M21 holden gearbox .
23 replies to this topic
#1 nzxu1
nzxu1
  • 276 posts
Posted 03 April 2009 - 11:51 AM
Probably a simple explanation here , but what's the difference between the 2 clusters available for an M21 gearbox , ie :
the * 497 * cluster and the * 599 * cluster and do they need their own specific input gear for each one ? .
l've removed the toploader gearbox conversion from my L34 and l want to replace it with an M21 , not only for originality but also to fix all the holes that some mongrel has chopped into the tunnel with a very blunt cold chisel to fit the toploader box . :angry:
Clusters and inputs are available new , but l want to make SURE that l order the right bits .
Thanks for any help here :)
#2 yel327
  • 13,717 posts
Posted 03 April 2009 - 01:50 PM
There is only 2 x V8 M21 clusters:
2813497 and 9939484.
The first is the standard V8 M21 cluster (2.54:1 1st), the other is the L34 M21 homologation gear set (2.32:1 1st). Both of these were also used in homologated gear ratio sets for LJ XU-1.
These both use a unique input shaft which is noot interchangeable between the two.
There is no xxxx599 cluster in an Aussie 4spd (I think you've just mis-typed 5 instead of 8), but there is a 2823899 M20 cluster which is the standard cluster for an XU-1. These can be put into a V8 M21 box but as they are an M20 cluster you have to use an M20 3rd gear with them. This ends up giving you a V8 box with a ratio set which was also homologated for L34. 1st gear ends up the same as normal M21 but 3rd is 1.25:1. In the end it's exactly like an XU-1 box but with a V8 length input shaft.
Hope this helps.
I listed all the part numbers on my website: http://www.monaropar.../aussie4spd.htm
#3 _SableMet7/73_
_SableMet7/73_
Posted 03 April 2009 - 11:01 PM
Gday, hope you dont mind me stealing your thread but
had a look on your site yel327 but couldnt find an answer
to a question I've got about my XU1s 899 box.
The serial number stamped into my casing is T 501_ _ _
& was wondering if the T prefix had anything to do with
the 308s QT or T engine prefix.
As werent the XU1 boxes just M21s modified to suit a
202 with the particular 544 input shaft & an alternate
cluster, 899, to suit 3rd gear.
Jono
#4 nzxu1
nzxu1
  • 276 posts
Posted 04 April 2009 - 04:46 AM
Thanks yel327 , indeed l did make a typo with the 599 instead of an 899 . The info you've given me is just what l was looking for thanks .......great website you have too . :) l know that new 2.54 clusters and inputs are available new aftermarket but what about the 2.32 ones ? .
Don't mind the thread hijacking at all sable either , we should be all here to help :) .....though you wouldn't think so looking at what's going on with some other threads on this torana site at the moment .
Hope this helps.
#5 yel327
  • 13,717 posts
Posted 04 April 2009 - 08:23 AM
I'll answer the last post first:
I know of no aftermarket source for the 2.32 input shafts or clusters for L34 or XU-1. The 6cyl version of the input shaft never even got a GM-H part number. I've never seen any of the 3 parts in the flesh, and (don't quote me) I think no L34 or XU-1 ever left the factory with one of these boxes (I'd love to know if one did). Curiously though the cluster and V8 input shaft are listed in the LH parts catalogue as L34 but I think that is simply there to demonstrate they were available. I have a few NOS M21 input shafts I bought a while back but as you say clusters and XU-1 input shafts are only aftermarket now.
Sable, not sure of the T. In Chev cast parts they have the plant code on them like T for Tonnawanda, K for McKinnon, F for Flint etc but I doubt that's the meaning of the T. I also doubt it has anything to do with T meaning 308HC as the M21 V8 box was optional on some 253's as well. Dr Terry might have a better idea on this. Note though that the standard XU-1 box is actually an M20 box with a different cluster and input shaft. For some reason Holden sometimes named their M21 box as "heavy duty" box, but the only part that could possibly be any heavier duty than the M20 and M22 was reverse as it has a unique part number for the M21 (yet they look the same and are interchangeable?). As the XU-1 box uses the same reverse gear part number as the regular M20 it cannot be an M21. I also normally refer to the box by it's 3rd gear, and as the XU-1 box uses an M20 3rd gear I call it M20. Although this isn't strictly correct either, it is definitely not an M21 otherwise later XU-1's would have M21 stamped on the BODY tag. The correct name is probably just XU-1 4spd as it was part of the XU-1 option on a GTR. Holden did homologate an M21 for LJ XU-1 use which may well have been a V8 M21 box using the XU-1 input shaft but if you look at the CAMS bulletin on page 192 of Fiv's book it lists the M21 3rd gear but no different reverse gear, although this could easily have been overlooked. I'd also really love to see an original XU-1 with M21 on the BODY plate as this could mean that someone optioned one of the optional ratio sets in it. Anyone seen one?
#6 _SableMet7/73_
_SableMet7/73_
Posted 04 April 2009 - 05:51 PM
Cheers,
Guess it was just that paragraph in th LJ factory supplement
confusing me saying XU1 4 speeds were same as fitted to 308 V8
models except for 3rd gear & shorter input shaft for 6 cylinder thats
also repeated in Fivs book.
VIN disc options also just list 4 Spd manual (with XU1).
But think I've seen something, somewhere that said M21 with XU. PO-
production option, but treat that as heresay till I find it again.
Also on the T prefix thing, I've found a 496 cluster M20 in the shed also
with the T prefix so cant be related to 308 engine prefix.
Ended up coming across a spare 544 input & plan on putting it into a M21
so guess I'll end up with a box with the other ratios as well.
Thanx again
Jono
#7 yel327
  • 13,717 posts
Posted 04 April 2009 - 09:16 PM
No worries. Just make sure you get the right input shaft cover for the 544 shaft and an M20 3rd gear. The aftermarket XU-1 inputs are probably a better bet as they have the later neoprene type seal.
If you ever find that info mentioning the M21 option for the XU-1 let me know. I've only ever seen it in Fiv's book on the CAMS documentation.
#8 _SableMet7/73_
_SableMet7/73_
Posted 04 April 2009 - 11:11 PM
I was just going to go with the 1.38:1 3rd in the M21 & swap the input
only.
Is that the 9685 or the 6171 input cover?
Gone thru a heap of old papers,books & stuff as I'm getting rid of a
heap of old bike mags so might turn up & I'll let you know.
#9 yel327
  • 13,717 posts
Posted 05 April 2009 - 07:35 AM
7439685 suits the early slinger/scroll type oil seal. There were later XU-1 input shafts with neoprene seals on them (part numbers 2825927 and 9930927) which is what the aftermarket ones are copied from. You use 9930909 with either of these.
#10 _SableMet7/73_
_SableMet7/73_
Posted 05 April 2009 - 05:37 PM
Hi yel327,
Was looking at that M20(923Inp/496Clu) I've got in
the shed & its got a Clutch Shaft cover with part number
9930912, its got a neoprene seal in it, but dosnt seem to
be on your list. Its a consectutive part number with the
neoprene covers on your list but can you tell me anything
about it?
#11 yel327
  • 13,717 posts
Posted 05 April 2009 - 09:30 PM
I'll look into it. It might just be a later revision.
#12 nzxu1
nzxu1
  • 276 posts
Posted 05 April 2009 - 10:55 PM
l've just been having a look at a copy of the supplementary factory spec sheet for SLR 5000 L34 option printed in july 1974 and it lists the gear ratios as 1st 2.54 , 2nd 1.85 , 3rd 1.38 and 4th 1.0 with reverse @ 2.54 . No mention of an alternative ratio option of 2.32 1st gear .
#13 _SableMet7/73_
_SableMet7/73_
Posted 05 April 2009 - 11:10 PM
Thanx mate, tried checking the cast date but its very hard to read
All I can tell you is it came with a shifter that would suit LH probly LX
Got it cheap & really only wanted the shifter, as was in good nick, to
renew my XU1s shifter by swapping the levers.
Would the stencilled lettering tell you anything?
Jono
#14 _SableMet7/73_
_SableMet7/73_
Posted 05 April 2009 - 11:36 PM
I know little of L34s but just found a copy of the CAMS paperwork for the
alternate ratio trans.
CAMS recognition # H2- 4
Ammendment # 11/8E
Transmission constant gear 24 in leu of 25
resultant ratios:
1. 2.32:1
2. 1.67:1
3. 1.26:1
4. 1.00:1
Rev. 2.32:1
Date ammendment is valid from 1st October 1974
Also had a few other ammendments like rear brake cylinder bore,different
oil pump & shaft, water pump assembly, rocker covers & filler caps etc
Can scan it tomorrow for you if you like or if you've got Fiv's other book History
Of The Holden V8 its on page 291.
J
#15 yel327
  • 13,717 posts
Posted 06 April 2009 - 06:19 AM
That's interesting. The gear ratios listed differ from those quoted for the XU-1 (see Fiv's book, page 192 with the amendment on page 196 for 3rd gear). When you work out the formulas given the XU-1 quoted ratios are correct. Does the L34 bulletin list the teeth counts?
#16 nzxu1
nzxu1
  • 276 posts
Posted 06 April 2009 - 09:05 AM
Unfortunately no teeth counts are given , just the ratios . It's on a copy of a 9 page bulletin outlining the differences between a standard SLR5000 and an L34 headed " Supplement S/LR 5000 Option L34 "
#17 _SableMet7/73_
_SableMet7/73_
Posted 06 April 2009 - 02:21 PM
Regarding the clutch shaft cover, if its any help, that M20 I got has
AS stencilled on the casing.
I scanned those CAMS documents for you & theres also a Aust Motor
Manual test report on HDTs L34 dated October 74 that lists the 2 trans
available.
Jono
#18 yel327
  • 13,717 posts
Posted 06 April 2009 - 07:22 PM
Notice how they all quote different ratios. The Motor one is correct and the centre CAMS document lists the teeth counts. This is the identical info to what is on the XU-1 CAMS paperwork, which also has 1st gear as 2.32. When you work it out for yourself you get:
2.30:1
1.65:1
1.25:1
1:1
So i'm not sure where the info on the other two comes from?
Notice also that the normal M20 ratio set (3.05:1 1st) is also homologated for the L34. This is probably the only application of M20 ratios behind a 308.
Edited by yel327, 06 April 2009 - 07:24 PM.
#19 yel327
  • 13,717 posts
Posted 06 April 2009 - 09:01 PM
Hi yel327,
about it?
I couldn't find it in any parts book. Might just be one of those pesky casting numbers.
#20 _SableMet7/73_
_SableMet7/73_
Posted 06 April 2009 - 11:23 PM
Yeah strange but at the top of the middle 1 theres 202 in brackets.
Also found the 2 M21 box's listed in the LX paperwork along with
2 different ratio T10s- 2.43 & a 2.64 1st.
#21 nzxu1
nzxu1
  • 276 posts
Posted 07 April 2009 - 05:19 AM
l already have several old M20 boxes and was hoping to use the bits from these to convert to a V8 M21 . l have a brand new 497 cluster already and was hoping to be able to get away with buying just a new 9930924 V8 input gear to do the conversion , but from the info provided it would seem that l will also need to find a 2813492 3rd speed gear and a 2813500 1st speed reverse gear also to complete the conversion . :cry:
#22 yel327
  • 13,717 posts
Posted 07 April 2009 - 09:53 AM
I reckon you only need the 3rd gear. I cannot see any physical difference between M20/M22 and M21 reverse gear although they are different part numbers. M21 3rd gears aren't all that expensive and don't really wear out either. You could always hold onto the M21 cluster and buy one of the new repro XU-1 clusters along with a new V8 M21 input shaft. Then you can use the whole M20 box and fit the XU-1 cluster and M21 input shaft. Only ratio difference is a taller 3rd gear.
#23 _HQ SS_
_HQ SS_
Posted 07 April 2009 - 07:51 PM
Jono
Jono.
I have collected a few date codes and 3 spd and 4spd serial numbers and they seem to all have The T on them and the serial numbers are consecutive like the engine numbers.
So I suspect that T may just mean Transmission or something along those lines.
I also suspect that the number sequence began at the beginning of the aussie 3 spd and 4 speed box's as the earliest number I have at the moment
is a F21 21st 6th 1971 V8 3 spd box with a serial number of T 280987.
The latest I have is on a 25C1 21st 3rd 1981 4spd box with a serial number of T926522.
I would be interested in any date code and serial numbers anyone may have and want to give me to add to the list I am compiling at the moment.
Cheers Paul.
#24 _ljharbsy_
_ljharbsy_
Posted 11 April 2009 - 11:45 PM
Gents,
I have been building these buggers for 20 years, there is an M20 M21 M22(usually 1 tonner ratios and use some three speed gears) and they made a special for bathurst which consists of 899 cluster M20 1st, 2nd, and 3rd gear while using the M21 4th gear ratios, hope this helps with ratio numbers. :clap:
