locka type diffs
Posted 25 June 2009 - 05:47 PM
Posted 25 June 2009 - 06:34 PM
_TORANGA_
Posted 25 June 2009 - 06:39 PM
Posted 25 June 2009 - 07:06 PM
im doing hillclimbs and it doesnt like turning corners much
ive looked into the 4 pin lsd conv,they didnt recomend it
_Phantom10_
Posted 25 June 2009 - 07:07 PM
Posted 25 June 2009 - 07:15 PM
_Phantom10_
Posted 25 June 2009 - 07:18 PM
http://www.eaton.com...ocker/index.htm
Posted 25 June 2009 - 08:48 PM
Posted 25 June 2009 - 08:53 PM
its the big salsibury
steve
Posted 25 June 2009 - 09:10 PM
I'm running a 4 pinion VK BW conversion in the Targa Hatch Steve, works really well.
If you go to a Harrop Detroit locker and want 31 splines, i've got 2 brand new axles here for you.
Welby
Posted 25 June 2009 - 09:24 PM
how much rwhp u got there welby,if u dont mind
ive got 350 an they didnt recomend the 4 pin conversion(the ebay mob anyway)
steve
Posted 25 June 2009 - 11:16 PM
Same problem I saw in the B/W diff Grina..hence the Lokka in it...best of luck, don't know of any Lockers for big salisbury but there might beone out there. failing that..go with the LSD tightened right up in my opinion.
Posted 26 June 2009 - 12:03 AM
I thought WA Diff Centre was looking into fitting a Lokka to the big Salisbury, did you hear anything?
Posted 26 June 2009 - 03:46 PM
Posted 26 June 2009 - 04:28 PM
How does that new Salisbury 4 pinion conversion work? If it uses BW parts maybe the Lokka would fit?I thought WA Diff Centre was looking into fitting a Lokka to the big Salisbury, did you hear anything?
_Squarepants_
Posted 26 June 2009 - 04:39 PM
More horse power and steer with the throttleits got a mini spool in it now
Posted 26 June 2009 - 09:48 PM
Uses salisbury crown and pinion but B/W LSD guts, quite ingenious actually and might be my next diff.
Don't see why a lokka wouldn't fit.
Posted 26 June 2009 - 11:18 PM
'bout the same Steve, 435 at the fly.
Andy they wanted to adapt a 4wd unit, but same as Harrop, big $$. In the end, i would not be getting my $ worth for the event we enter.
It uses salisbury crown and pinion from the VK, but B/W internals, we ran it last year and it worked really well.
Welby
Posted 27 June 2009 - 08:59 AM
Hmm the Lokka only fits in open centres, not LSD. But if they do an open version too then I'd say this sounds promising, and I bet its still cheaper than a Detroit locker!Uses salisbury crown and pinion but B/W LSD guts, quite ingenious actually and might be my next diff.
#21
Posted 04 July 2009 - 02:21 PM
suit the early Holden 10 bolt Salisbury diff.
These unit are identical in specification and appearance to the
Commodore units we manufacture.
Alternatively we can remanufacture a Detroit Locker as were supplied
back in the Grp C period.
The Truetrac will be ~$1,750.00 inc GST and a Detroit Locker will be
~$2,500.00 inc GST.
thats an email i got from harrop
steve
#22
Posted 04 July 2009 - 03:08 PM
I will add that the detroit locka needs some axles as well. that will up the cost.
Did i mention i have 2 brand new 31 spline axles to suit ?
Looking for a new home at the right rate....
#23
Posted 04 July 2009 - 06:03 PM
then i will get back to the arse end
steve
#24
_outer control_
Posted 04 July 2009 - 09:35 PM
Try keith croft in sydney he will make you a brand new detroit locker with billet centrewats out there i can use, steve
for quite a reasonable price 0245736418
#25
Posted 04 July 2009 - 09:55 PM
