holden 6 Yella terra head with yt5008 roller rockers
11 replies to this topic
#1 _boynuz_
_boynuz_
Posted 30 December 2008 - 11:22 PM
Hi is it a good idea to run guide plates with the yella terra head and roller rockers yt5008 and
will it clear with the standard rocker cover.
The bottom end is a 186 built to 71 xu1 specs.
#2 _Drag lc_
_Drag lc_
Posted 31 December 2008 - 07:11 AM
boynuz,
if your head is a early one with the pushrod slots in the head instead of the round holes like Hq type with bridged rockers originaly you should be alright as the slots in the head for the pushrod will guide the pushrod and rocker arm.
as for the std rocker cover we run the same rockers as you with guide plates and .500"+ valve lift
with std r/cover just with the baffle removed.
hope this helps.
Thanks Hayden
#3 _boynuz_
_boynuz_
Posted 02 January 2009 - 10:38 PM
Hi Hayden
I have the early type head with the push rod slots in the head and the cam i will be
using is wade 373 cam which the lift is 0.286 so i think all should be good.
Boynuz
#4 _PRO-192_
_PRO-192_
Posted 03 January 2009 - 02:32 AM
should be fine with a small cam like that, from memory yt5008's are 1.5 ratio?? i have had lots of dramas with yella terra rocker gear bending pushrods and popping them out with the cam i run which is around the .530" we even tried die grinding the back out of them to allow a greater angle but in the end changed to crower... also have used milodon and crane on other engines i have built same as mine...
#5 _PRO-192_
_PRO-192_
Posted 03 January 2009 - 02:57 AM
and also broke alot of camshafts at the reliefs
micko
#6 _boynuz_
_boynuz_
Posted 03 January 2009 - 03:17 AM
Hi the yt5008's are 1.5 ratio, It looks like use are all running monster cams compared to what i'm going to run.
Will see how my setup goes once i get it finished.
#7 _FCCOOL_
_FCCOOL_
Posted 22 March 2009 - 07:24 AM
I was wondering how you went.
I have yt5008 rockers with yella terra guide plates, i had to modify a fabricated sheetmetal aluminium rocker cover to get it on over the guide plates, the guide plates also had to be bent carefully to fit, now i cant get the rocker cover off without removing the wiper motor (FC holden)
my head is a 12 port black head with the big holes and i was told when i got these rockers that i would need guide plates.
ii have never had a standard rocker cover to try but my other rocker cover, a KC alloy one to suit roller rockers would not fit even after heaps of grinding.
#8 _UCV80_
_UCV80_
Posted 22 March 2009 - 11:19 AM
If you grind the corners off some of the guides and give a kc cover a good rasp it will fit, iv done this before. bit of a pain in the ass tho.
#9 _FCCOOL_
_FCCOOL_
Posted 23 March 2009 - 07:40 PM
ive cut the corners off the guide plates and started grinding some of the rocker cover but it still needs to move across about 4mm and i dont think there is enough meat.
these are the yt guide plates with the brass inserts, has anyone used them on a 6?
#10 _Drag lc_
_Drag lc_
Posted 24 March 2009 - 07:22 AM
yes we have the same ones as you and same rockers have you checked it is not hitting on the cutouts for the bolts in rockercover on the dizzy side i did try and fit an alluminum r/cover on a few weeksd ago but it did need a bit of surgery to fit and i couldnt be bothered to do it so the std one went back on hehe. are these these the ones you mean?
Thanks Hayden
#11 orangeLJ
Posted 24 March 2009 - 08:32 AM
Ive got the same rockers and the same guide plates, no hassles at all.
Just slapped my rocker cover back on and away I went.
#12 _boynuz_
_boynuz_
Posted 05 April 2009 - 11:26 PM
Hi sorry for late reply havn't been on forums for ages, I checked my roller rockers and they are actually yt5007 which is the 3/8 type and have decided i'm not going to use guide plates and the
roller rockers clear the standard rocker cover.
