Edelbrock Performer Manifold - Vacuum port block off.
_Big T_
Posted 05 May 2009 - 05:24 PM
The 308 Edelbrock Performer Manifold has two vacuum ports tapped into the intake runners, one at the front (not needed) and one at the back (brake booster vacuum). I need to block the front one off but I dont have any bolts or fittings at home that fit.
Does anyone know what size bolt will do the trick or is there something else I can use?
Cheers,
T
Posted 05 May 2009 - 07:52 PM
Howdy,
Cheers,
T
It will be a tapered gas thread, either 1/4 or 3/8 NPT. You should be able to get a plug from any auto parts outlet.
_Allports_
Posted 05 May 2009 - 08:32 PM
Posted 05 May 2009 - 08:35 PM
_Monkey_
Posted 05 May 2009 - 11:13 PM
_Big T_
Posted 06 May 2009 - 11:48 AM
Monkey - Long time mate !! I've got a Torker on it now. In fact its better than a Torker, its a MaxiTork !! It just doesnt have the lower RPM torque that is more suited to the street though, hence the swap.
Dude at Autobarn reckons I need a 1/4 UNC. Glad I asked here for some proper advice. I tried few fittings I have at home (tappered brass single outlet off a 202 manifold) and they fit but are obviously no good for a block off though.
