Fitting VN V8 Calipers to R31 diff
_Racelx_
Posted 01 April 2009 - 01:09 PM
Posted 01 April 2009 - 01:27 PM
Axle flanges seem to sit at about the same length outside the housing too, however the Commodore disk is offset further inward due to the internal drum handbrake, which I think would foul on the shock. Don't most of the guys who use Commodore diffs mount the brakes at the front?
_Torrie_Man_
Posted 01 April 2009 - 10:14 PM
_Racelx_
Posted 02 April 2009 - 06:54 AM
Posted 02 April 2009 - 07:00 AM
- one pad backer has a little lug to locate in the caliper piston so that the piston doesn't turn against the pad due to the internal park brake design
- they have less friction material on a new pad as the caliper isn't quite as wide
Posted 23 March 2012 - 06:18 PM
Posted 23 March 2012 - 07:55 PM
Posted 30 July 2012 - 07:39 PM
I just want to bump this thread up to squeeze out some more info. As I said I have a R31 Skyline diff with no brakes at all. I can't seem to find any skyline discs/rotors anywhere, but VN stuff is easier to get hold of. How much effort/modifying does it take to fit any holden discs/calipers to the skyline housing?
Thanks.
Posted 30 July 2012 - 09:01 PM
Showing where the axle bolts too
And maybe some measurements... so we can see if the pattern is the same as commodore
_evil UC hatch_
Posted 30 July 2012 - 09:08 PM
I had one of all 3 laying about my garage 3 years ago and was looking at ditching the R31 brakes for the commodore one, mainly due to the stud pattern difference.
thats as far as I got with the R31 diff, it will end up in a Torana one day...
Posted 31 July 2012 - 08:31 AM
There are two things I would be concerned about:
1) the VN disc has a deeper offset due to the internal drum park brake which will sit the caliper further inboard, I wonder if it would clear the shock
2) I don't know if the wheel mounting flange of the R31 axle has the right offset/distance from the bearing to suit the VN brakes, i.e. you might end up with the rotor not sitting centre in the caliper (if this is an issue perhaps a spacer could fix it)
Given the price of the VN brakes (next to nothing or even free) if it were me I'd get hold of some and test fit to find out.
Posted 01 August 2012 - 03:36 PM
As above the axle tube flange is identical and the VN stuff will bolt on to that. The pic I posted is the original R31 angle, the relation of the caliper to the mounting flange is the same as Commodore, just the tube end is rotated however many degrees that is to bring the caliper up the that position.
Well over here all the VN brakes I can find are pretty expensive, so not really practicle buying some to check. That is an less i get a stuffed set from wreckers just for a test fit. However it sounds like with the hassle of them being further inboard and the different type of handbrake I should stick to stock R31 brakes. The only thing is I have been looking for a long time and have yet to find any that they don't want a fortune for.
Posted 01 August 2012 - 04:42 PM
edit: the above refers to Commodore brakes. I have a pair of original R31 rotors here somewhere (still 4 stud but I think they were still reasonable), you can have them for postage if they are any use
Edited by 76lxhatch, 01 August 2012 - 04:44 PM.
Posted 01 August 2012 - 07:58 PM
_CHOPPER_
Posted 01 August 2012 - 08:06 PM
Posted 01 August 2012 - 08:13 PM
Posted 01 August 2012 - 08:43 PM
So widen your search beyond "VN"
Surely the countryside is littered with shitboxes over there just like it is here ?
_CHOPPER_
Posted 02 August 2012 - 11:41 AM
Theres heaps of room to redrill, i may have done it
Then I stand corrected!
Posted 02 August 2012 - 04:53 PM
Commodore brakes are essentially the same from VB-VS with beam axle
Things are getting cleaned up these days. the recycling guys are travelling around the country side in trucks with hiabs and offering people cash to let them take away their wrecks!
Anyway I'll try the R231 setup first so if anyone knows of any calipers over there for cheap can you let me know..................
Posted 02 August 2012 - 07:54 PM
Be cheaper for us to find and send you some Commodore ones
