Spark plug selection question?
11 replies to this topic
#1 rodomo
  • 18,050 posts
Posted 31 July 2009 - 12:22 AM
I'm chasing the correct plugs to fit to a bit of a mental 202.
Specs are unclear (bought like this) but it is running triples, solid cam, roller rockers, noisy timing gears, extractors, H.E.I ignition (Scorcher tweeked) and is very lumpy @800rpm.
The head is a stock (but worked) 202 from what I can make out?
http://www.gmh-toran.......c=39016&hl=
IF
BP6EFS-13 = VK 6 with H.E.I (1.5mm gap) and
BP6ES = LJ XU-1 (0.8mm gap) and
BP5FS = Stock LJ 202 head (0.9mm gap)
THEN
BP6FS with a gap of 1mm would suit this engine?
Info found on the NGK site http://www.ngkspark..../sparkplug.php#
Then click on part numbering system.
Any help appreciated.
#2 warrenm
warrenm
  • 2,122 posts
  • Car:1972 LJ Torana
Posted 31 July 2009 - 07:12 AM
IF
THEN
If it's running a HEI ignition why not use the BP6EFS?
#3 rodomo
  • 18,050 posts
Posted 31 July 2009 - 08:26 AM
This is the exact reason for asking the question.
Both BP6EFS and BP6ES are 3/4 reach and protrude approx 5mm into the combustion chamber.
There is no problem with the protrustion hitting anything.
My concern is that the exposed 5mm of thread in the combustion chamber could make them difficult to remove down the track?
#4 orangeLJ
Posted 31 July 2009 - 09:03 AM
I run BP5FS plugs in the 202 in the orange thing, never had a drama
#5 _monaroman68_
_monaroman68_
Posted 31 July 2009 - 10:19 AM
We use BP7EFS in the race car , 5and 6' too hot.
#6 _doucmyuc_
_doucmyuc_
Posted 31 July 2009 - 06:39 PM
Whats done to the icompression?
If running the HEI system, you can run a 1.3/1.4mm gap if you have some beefy compression.
Higher voltage or coil discharge will let you run a bigger gap.
Edited by doucmyuc, 31 July 2009 - 06:40 PM.
#7 rodomo
  • 18,050 posts
Posted 31 July 2009 - 06:45 PM
Pretty much standard Holden H.E.I including coil, but I think the curve has been adjusted by Scorcher.
With the plugs that will suit this head, it would be a fair bend in the earth strap to stretch it to 1.5? I suppose a gap is a gap though?
Ha Ha you edited? :D
Comp ratio is unknown.
Edited by rodomo, 31 July 2009 - 06:47 PM.
#8 TerrA LX
Posted 01 August 2009 - 08:58 AM
Problems I have found with this on other models are, thread at end of head (chamber side) does not like being screwed this far first time and tip of plug getting hot in chamber being exposed with no head thread to cool it.
#9 TerrA LX
Posted 01 August 2009 - 09:00 AM
Most of the advise I have had with similar cars is to stick with around 1mm gap.
#10 _torbirdie_
_torbirdie_
Posted 02 August 2009 - 02:37 PM
Have no experience at all in using the efs plug in a motor it isnt designed for, but would think that the protruding thread into the cylinder could get very hot due to being exposed into the chamber and then serve as a potential hot spot for preignition.
#11 _monaroman68_
_monaroman68_
Posted 02 August 2009 - 08:45 PM
^ Have never had a problem yet using efs plugs in a 38 cc open chamber head and zero deck hight blocks.
Foulded the odd plug from a bit of cold start in the shed and not warming the engine enough . But have never dettd a plug yet .
#12 rodomo
  • 18,050 posts
Posted 02 August 2009 - 09:08 PM
So you mean in a 202 9 port head? :huh:
I have read you previous posts and hear what you are saying but this is more of a weekender street application.
The owner is a bit of a knob too so I have to make it easy. :tease:
