how do i open the bonnet?!?!?
12 replies to this topic
#1 _torana_umunga74_
_torana_umunga74_
Posted 21 August 2009 - 02:50 PM
im in trouble i shut the bonnet to wash the car but i forgot i'd broken the release cable before now i cant open the bonnet!
#2 Statler
  • 6,329 posts
Posted 21 August 2009 - 02:57 PM
Lh LX?
Put a fine blade screwdriver between the nose cone & bonnet, then tap the handle with the palm of your hand.
Be carefull not to chip the paint on the bonnet.
#3 _torana_umunga74_
_torana_umunga74_
Posted 21 August 2009 - 03:07 PM
not sure wat u mean, how will that pop it? is it just like spring loaded?
#4 _darrenmark1_
_darrenmark1_
Posted 21 August 2009 - 03:21 PM
Stick your hand in from underneath nd release the catch!
#5 MRLXSS
  • 12,419 posts
Posted 21 August 2009 - 03:24 PM
Take the grill out if you need to, and get to it from there...
#6 _rorym_
Posted 21 August 2009 - 03:31 PM
^^^ YEP!!
#7 GML-31
Posted 21 August 2009 - 03:41 PM
^^^ agreed not sure how a screwdriver from up top will do anything at all
#8 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 21 August 2009 - 06:20 PM
The screwdirver trick between the bonnet and nose cone works a treat, just make sure you have a cloth or rag around a very thin screwdriver. All you have to do is aim it at the spring loaded latch. Easiest way to do it without pulling anything apart.
#9 _POTF_
_POTF_
Posted 23 August 2009 - 04:43 PM
Easiest & least risky way is to remove the Grille & then get your hand in there to losen the catch or pull on the cable if there is still part of it connected to the catch.
#10 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 23 August 2009 - 05:02 PM
A rag with butter knife. The blade is thinner than most screw drivers. Easy!
#11 _torana_umunga74_
_torana_umunga74_
Posted 23 August 2009 - 06:28 PM
well it wasnt easy as when i crashed the bonnet tip was bent down a little. couldnt get a knife in anywhere as the gap has bugger all clearence. took the grille out and i still couldnt get the thing to pop cos the bonnet was pushed a little to one side and someone had the press away from the edge while i tapped the release knob. bastard of a job but all fixed now:spoton:
#12 _RedOct74LH_
_RedOct74LH_
Posted 02 September 2009 - 07:37 PM
whoooops
#13 LX2DR
LX2DR
  • 1,763 posts
  • Name:Paul
Posted 02 September 2009 - 08:35 PM
Drill 2 holes, 1 either side of center about 20mm apart.
Look through 1 and stick a small screwdriver through the other.
When you see the screwdriver touching the catch, lever slightly sideways till it opens.
When finished you can put 2 of those nice blue LED"s in the holes to flash it up and then the holes are their for next time.
:tease:
Edited by LX2DR, 02 September 2009 - 08:39 PM.
