how to know if ball joints are stuffed?
#1 _SnotGobbler_
Posted 01 January 2009 - 07:10 PM
looked through the site and recommendation is to leave the top ball joints alone unless they are stuffed because they are riveted in.
after 35 yrs surely they need replacing....how do i know if they are stuffed?
thanks
Posted 01 January 2009 - 07:24 PM
Mark
Posted 01 January 2009 - 07:30 PM
exsesive movement in the ball joint itself,corrosion,broken rubbers.I was in the same situation after buying the car and deciding to rebuild the front end i thought it was senseless not to change them and everything else that could cause a problem. I think from memory that mine where original as well. don't have to worry now all new.
Mark
Ive seen some new top joints fitted that were worse than the OEM fitment.
Did you replace your inner tie rods as well?
It is sorta like rebuilding a motor and replacing the crank just cause it is 35 years old.
#4 _SnotGobbler_
Posted 01 January 2009 - 08:00 PM
anyway thats a bit off topic i guess
Posted 01 January 2009 - 09:52 PM
Then, if you grab the top and bottom of the wheel and rock it in the direction of the arrows, you will see/feel the play in these components.
The lower inner control arm bushes will still be loaded by the spring and won't reveal much play. A bar to lever them and a visual inspection of the centre line of the pivot in relation to the bush hole in the control arm will give you an idea of wear.
#6 _SnotGobbler_
Posted 02 January 2009 - 09:02 AM
ill just replace them, have new replacement ball joints now
now need to figure out where im to get the tools to remove/replace them all
Posted 03 January 2009 - 06:51 PM
mark
#8 _SnotGobbler_
Posted 20 March 2009 - 08:01 PM
as it looks as if the bush housing is offset slightly.. but maybe not. doesnt seem to be specified in the workshop manual anywhere
DSCF0073.JPG 313.85K 19 downloads
#9 _OtG_
Posted 20 March 2009 - 08:29 PM
#10 _why-psi_
Posted 20 March 2009 - 08:57 PM
Edited by why-psi, 20 March 2009 - 08:59 PM.
#11 _SnotGobbler_
Posted 22 March 2009 - 09:02 AM
ok, so ive worked on my chasis crossmember stc and replaced/painted it all etc. now im wondering.. does it matter which side the lower control arms go in for the lj?
so anyone know or suggest?? need to know so i can put the thing back to together :-)
Posted 22 March 2009 - 09:20 AM
............................................The one pictured is the driver's side.
#13 _waz355_
Posted 22 March 2009 - 11:18 AM
The picture drawn above would not actually check to see if a ball joint is worn. Moving the wheel in the direction of the arrows will only check wheel bearing play.
There is 2 ways to check a ball joint. Either having the joint loaded and removing the load by the use of a crow bar and checking for movement. Or having the ball joint unloaded and applying a load with use of a large set of multigrips or sometimes you can fit a bar in there to do it.
In the picture drawn the ball joint is still loaded so if you put a crow bar between the wheel and the ground and pulled up this would show any movement in the bottom ball joint.
There are 2 types of ball joints load bearing or locating and it depends on the type suspension system for if the upper or lower ball joint is locating or load bearing.
Does that make sense?
Posted 22 March 2009 - 11:32 AM
The only load on either balljoint in the diagram are the unladen weight of the wheel/hub assy, stub and upper control arm.
#15 _waz355_
Posted 22 March 2009 - 11:40 AM
I think it may be possible for your method to work if the joints were very very badly worn, but definately would not show day to day wear. I would be gladly proven wrong though, hey I have been wrong before!
Waz
Posted 22 March 2009 - 02:26 PM
I'll keep doing it my way
#17 _Terrible One_
Posted 22 March 2009 - 06:49 PM
Multi grips and/or a pry bar will quite easily show any wear in a balljoint.
Posted 22 March 2009 - 07:06 PM
You do it your way.
I'll keep doing it my way.
#19 _SnotGobbler_
Posted 23 March 2009 - 06:59 AM
Hang on, I'll go look, brb.............................................................................
sweet thanks! :-)
Not being a smarty pants cosidering i was the one to ask the question lol......
but come to think of it... im with Waz, im no mechanic, but i did some work at a few garages when i was a school kid.
i remember being taught thats the way to check wheel bearing play by taking the load off a wheel and rocking it in the direction of arrows, and the crow bar way to check ball joints...
Posted 23 March 2009 - 07:28 AM
#21
Posted 23 March 2009 - 09:08 PM
Excellant post rodomo, I can't believe how much i've forgotten
mark
Thanks mate!
It's better to have forgotten something and then remembered it than to never have learnt it.
#22 _waz355_
Posted 23 March 2009 - 10:06 PM
The majority of wear will be picked up by moving the joints in an up and down motion. When ball joints fail (for example the bottom one in your drawing) the ball actually pulls UP out of the socket, hence the reason for checking the up and down movement.
I am looking at this from a trade perspective. As I said before it is possible that your way may pick up a really excessively worn joint, BUT this is not an effective way of checking a ball joint. It is a very good picture though!
Am I making any progress?
#23
Posted 23 March 2009 - 10:37 PM
I have used these methods as well on particular balljoints and tie rod ends.
I won't turn this into a pissing contest either.
I would have already won it as I pissed myself when I read this:
"Moving the wheel in the direction of the arrows will only check wheel bearing play"
Use some muscle and try it before you can my method.
#24 _Yella SLuR_
Posted 24 March 2009 - 05:08 AM
Edited by Yella SLuR, 24 March 2009 - 05:08 AM.
#25 _waz355_
Posted 24 March 2009 - 07:18 AM
