no engine numbers on 308 options???
_beergut_
Posted 14 June 2009 - 07:23 PM
what's the best way to find out
bearing in mind i don't have access to the rego papers or chassis numbers/former owners???
and the project car it's going into has to be rego'd
_nial8r_
Posted 14 June 2009 - 08:35 PM
Posted 15 June 2009 - 06:02 AM
Posted 15 June 2009 - 06:44 AM
Posted 15 June 2009 - 12:40 PM
Bit sus I think.
_Courage_
Posted 15 June 2009 - 04:29 PM
Why you bought an engine missing its numbers I'll never understand, surely you want to put this into a car at some stage and drive it?
I don't think an xray will work because due to metal causing a black out. When stamped the metal should retain a 'crush memory' and I believe that heat may be able to reveal this.. even for a few mins (Blow torch)
My advice is to contact your states stolen car squad, they will want to see you, the egine and the person details of who you bought the engine off.
Posted 15 June 2009 - 04:38 PM
If the engine number has gone as a result of machining operations, ie decking the block, I would wonder how much has been taken off, and whether it will be any good for your intended purpose.
If it has been decked for a special project, you may have dramas with piston and or valve clearance.
Have heard that acid may help show numbers, but not sure which type and how reliable it would be.
_sshatch355_
Posted 15 June 2009 - 07:13 PM
Mods - This is heading down a dangerous path, we all know why some engines are missing there numbers and speaking for myself i don't want this type of stuff on a forum I frequent due to probity and ethical issues.
while i understand the angle you are coming from you have got to remember the holden v8 engines are known for loosing there numbers when machined/decked however if its been ground off by other means that would be a different issue.
i have just had 2 355 decked to zero deck height and lost the numbers on both of them.
i have taken a few over the pits and had no trouble with getting them passed here in sa
jm2c
_darrenmark1_
Posted 15 June 2009 - 07:19 PM
Was the car a v8 before?
Did you buy the engine of someone else?
Why has the car got no chasis Number?
Has it got the tags?(The chasis number should be on there) if it has they should be able to look it up for you!
Daz
_Courage_
Posted 15 June 2009 - 07:29 PM
"i have a 308 that's been decked and i've lost my engine number"
And
"bearing in mind i don't have access to the rego papers or chassis numbers/former owners???"
The first implies he knew the number at some stage but they have been lost since.. we shall assume due to no nefarious reasons.
The second line implies that this engine came out of a car that he knew about, but can not make contact with them to get tracking details.
Obvious if he could do either of these then he would get the numbers stamped easy enough.
I am trying to think of any situations where you would be missing the numbers and not able to get data on the original car, owner, chassis, rego.
I keep coming back to that this block is out of a stolen car.. unless there is some other way this came about?
sshatch355 Hi mate, Here is VIC if your car gets a once over they will check the block number against your vic road record, if you don't have it stamped it is considered a stolen engine until you can prove otherwise. Is SA different in that regards?
_rocket_
Posted 15 June 2009 - 07:41 PM
_sshatch355_
Posted 15 June 2009 - 07:57 PM
[/quote]
over here restamping even with the original number is a big no no so its better to leave it blank and have the recipts for the engine work to show why the number has gone.
as you probably know we only get inspected over here when we get defected you dont even need an inspection for most v8 conversions as its just a engine number change and they want to know it has front discs.
the only problem with the that system is theres so many bombs/rust buckets on the road
so how do you guys go about proving its not stolen???
it would be so much easier if the vehicle laws were the same australia wide
_darrenmark1_
Posted 15 June 2009 - 08:24 PM
_beergut_
Posted 16 June 2009 - 07:32 PM
brought off a wrecker mate so its all legit (hes above board)
heard bout the decking issues that.s y i asked will try the heat thing when i get a chance
thanks all
Posted 16 June 2009 - 09:42 PM
_beergut_
Posted 17 June 2009 - 09:04 PM
some numbers there but still not clear and defently not clear enough for rego
got some redex rust convertor in the shed and some moflo (acid based)
should i give these a go?
or would the blowtorch idea be a better bet?
oh and the letter i can c is x what could come b4 it?
all i know at the mo is it came out of a vl commodore
but its not the orginial motor
