Windscreen sealant clean up
7 replies to this topic
#1 _TRRANA_
_TRRANA_
Posted 30 July 2009 - 10:22 PM
Gday all.
About removing windscreen goo....
I need something strong because the sealant is hard and well stuck...
I obviously dont want to affect the paint, rubber, glass and interior if a splash goes here and there....
What does everyone recommend is the best? ....a wax and grease remover like Acetone? Prepsol? or Turps etc?
Dorzy
#2 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 30 July 2009 - 10:30 PM
turps is the go...and a razor blade
#3 _threeblindmice_
_threeblindmice_
Posted 30 July 2009 - 11:26 PM
Just had a windscreen put in , he used Prepsol to clean up .
#4 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 30 July 2009 - 11:33 PM
Don't use Acetone, way too powerful.
#5 _Bomber Watson_
Posted 31 July 2009 - 07:40 PM
If its acrylic then turps or prepsol, if its 2k then both of those and a bit of thinners carefully for the stubborn bits.
#6 _SS Hatchback_
_SS Hatchback_
Posted 01 September 2009 - 09:36 PM
Same just had one fitted and i used prepsol or sometimes called wax and grease remover.
#7 _BATHURST-32D_
_BATHURST-32D_
Posted 02 September 2009 - 06:51 AM
because its hard you will need to use a razor to take the top off then you can finish off with the prepsol.
cheers gong
#8 _beergut_
_beergut_
Posted 02 September 2009 - 11:50 PM
cool i'll try it on my fraud daily then redo to fix the leaks (swears under breath)
btw prepsol is just a trade name for wax and grease remover for anyone interested
