Borgwarner will it handle it?
Posted 24 February 2009 - 11:26 PM
Just wondering whos thrown wat at a bw diff, ive got a tiny bw lsd in my Lc and im now heading toward an auto with transbrake etc in my lc, my thoughts are maybe the Bw wont handle it maybe i should go back to the Nine inch? I know there a few Vl turbos runnin ten's nines still with borwarners but i dont know how much torque/dumpin there gettin?
Whats thoughts n what have u guys thrown at them?
Posted 24 February 2009 - 11:36 PM
Posted 25 February 2009 - 05:48 AM
Although when you say tiny do you mean 2 pinion/25 spline?
Posted 25 February 2009 - 09:40 AM
Posted 25 February 2009 - 11:39 AM
The weak point on the BW diff is the tubes plug welded into the housing, with slicks, sticky track and enough torque put to the ground on launch they just twist the tubes out of the housing.
Usually around 500Hp+ and a good rear end setup will do it.
Posted 27 February 2009 - 07:18 PM
Its got mini tubs adjsutable arms Coil overs and 18by10's! I dont really wanna go to nine inch (already cut the bw down n welded brackets to the cast EKK )but then i dont wanna break the borgwarner!
Posted 27 February 2009 - 09:57 PM
I'm still going to keep the b/w in my lc...it's still going quite well with the abuse I gave it.
Posted 27 February 2009 - 10:35 PM
Yes...
9 inches break too...ask Ronald Redsox.
Posted 28 February 2009 - 01:32 AM
Perhaps putting pins in the housing so it cant twist around, if you get what i mean.
IE, where the tubes go into the housing, drill and insert pins through that join to stop it from twisting....
_ronaldoredsox_
Posted 28 February 2009 - 09:45 AM
Posted 28 February 2009 - 05:43 PM
Guys!~
