I would like to think that I can just plumb it into my existing line (I want to put it under the car at the rear, near the diff, where the floor pan starts curling up for the diff, so Plodd won't see it), but I've been told by the brake shop in earlier (unrelated) discussions that it's extremely hard to flare old steel tubes without them cracking. Is this a feasable concern?
My other question is: Does anyone know of a good hand held flaring tool that will do 3/16" tubing, and will it work on old tubing? My mate that helped me with the pipework on my diff had a "Bluepoint" hand held jobby that he reckoned worked perfectly (apparently on every size other than 3/16") as he wasn't happy with the way it performed on the day and I had one fitting leak so I had to make another pipe and get it flared at the brake shop on their bench mounted machine.
I'm all for doing things myself and on the cheap, but if it means redoing things and having to spend more money doing it, then I'd rather just pay up front for it, however, I'd really prefer not to have to replace the whole tube if I don't have to.
