popping (backfire) out exhaust
14 replies to this topic
#1 _LJ355_
_LJ355_
Posted 09 June 2009 - 08:09 PM
Guys ive encountered a problem with the new motor
Starts idles fine but as it gets warm it starts to pop (backfire) out the exhaust
Tried another carb still does it although cant get the fuel pressure lower than 9psi
Double checked rocker clearance as per camtechs specs .016 intake .018 exhaust
No vacuum leaks anywhere
Tried timing doesnt make much difference currently set at 20deg
combo is
355
VN heads
Camtech solid roller 252/257 @.050
10.5.1 comp
750 bg tp single plane
MSD pro billet 6al blaster 2 coil
Any ideas ?
#2 LXCHEV
LXCHEV
  • 3,649 posts
  • Car:'76 LX - 383 Chev
Posted 09 June 2009 - 08:15 PM
Mine pops when I foul plugs. You have extremely high fuel pressure for a carby. Why can't you get it any lower? What do the plugs look like?
Weird that it idles fine though, if it was fouling plugs, it wouldn't like idling.... good luck finding the problem...
#3 _LJ355_
_LJ355_
Posted 09 June 2009 - 08:22 PM
Ive got this fuel rail that has shims to adjust pressure we have tried it with and without them it doesnt make any difference il post a pic to show
Plugs are light brown although 7 and 4 a little darker
Forgot to add it doesnt miss constantly it does it sort of now and then
#4 _LJ355_
_LJ355_
Posted 09 June 2009 - 08:26 PM
Anyone got or used one of these fuel rails ?
#5 _Torana308_
_Torana308_
Posted 09 June 2009 - 08:46 PM
Sounds like it is leaking fuel either out the vent tubes on the carby or the boosters in the carby, Run it with the air cleaner off and see if you can see fuel spewing into the carby. I am guessing it will be due to fuel pressure if it is.
9 Psi is alot of fuel pressure. Is it possible to borrow a holley reg and drop the pressure and see how it goes?
Other than that is TDC on the balancer definately TDC, Mine is 4 degrees out from new, and my mate was having similar problems until we replaced the balancer and found the real TDC
#6 _ass308_
_ass308_
Posted 09 June 2009 - 08:49 PM
could rocker lash cause poping ?
#7 _Squarepants_
_Squarepants_
Posted 09 June 2009 - 08:57 PM
Fuel pressure is too high, get a regulator.
#8 _LJ355_
_LJ355_
Going to try and get the fuel pressure down have had it running with the filter off havent noticed fuel spilling in but will check that
Has a romac balancer TDC is right on
Starting to think maybe back the rockers off a little ?
Just weird how its fine for a minute or so then gets warm then does it
#9 _evilsim_
_evilsim_
Posted 09 June 2009 - 08:59 PM
Sounds similar to what my car is doing. Too much fuel going into throttle body. I agree with T308 drop the pressure.
Simmo
#10 _LJ355_
_LJ355_
Posted 09 June 2009 - 09:01 PM
Yeah i think il start with the pressure problem and go from there
Thanks guys
#11 _why-psi_
_why-psi_
Posted 09 June 2009 - 10:25 PM
maybe your return line could be resrtictive, try the -8 as a supply and -10 as a return and see if that helps?
#12 _1QUICK LJ_
_1QUICK LJ_
sounds like youve got two plug leads around the wrong way. double check em mate
#13 _LJ355_
_LJ355_
Posted 10 June 2009 - 05:37 PM
Quicklj was right 2 leads around wrong way :fool:
#14 _sloshy_
_sloshy_
Posted 13 June 2009 - 01:30 PM
Its always the simplest things.
#15 _LJ355_
_LJ355_
Posted 14 June 2009 - 04:45 PM
Yeah your not wrong glad thats all it was :o
