Brake upgrade kit on ebay from Mr Spares
_1ARC_
Posted 24 March 2009 - 01:33 PM
New kit first release, can do in any stud pattern look. Sorry not sure how to link.
The kit is similiar to Hoppers Stoppers and cheaper. It seams that the only differance is that there is no need to swap the sub axles.
Does any one know if these are worth thinking about.
Posted 24 March 2009 - 02:56 PM
Posted 24 March 2009 - 03:06 PM
Definitely doesn't look great, VT style calipers which will most likely require cutting upper arms, and the brackets have just had holes filled and re-drilled.
_sbc57lx_
Posted 24 March 2009 - 03:25 PM
http://cgi.ebay.com....-...:1|240:1318
That was there OLD kit , I'm not 100% sure, But I think their NEW KIT it's a copy of the Hoppers kit, now using AU type rotor and AU calipers, OLD kits did have redrilled mounting points .,., QUILITY, I'VE GOT NO IDEA..........
_1ARC_
Posted 24 March 2009 - 03:44 PM
Posted 24 March 2009 - 04:00 PM
No reciept without paying extra cause he doesn't pay GST
No fitting instructions
No engineering report
Is it worth the saving ?
if I had a new kit I'd be showing pics of that rather than the one he is showing
Posted 24 March 2009 - 06:24 PM
As Datto said to me , hoppers are worth the extra $300 for quality, and piece of mind.
Evan.
Edited by Evan, 24 March 2009 - 06:25 PM.
Posted 24 March 2009 - 06:25 PM
edit: Evan, beat me to it, obviously my figures above are roughly correct, I didn't think that was a big difference in price
Edited by 76lxhatch, 24 March 2009 - 06:26 PM.
Posted 29 March 2009 - 06:02 PM
No engineering report is a deal breaker! They aren't that much cheaper anyway are they? I thought you guys only pay around $1300 for a Hoppers kit?
Hoppers don't come with engineers report either anymore apparently. I brought the hoppers kit that was on here last week and Lee had lost the paper work so he contacted Hoppers and they told him they dont do paper work anymore because the kits are easly complied. Which let me think whats stopping me from copying the mounting brackets & spacers and selling my own complete kit aswell since everything else is off the shelf once you've drilled the blank discs to the right pattern.
Posted 29 March 2009 - 06:16 PM
Posted 29 March 2009 - 06:48 PM
Posted 02 November 2009 - 12:26 AM
_sbc57lx_
Posted 02 November 2009 - 08:34 AM
YES , that is true , but if you add up the cost of all the parts , I think it adds up to about the same - may be just a little more. why not get it all a once?Seeing most of the stuff is available over the counter, isn't all that is really needed is a decent calliper bracket?
Posted 02 November 2009 - 11:26 AM
Well worth the investment in my oppinion.
Posted 02 November 2009 - 06:47 PM
I have recently fitted this kit. It uses AU ii XR8 calipers and discs...
Don't have a replacement part number for the hubs do you?
Posted 02 November 2009 - 08:08 PM
Posted 02 November 2009 - 08:46 PM
Not sure about the part number as he manufactures his own hubs.
"Can I see this letter ?"
I specifically requested the letter from him as it doesn't come with the kit. It simply states that all components are ADR compliant and available in the Australian market on the Au 11 XR8. He then states that the hubs are machined using correct engineering practices.....It was far from an engineering report but was enough to have them accepted.
Like I said, with a little fiddling to fit them, they work really well and are worth the money in my eyes.
Cheers, Gerry.
_robrenjus_
Posted 29 January 2010 - 10:23 PM
Posted 29 January 2010 - 10:39 PM
Cheers, Gerry.
So the hubs are modified AUII Falcon?
Posted 29 January 2010 - 11:08 PM
AU has a hub that bolts to the base of the strut
They are a manufactured hub to take standard Holden bearings
#21
Posted 30 January 2010 - 07:20 PM
#22
Posted 02 February 2010 - 08:20 PM
No
Someone on ebay sells hubs to HQ stubs with any stud patten for about $330 or $350 the pair. I think they in Bayswater, vic. I searched HUBS on ebay and found them but it was a while ago.
