LSD Test
9 replies to this topic
#1 _redbill_
_redbill_
Posted 07 June 2009 - 02:13 PM
If I release the clutch and both rear wheels spin/skid together is this a good indication of the vehicle having a LSD. I don't really want to pull the diff centre out of the vehicle. Are there other ways of checking for LSD while the centre is intack.
#2 _Bomber Watson_
Posted 07 June 2009 - 02:22 PM
Jack the back of the car up so the wheels are in the air.
Gearbox in neutral, turn one wheel. If the wheel on the ot her side spins in the opposite direction you have a single legger. If it spins the same way you have an LSD or a locker.
Then put the car in gear and repeat, if you cant turn the wheels you either have a very very tight LSD or a locker, if its very firm but one wheel turns one way and the other turns the ot her, you have an LSD.
A flogged out single legger will often spin twins when you step the clutch, so not really a good way to tell.
My box Torana with a ban-go single legger pulls twins in the gravel :D
#3 TerrA LX
Posted 07 June 2009 - 02:31 PM
No. A locked diff, LSD, mini/full spool and a single spinner are all capable of spinning both wheels.
Also a worn LSD may only spin one wheel.
#4 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 07 June 2009 - 02:38 PM
http://www.fugly.com.../LSD_tests.html
#5 _redbill_
_redbill_
Posted 08 June 2009 - 10:20 AM
Hi,
Jacked the car up under the diff.
Put the car in neutral, spun one wheel forward the other side spun the other way.
Did the same when I spun the wheel on the other side.
Put the car in gear, did the exact same as it did in neutral.
Any idea what diff centre?
#6 _Bomber Watson_
Posted 08 June 2009 - 10:24 AM
Open.
#7 _Adam Perth_
_Adam Perth_
Posted 10 June 2009 - 11:30 PM
i read in a holden manual years ago that a new LSD should be 68 pound before slip.
test with a torque wrench..
#8 _lj304_
_lj304_
Posted 11 June 2009 - 11:32 AM
That will only happen if the diff is completely locked with a spool or weld. most lsd's have a clutch system so the wont be lsd unless there is enough power put through them. my new ss spins opposite and theyre lsd.
[quote name='Bomber Watson' date='Jun 7 2009, 02:22 PM' post='406431']
#9 76lxhatch
  • 7,215 posts
Posted 11 June 2009 - 01:18 PM
Sorry lj304 but any LSD (except perhaps a Hydratrak/viscous) will spin both wheels the same direction when you spin one, sounds like you have an open diff too
#10 _mumstaxi_
_mumstaxi_
Posted 11 June 2009 - 01:22 PM
In the clutch style LSD , it is just that, "Limited Slip Diff", the left and right wheels/axels are essetially locked/held together in rotation by sping loaded clutches, until the forces to rotate them at different speeds overcome the clamping pressure of the clutches (when you turn a corner) , thus allowing/forcing a certain amount of "slip" upon the clutches.
This type of LSD (in good condition) will always spin both wheels in the same direction when un-loaded (car off the ground) :spoton:
Not sure what model ss you have (but you could have a Viscous type LSD) and yes some diff centres like Torsen LSDs "will" spin in oposite directions when both wheels are off the ground but the clutch and cone style LSDs (what these guys are talking about in the old holdens) should turn both in the same direction without load (both wheels off the ground)
MT
