Help me fill in my WA Modification application
PG 3 original engine number = I assume this is the engine that�s currently in it ??
PG 3 replacement engine Kw = I�m putting in a 308what should I put down (300hp?)
PG 4 summary of details
Engine Make & Year: HOLDEN 308
Engine Modifications: N/A
Transmission & Mountings: Ford Topload
Differential: Ford 9�
Vehicle Height: ??? it would be way to low in it�s current state, should I put the std height
Front Suspensions: I haven�t though of a brand or type � something suitable for a V8
Rear Suspension: I haven�t though of a brand or type � something suitable for a V8
Chassis: N/A
Steering: N/a
Braking System: 290mm drilled DBA rotors and callipers (Hopper stoppers)
Tyres Front: 245/40/17
Wheels Rims Front: 8� wide 17dia
Tyres Rear: 265/40/17
Wheels Rims Rear: 8� wide 17dia
Seating: OEM
Lighting: OEM
Body: fitting of Torana wheel flares, bonnet scoop & rear wing, cutting guards, cutting hole in bonnet
Exhaust System: Try-Y extractors, twin system dia2.5�
Other:
Provide further details of modifications under the relevant headings overpage � answer all questions or write �not applicable�.
Pg 5
Engine �
will the engine be modified = I�m only rebuilding with the aim of 300hp.
Transmission �
model / type = ford toploader
Modifications = ??
Differential �
model / type = ford 9�
Vehicle ride height �
OEM height to top of roof = ???
Modified height to top of roof = ???
Front suspension �
Will the suspension be modified = yes
What mods = stiffened, suitable for V8, height raised to OEM or slightly below
Will the vehicle front suspension be raise = yes
By how much ??? (depends that the minimum is ??)
How will the height of the vehicle be altered?? = raised to OEM or slightly below
Suspension springs = replaced
Spring height from original = ??
I�ll concentrate on the first 5pages, once I get this sorted I�ll worry about the rest of the document.
Edited by Marshall, 22 March 2009 - 07:53 PM.
