Brake Master Cylinder Bore Sizes
4 replies to this topic
#1 gooley
gooley
  • 529 posts
  • Name:Jason
  • Car:Holden Torana LC 1970 Coupe
Posted 28 December 2008 - 08:06 PM
my uncle has asked me to buy a master cylinder cos it has a bigger bore and he says mine is a smaller one.. Just wanted to know how many different master cylinders are their for the LC/LJ model with different bore sizes.? What are the advantages of fitting a bigger master cylinder? Does the brake pedal feel different? What are the sizes?
Edited by gooley, 28 December 2008 - 08:08 PM.
#2 _Bomber Watson_
Posted 28 December 2008 - 09:55 PM
Im nearly certain that LJ has the same 1" bore as the Kingswoods do.
I believe early LC had 15/16" bore??
And a smaller bore will make the pedal easier to push but you must move it further to displace the same volume of fluid, or cause as much braking force as a larger bore, which will be harder to push but require less movement.
All the above is my understanding and may be incorrect, awaiting someone to confirm.
cheers.
#3 dattoman
Posted 29 December 2008 - 07:41 PM
They are all 1"
Unless its a 4 cyl with a plastic bottle
#4 gooley
gooley
  • 529 posts
  • Name:Jason
Posted 05 January 2009 - 08:32 PM
do you recommend i should fit a bigger size one??
#5 dattoman
Posted 06 January 2009 - 07:13 PM
If yours is all cast iron or alloy
Its 1" and there isn't a bigger one
Why would you think you need a bigger one anyway
