No oil going to head
13 replies to this topic
#1 GTR-1
GTR-1
  • 351 posts
  • Car:Phantom Grey 7/71 LC GTR.
Posted 19 June 2009 - 04:49 AM
I recently bought a 72 XU-1
The engine (202 red motor) had been reconditioned in 1991 and then taken off the road in 1999 and has done less than 1000 miles, so it's been sitting unused for 10 years
I've managed to get the engine running to where it will sit there and idle. There is an oil pressure reading on the guage but no oil is going to the head.
Any ideas on what I should be checking?
#2 rodomo
  • 18,042 posts
Posted 19 June 2009 - 09:03 AM
How long did you run it?
#3 GTR-1
GTR-1
  • 351 posts
Posted 19 June 2009 - 10:14 AM
I've let it sit there idiling for a couple of min at a time. Long enough for the oil to make it upto the head (I think) I'm a bit wary about running it too long just in case something is blocked and the bearings arn't getting any oil. I don't want to ruin the engine.
#4 rodomo
  • 18,042 posts
Posted 19 June 2009 - 10:23 AM
Does it rattle like noisy lifters?
#5 GTR-1
GTR-1
  • 351 posts
Posted 19 June 2009 - 02:11 PM
Haven't really listened out for noisy lifters due to the rockers being a little bit noisy and the engine idiling a bit high as I haven't set the carbs up yet.
#6 _2runa_
_2runa_
Posted 19 June 2009 - 02:41 PM
The followers have a habit of bleeding when left for lengthy periods. If you've got oil pressure remove the rocker cover , grab an oil can and lube the rocker gear, start the eng. and run it at 1200-1400, and continue to lube the rockers slowly the process can take some time, i've had the mongrols take upto an hour. I would also change your oil filter as well . Let us know how you go.
#7 _Adam Perth_
_Adam Perth_
Posted 19 June 2009 - 05:07 PM
chuck a litre over the top and drain 1 litre out.
it does take time, 5-10 minutes to get there.
there is generally a high variabilty of oil delivery up thru the 12 push rods
#8 GTR-1
GTR-1
  • 351 posts
Posted 20 June 2009 - 07:06 AM
Will have another crack at it over the weekend.
I'm just worried about the bearings not surviving without the oil they need. If the oil isn't making it up the pushrods is the oil making it to the bearings?
#9 _82911_
_82911_
Posted 20 June 2009 - 07:26 AM
All the bearings are pressure fed. So if you have oil pressure, they have oil.
#10 tonys2r
tonys2r
  • 200 posts
  • Car:LC GTR XU1
Posted 20 June 2009 - 09:42 AM
i had the same problem with a car i had , couldn't get oil pressure because the engine was rebuilded by a person that put a standand oil pick up in because he didn't know xu1s have a longer oil pick up. took car to the experts problem was fix.
#11 frash da bucket
frash da bucket
  • 1,890 posts
Posted 20 June 2009 - 10:06 AM
And also check your push rods,make sure they aren't blocked,and check the top of the liffters,are free from any bulid up.
cheers.
#12 _2runa_
_2runa_
Posted 20 June 2009 - 10:48 AM
You need to make sure you have oil pressure first and stop if you dont. the top of the motor is feed via the push rods so if you have good oil pressure it should be an indication that the bearings are OK.
Most of the engines that I rebuild I prelube them by this method.
You can do this using an old gas bottle and put a pressure relief valve / oil feed down through the centre and an air fitting, the unit is connected via a hose to an oil port set at 30+psi til im happy i have oil.
If anyone follows this method make sure you check you oil level before you start your eng.
Try oiling the rockers if you have oil pressure.....just continue doing it til your happy that you have oil ......and if it doesn't work I guess we will all have mail :cry:
All jokes aside .....Follow the methods and it should be OK
#13 GTR-1
GTR-1
  • 351 posts
Posted 21 June 2009 - 03:49 PM
All good news from my end.
Ended up pulling out the lifters and push rods and filling them with fresh clean oil, started her up and not so long after oil was making its way to the head. Did all the necessaries to make her run right.
Dropped it down on its wheels and took it for a spin round the block, needs little adjustments on the clutch and carbs, other than that it's seems to be all good.
This is the car in Question: A Chateau Mauve 9/72 LJ GTR XU-1
Attached File  P1010119.JPG   181.79K   23 downloads
#14 _Drag lc_
_Drag lc_
Posted 21 June 2009 - 03:56 PM
Hey that Looks nice mate.
Cheers hayden
