LX Steering Column Inner Shaft Collapsed
_redrana_
Posted 11 March 2006 - 08:26 PM
Is it ok to use the inner shaft without the plastic pins in it as I can slide the shaft back to its correct length or is this too risky?
Otherwise can the pins be replaced somehow? A wrecker said he heard of people using knitting needles to replace the pins?!?? Sounds a but dodgy to me?
Anyone know if the rubber seal that goes around the column and seals it in the firewall can be bought new?
Any advice or thoughts appreciated.
Posted 11 March 2006 - 09:31 PM
RACV MAN
_CHOPPER_
Posted 11 March 2006 - 09:56 PM
_Yella SLuR_
Posted 12 March 2006 - 12:06 AM
The consequences of getting it wrong are too great.
Edited by Yella SLuR, 12 March 2006 - 12:06 AM.
_Yella SLuR_
Posted 12 March 2006 - 12:09 AM
<Yella introduces politically correct GMH Torana Forums ---> New concept OK>
_redrana_
Posted 12 March 2006 - 06:58 AM
Hah no problem - I was trying to remove the lower bearing and gave the column a tap with a mallet then realised the risk of affecting the pins - sure enough they had sheared. Out of interest it didn't take much pressure.Just out of interest, wouldn't happen to be the result of removing the steering wheel by any chance, or trying to remove cotter pins with the column unsupported? Would be interested to know how it happened, just for information, not to bag you out.
I've had a look at some other second hand columns and they had a similar problem with the inner sharf being shorter than they should be (without me doing anything stupid to them
Thanks for the advice - I'll get the column sorted properly by a specialist.
_redrana_
Posted 12 March 2006 - 07:06 AM
- no removing the cotter pins didn't seem to have any effect or removing the steering wheel. I'd removed the whole column with steering wheel in place.
In relation to removing cotter pins is anyone aware of a decent tool that would remove these properly and where they can be bought? There is a specific tool recommended in the Holden service manuals but I'm sure they wont be available for purchase from Dealers (but will try that this week).
_Yella SLuR_
Posted 13 March 2006 - 09:18 AM
Yes, replacement column I got was also short, but the guys here at Capital Steering and Suspension fixed that all up for me.
Here is why I needed to rebuild my column:- cracked outer column.
Posted 16 March 2006 - 10:01 AM
The pins are VERY fragile, and the shaft inner can't slide past where the pins hold it in place anyway.
_Yella SLuR_
Posted 16 March 2006 - 11:15 AM
Posted 23 March 2006 - 11:12 AM
_Yella SLuR_
Posted 23 March 2006 - 11:30 AM
It is a design fault that they start cracking in this location, the pictured example is a bit extreme though. Only discovered it because the mechanic knocked it back for a faulty upper bearing on the rego check.
_JBM_
Posted 24 March 2006 - 09:49 AM
There is a pic of it in the LH factory workshop manual, looks a bit like a roller chain link breaking tool.
Did anyone end up finding one or making one?
James
Posted 24 March 2006 - 05:18 PM
had one almost exactly the same in my first torana.
Welded it up in the car and sold it not long after..
Ahh memories!!!
Damo
_redrana_
Posted 24 March 2006 - 07:46 PM
Yep I was after an original tool for removing the flexible link cotter pins or failing that a substitute that will do the job properly - no luck yet finding one though. I'm still keen to hear if anyone is making them or if anyone who has found a simialr tool to do the job.Someone was after a GM service tool to remove the steering cotters.
James
