you might as well have a QT block. I've got a similar problem with a Bathurst HK engine here. It's an original 327 from an early Dandenong GTS327, but it's been decked during a rebuild and the original engine number restamped. It's of no use as it is so I'm going to deck it again and use it as a spare engine for one of my early GTS327's, basically build it up as a 400hp 377 so if I bust it I haven't busted the original motor. It'll probably be on club rego anyway so I won't even bother with a number. If I have to i'll get a NxxxxP number for it.
#13 _xr81966_
_xr81966_
Posted 17 December 2008 - 07:16 PM
19K6 does that sound about right ?
#14 _gtr-xu1_
_gtr-xu1_
Posted 17 December 2008 - 07:41 PM
19 oct 76
#15 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 18 December 2008 - 05:43 AM
Typically the cast date on the block preceeds the vehicle build date by one or maybe two months, but they are very (most) often dated the same month. Engine numbers for cars built in during the Oct-Nov 1976 period we in the HT65### range. So your cast date seems to be too early for the engine number. I think Yel327's suggestion that its a restamp is on the money.
#16 yel327
  • 13,717 posts
Posted 18 December 2008 - 08:09 AM
They can be out by a lot more but it's not all that common. If a block has problems during maching eg a tap breaks off they were sometimes put aside and worked on later. This most often shows up in Chevs where the engine number has a date code in it. I've seen cast dates a day or two before engine number dates. I also have a few with 4 months between them. So it might be the right number for the block, but probably not. 3000 or so Torana engine numbers out....Remember auto 6cyl Toranas were using HQ engine numbers at that time so do the maths. Where does Hx68xxx place it compared to other Torana build dates?
If you put a phot here of the engine number it should be obvious it it's a restamp or not.
#17 _brutass08_
_brutass08_
Posted 18 December 2008 - 12:09 PM
Now you guy's have me thinking , I was always going to try and get a block that matched my genuine 76 model slr5000 , due to when I bought it it had no engine # so obviously had to put one on when it went over the pits( motor had been decked when it was rebuilt by previous owner/s ). But now checking the cast date , which is 27j6, it may very well be the original motor due to the car build date being 10/76 , not sure what to do to check , but I have put a # on it from a broken 308 I had in the shed ,a few years ago now , was'nt aware of cast dates etc back then. May have to do more research I guess , cheers.
#18 yel327
  • 13,717 posts
Posted 18 December 2008 - 12:35 PM
27J6 (27/9/76) is a spot on cast date for a 10/76 Holden. If it was too much later it'd be getting awful close, although Toranas are probably a bit closer in build vs cast date since the Engine plant and Dandenong assembly plant are in the same area. It'd take a little while for engines to get to Elizabeth, Mosman Park, Acacia and Elizabeth. It is also possible that a 10/76 build was completed a few weeks into 11/76.
