Removing baked-on burnout rubber?
24 replies to this topic
#1 _BoltZ_
_BoltZ_
Posted 09 March 2006 - 10:11 AM
Hows it going?!
A mate of mine called me up last night and asked me to post a question on here... i know it's been done to death but anyways. He has a VY SS, and recently has discovered the joys of drag racing, and burnouts. Unfortunantly for him, he didn't realise until recently that burnouts in VY's tend to collect rubber on the rear of the car, and it is "now hard and feels like coarse sandpaper".
Like i said before, i know this topic has been answered a number of times on the old forums, but it'd be great if anyone could shed some light on how to get the offending rubber off without damaging the fresh paint on the car...
Thanks heaps guys,
BoltZ
#2 ToRunYa
ToRunYa
  • 2,073 posts
  • Name:Em
Posted 09 March 2006 - 10:19 AM
a trick i learned a wile ago was (im waiting for it) vasoline
it softens the rubber and you can just wipe it off. havent seen any adverse effects on the paint but i always make sure i get all of it of with a detergent.
#3 GML-31
Posted 09 March 2006 - 10:23 AM
do you only use this on the arseend of your car to loosen it up....someone had to do it....sorry
#4 ToRunYa
ToRunYa
  • 2,073 posts
  • Name:Em
Posted 09 March 2006 - 10:25 AM
hence why i was waiting for it lol
#5 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 09 March 2006 - 10:26 AM
Paint on new cars is pretty tough nowadays, I've always used petrol or white spirits. Shellite works well also. I'd be interested in the seeing how the vaseline goes...
There are products out there that you put on prior to doing burnouts which act like a barrier, so the rubber can just be hosed off at the end of the night.
#6 GML-31
Posted 09 March 2006 - 10:31 AM
why wouldn't you just put a few layers of cling wrap on it prior??
#7 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 09 March 2006 - 10:48 AM
Coz you don't want to look like a pussy with glad wrap up ur guards... jk :P ;)
#8 knoath
knoath
    far.... FAR
  • 2,036 posts
Posted 09 March 2006 - 10:53 AM
Easy off Bam!
One wipe and BAM, it's gone... :tease: :spoton:
(this is by no means to be taken seriously)
#9 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 09 March 2006 - 12:08 PM
Big Kevs Burnout Crap Remover...I'm Excited.
#10 ToRunYa
ToRunYa
  • 2,073 posts
  • Name:Em
Posted 09 March 2006 - 12:13 PM
^ carefull using that you may get too exited and have a corinary...
#11 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 09 March 2006 - 12:21 PM
hehe..originally my post went a little further than that...but I thought better of it and delete it before I posted.
Clear....BEEEEEEEEEEEEEEP :spoton:
#12 GML-31
Posted 09 March 2006 - 01:35 PM
Old big Kev will be turning in his grave knowing he missed out on a golden opportunity....
#13 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 09 March 2006 - 01:54 PM
Kero. Get a rag soaked in it, hold it on to soak the rubber. give it a wipe and it will come off easy, no paint damage. All detailing trick, works on tar too.
#14 _SSHatch_
_SSHatch_
Posted 09 March 2006 - 05:19 PM
Prepsol, Prepwash whatever you want to call it!!
Works fine, just spray on, let soak and wipe off!!
And I cant believe that a simple question turned into a conversation about asses, vaseline, rubbers, cling wrap and wipes.
This is almost porn by now!! :rolleyes:
#15 retired308
retired308
  • 187 posts
Posted 10 March 2006 - 08:29 AM
old drag racing trick...put the vaseline on the car first before burnouts,smear it on over the back guards ,then wash it off when finished, ....
#16 _73LJWhiteSL_
_73LJWhiteSL_
Posted 10 March 2006 - 08:46 AM
I know of a product, made from oranges, that is designed to remove stickyness. I've used it to remove windscreen sealent, just spray on, and wait 5 minutes then it just wiped off, dunno if it would work the same for burnout rubber. :huh:
Steve
#17 _Bomber Watson_
Posted 10 March 2006 - 10:07 PM
i have a preventative suggestion. i havn't tryed it yet but will. silicone spray. you can get it from anywhere. i used to use it a lot back when i was racing off road radio controlled cars to stop the mud from sticking to the chassis. basicaly spray it on and an hour or so later it dry's to a clear slippery finish. just hose off later. also if you spray it on black plastic it makes it shiny :P . shouldent hurt paint.
#18 _greenmachine215_
_greenmachine215_
Posted 12 March 2006 - 01:45 PM
Easiest method i know of, Spray WD40 Or RP7 on the area with the rubber let it sit for a min, then start wiping
it makes a bit of black mess But just keep spraying and wiping Comes off easy :spoton:
#19 _MYLJ_
_MYLJ_
Posted 12 March 2006 - 02:19 PM
Prepwash on a rag is all I use, plenty of clean rags and I always work my way down from the top of the rubbered area to the bottom of the panel. When its all off I then give it a wash with soapy water to remove the residule prepwash.
#20 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 15 March 2006 - 05:18 PM
I wonder if "pure and simple" would work???
Stops food sticking to pans etc.
#21 _Hotrodder_
_Hotrodder_
Posted 16 March 2006 - 12:41 AM
And a quick re-spray along the doors and 1/4 panels.......... :tease:
#22 _MYLJ_
_MYLJ_
Posted 16 March 2006 - 08:59 AM
:spoton:
...........errrrrrrrrrr yeh that too :spoton:
#23 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 16 March 2006 - 11:53 AM
Vasoline is recommended if you scratch the paint. Just smear some on and it will stop the oxygen and water reaching the bare metal and rust forming.
I put some on when I scratched my guard, an iron fence closed on me during reversing. I was planning to have it painted but didn't get around to it.
I applied a bit more vaseline to the spot after washing my car the first few times, it hardened I guess and now it is a dark colour but has kept rust away for a few years now.
I heard on the radio this morning you can use peanut butter to remove bugs and tar from your paint - smooth is recommended as crunchy could scratch.
s
#24 _smokem_
_smokem_
Posted 19 March 2006 - 09:12 PM
we use those cheap 2 buck cans of degreaser and it comes off
piss easy just spray it on then get ya hands dirty by rubbing it
then hose it off iff its been there a while you probably have to
do it a couple of times,ive seen plenty of tyres go band and leave
a lovely black mark down the side of the car and it comes off straight away..
ive been doing this for years and its never left a mark on my paint!!
#25 _BoltZ_
_BoltZ_
Posted 21 March 2006 - 12:07 PM
Thanks for all your helpful advice everyone... i've passed it onto the said party, he's appreciative of all your feedback.
Cheers :spoton:
