Starting Engine without using ignition n key
43 replies to this topic
#1 gooley
gooley
  • 529 posts
  • Name:Jason
  • Car:Holden Torana LC 1970 Coupe
Posted 10 January 2009 - 10:40 AM
My ignition Switch is messing up so while i wait for a new one i just want to start the engine....
I remember there was a way from connecting wire up to the positive side of something man i cant remember.. been a while since i got my torrie back
#2 GML-31
Posted 10 January 2009 - 10:48 AM
so you want to know how to hotwire a car..lol
#3 gooley
gooley
  • 529 posts
  • Name:Jason
Posted 10 January 2009 - 10:53 AM
yeah but for my own car i have done it before to my car around NOV 07 then it got sent to painters for a year and i just got it back now....in that time i forgot how to start it up by hotwiring but at the coil pack....
I just cant remember if its at the positive and then other lead to negative(Earth)
Edited by gooley, 10 January 2009 - 10:57 AM.
#4 _lx-304_
_lx-304_
Posted 10 January 2009 - 11:06 AM
take the plug off the ig switch.put some wires with terminals on them,on the red pink/yellow and purple.join the red and pink/yellow together,which will give ig and touch them to the purple to get it to crank.do not leave the purple connected as it will continue to crank.this will start the car.
dave
#5 gooley
gooley
  • 529 posts
  • Name:Jason
Posted 10 January 2009 - 11:13 AM
cheers for the PM GML-31... and thank you dave also but GML-31 was on the right track... i didnt want to deal with the wiring but just with coil pack and starter motor way instead
#6 _lx-304_
_lx-304_
Posted 10 January 2009 - 11:16 AM
can you tell me how to do it that way,i would be interested to know another way
dave
#7 _Lamo_
_Lamo_
Posted 10 January 2009 - 11:24 AM
dave
I would have thought a monentary switch to the starter soleniod would do it.
#8 _lx-304_
_lx-304_
Posted 10 January 2009 - 11:35 AM
it depends if he just wants to start it or does he want the car functional to drive.for this power needs to provide to the brown wire on the switch as well.i thought providing power to the coil would only give you ig and nothing else.it is at the switch where it all happens.
dave
#9 _PRO-192_
_PRO-192_
Posted 10 January 2009 - 11:37 AM
wire from + batt to + coil then to fire "short" the + terminal on the starter motor to starter terminal on the starter motor(purple wire) using a screwdriver or similar
this will start it
"do not try this at home or use this information for illegal purposes"
micko
#10 _mumstaxi_
_mumstaxi_
Posted 10 January 2009 - 12:22 PM
I you "need" to move the car like this, just make sure you have the IGN key/barrel in a position so the steering lock can NOT engage !
MT
#11 _Lamo_
_Lamo_
Posted 10 January 2009 - 02:19 PM
MT
Oh yeah thats important too. Actually, what is VERY important is that the car is not in gear.
#12 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 10 January 2009 - 02:33 PM
Yeah, the ignition on my old Lj played up one time and I had a switch wired up under the bonnet. Take it outta gear first!! :spoton:
#13 _Lj253_
_Lj253_
Posted 22 November 2015 - 01:56 PM
Does anyone no the ignition working for the lj
#14 _Bomber Watson_
Posted 22 November 2015 - 02:00 PM
I dont quiet understand the question mate, can you be more clear?
If your chasing a wiring diagram, buy a workshop manual. Preferably a genuine GMH one, they pop up from time to time for reasonable coin, or if you cant get one of them an ellory's/gregory's. The GMH one is 100 times better though.
#15 VDO
VDO
  • 191 posts
  • Name:Chris Curtis
Posted 22 November 2015 - 04:54 PM
http://s1072.photobu...sc7fb6.jpg.html
#16 _Lj253_
_Lj253_
Posted 22 November 2015 - 05:06 PM
Sorry guys I don't have a key for my lj and I want to get it started anyone ever done this ?
#17 _Lj253_
_Lj253_
Posted 22 November 2015 - 05:09 PM
And if it makes a difference it has a 253 in it
#18 _Bomber Watson_
Posted 22 November 2015 - 05:12 PM
Look its easy to do, and has been covered above.
Simplest version is to run a wire from the positive battery terminal to the positive side of the coil.
Then just ark out the starter motor between the positive nut on the solenoid and the little spade terminal just above it with a screwdriver..
Edited by Bomber Watson, 22 November 2015 - 05:12 PM.
#19 _Lj253_
_Lj253_
Posted 22 November 2015 - 05:17 PM
Thanks mate is that the only way it can be done ?
#20 _Bomber Watson_
Posted 22 November 2015 - 05:22 PM
No. theres a million and six ways it can be done. Thats just the simplest.
What exactly are you trying to achieve? Temporarily start it to see if it runs, or actually fix the issue, or something in between?
#21 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 22 November 2015 - 05:25 PM
http://www.gmh-toran...-colour-charts/
#22 _Lj253_
_Lj253_
Posted 22 November 2015 - 05:32 PM
Well I have just brought the car and the guy didn't have the keys so yeah I want to see if it runs
it hasn't been started in about 5-6 years but it cranks by hand fine,
Edited by Lj253, 22 November 2015 - 05:36 PM.
#23 _Lj253_
_Lj253_
Posted 22 November 2015 - 05:36 PM
Wasn't much help but thanks
#24 _Bomber Watson_
Posted 22 November 2015 - 05:47 PM
THat color pick is probably the most help you will get.
If you want to make it a bit more permament you can put a toggle switch in the line going to the coil, this will become your ign on and off, and you can just run a wire from the positive battery terminal to the spade terminal on the starter solenoid, again with a toggle switch in line somewhere, this is your starter switch, flick it on to crank, off to stop cranking.
#25 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 22 November 2015 - 06:21 PM
take steering wheel off.get flat screwdriver and hit in the slit that holds the ignition barrel in and take it to a lock smith...or just get a new on.
only takes about 10secs to knock out.should be able to kick her in the guts then
Edited by madtoranajzedded, 22 November 2015 - 06:27 PM.
