WHICH MANIFOLD TO USE
Posted 08 October 2009 - 05:57 PM
Posted 08 October 2009 - 07:04 PM
Have two manifolds: KC 253 308 and GM 88-2. Would one be better than the other?
Performance wise I doubt they would be any different, quality wise I cant speak from expirience but my friend has a KC one on
his Commodore it seems Ok. It was designed to be an aftermarket stock replacement.
If I'm not mistaken one advantage of the KC manifold is it has the dual carby bolt pattern so you can
put a quaddy or a holley on, versatile.
Posted 10 October 2009 - 07:41 AM
Posted 10 October 2009 - 03:04 PM
_beergut_
Posted 11 October 2009 - 12:29 PM
red or blue?the castings on the KC are SHIT! 1 came on a 253 I had and I spent ages fixing it up, the ports were all different shapes and the finish inside the plenum was rubbish. as Yel said, if you have pre poll heads go with the early standard manifold modified ala L34 or a Performer, performers also fit blue and black heads but are "illegal" on pollution engines
thought if you had the egr valve you where right on the reds?
Posted 11 October 2009 - 01:17 PM
_beergut_
Posted 14 October 2009 - 07:15 PM
or the car it is in?
for pollution?
might need a manifold swap
Posted 14 October 2009 - 07:59 PM
the performer does not have an egr valve, it has the crossover but no valve which makes it illegeal to use on any holden V8 post 1975 so that includes some red and all blue and black
Not quite true. ADR27A and even later V8 manuals didn't have an EGR valve, they had a plate blocking off where it would have gone. They still had transmission and temperature controlled spark advance but that can be fitted to a Performer.
_JoeVK_
Posted 30 October 2009 - 11:54 AM
The KC manifold is a copy of the VH/VK GroupIII manifold but it has ribs in the plenum floor whereas the HDT one is smooth. The KC has the advantage of fitting on all pre EFI heads. If the 88-2 you have is a GroupIII manifold use it, if it's just a stock blue/black use the KC. An Edelbrock Performer or a stock HT-HJ/LH manifold on early red heads would be better than the KC though.
Question why would a early HT-HJ manifold be better than a KC? I know that the KC manifold will out flow a Brock manifold, which often people hold in such high regard.
True the VK Manual Commodores had no EGR valve but they did have the exhaust cross over via the square port in the heads.
Posted 02 November 2009 - 02:51 PM
No manual V8 HX-VK should have an EGR valve, since the Performer has the exhaust crossover it should be legal on a manual car.
_JoeVK_
Posted 02 November 2009 - 08:31 PM
Early manifolds are good because GMH Engineers got it right, and stuffed it all up with ADR27A mods. The early manifolds are almost as good as an Edelbrock Performer. When I locate the Dyno proof i'll post it up. I'd be surprised if a stock KC manifold out-flowed an original VH/VK Brock, especially with that awful ribbing in the plenum. Happy to be proven wrong though.
I now a guy who flowed the KC with a Brock 955 manifold and said it outflowed it. The KC in std form flows 170-190cfm and the ribbed floor helps low speed running. It looks like the KC was modelled after the Brock but was made multifit ie suit 1 and 2 centre bolts.
FWIW, if you abrasive port a KC you can get 218-220 cfm and pickup around 20rwhp on a 250rwhp combination.
Also, has anyone even seen a performer with out the exhaust cross over?
Also, I liked to see the Dyno chart if you can post it up.
Posted 03 November 2009 - 05:21 AM
_LHSL308_
Posted 17 January 2012 - 09:21 PM
_LHSL308_
Posted 26 April 2012 - 06:34 PM
Bit late I know yel but did you ever find that dyno chart? I am in the mix for a new edelbrock performer manifold for my 355 and am tossing up whther it is the right manifold for my application.
Still waiting on some advice for the above comment. Looks like going to be doing an engine rebuild to fix the oil leaks and a few things internally soon. Need to know whether an edlebrock performer will be ok with a holley 750 on my 355, obviously L34 heads too. Any comments guys?
Posted 26 April 2012 - 08:07 PM
Posted 26 April 2012 - 08:17 PM
_LHSL308_
Posted 26 April 2012 - 09:06 PM
_LHSL308_
Posted 26 April 2012 - 10:41 PM
Posted 27 April 2012 - 06:55 AM
Unless you have one of the uncommon Holley bolt patterns, which I doubt, a Performer will accommodate it.
Posted 27 April 2012 - 07:39 AM
About 15 years ago I engine dynoed a 326ci 308 with B Cast heads and a small solid cam. I swapped between a Performer, a Torker and a Stripmaster. The Performer with a 2" spacer made the most torque, the Torker was the worst (never matched the Performer and was up to 25 ftlb down in the midrange). The Stripmaster did make more power but didn't pass the Performer until after 6000 rpm. And yes, I tried a heap of spacer combinations with each intake. Even today few people believe the Performer is better than the Torker. In fact Craig Bennett recently did a similar test with his own intake and the Performer still beat the Torker everywhere.
More recently a friend dynoed his 355/308 with a Performer and 2" spacer (ported heads and Crane 300A). He then fitted the new TP single plane hi-rise intake and re-dynoed it. Same as the Stripmaster, it picked up from 6000 rpm on and held on for an extra 400 rpm. On the street he maintains the Performer was better.
#21
_LHSL308_
Posted 27 April 2012 - 03:35 PM
