Intermittent Overheating V6 Ecotec
Posted 30 March 2009 - 10:38 PM
It started to overheat (Temp gauge near full) and engine started to hesitate, dash flashed HOT on LCD screen.
But 30sec later the temp came down and normal again and all was OK.
I interrogated the ECU and no codes came up pertaining to temp. temp sensors or otherwise.
Thermo fans are working OK.
Radiator and overflow where full of coolant.
This has only happenned once so far.
I'm thinking sticky Thermostat, but if anyone has other diagnosis, I'm listening.
Thanks.
Posted 30 March 2009 - 10:41 PM
You've probably nailed it. Common fault.
_Torrie_Man_
Posted 30 March 2009 - 10:46 PM
Posted 30 March 2009 - 11:03 PM
happens alot mate, any crunchy bits in hoses/radiator?
Havent pulled off any hoses yet but cant see much from the radiator cap except for a small smear of greasy looking ruston the sides.
Probably the lubricating agent mixed with the loose rust which had me wondering if the radiator might be blocked.
Posted 30 March 2009 - 11:39 PM
Hoses stuff up from the inside out.
Another common fault you might want to look at is a crumbling plastic heater tap.
Posted 31 March 2009 - 05:12 PM
I think he means to grip the hoses and feel if they crack.
Thanks Rod. I changed the thermostat today. The old looks OK (not falling apart or pieces missing)
The heaters hoses are good and no chrunchy bit to speak of TORRIE_MAN.
Heater looks Ok too.
We will ll see how it goes,
Thanks guys.
_Terrible One_
Posted 31 March 2009 - 05:55 PM
Rodomo's right about the heater tap, very common problem with the crummydoore.
Make sure you bleed the cooling system properly or you will definitely have more overheating problems than you did before!
_Torrie_Man_
Posted 31 March 2009 - 06:44 PM
_efiXP_
Posted 01 April 2009 - 06:39 AM
replaced the temp sender ,thermostat and radiator cap
$137 incl labour and all fixed
