LH Brake Probs
#1 _JadeGreenLHSLR_
Posted 09 October 2009 - 07:20 PM
put all my brake back together and when bleeding them out, it bleeds well at each slave cylinder, but still get no pedal, is there a way to check the master cylinder? got uc girlock calipers on the front and stock LH drums on the back. any help or suggestions would be greatly appreciated.
cheers waz
Posted 09 October 2009 - 09:17 PM
Posted 09 October 2009 - 09:34 PM
#4 _JadeGreenLHSLR_
Posted 10 October 2009 - 08:22 AM
slr_v8 - tried with it on n off, dont think its the booster, but not sure.
it pumps fuel down the line, but it seems the air comes back up to the master cylinder, is this possible?
When we bleed it, at each slave cylinder it all seems right but still cant get no pedal.
Posted 10 October 2009 - 08:28 AM
In all cases the bleed nipple should be above the fluid inlet.
Hope this helps.
#6 _JadeGreenLHSLR_
Posted 10 October 2009 - 08:37 AM
#7 _JadeGreenLHSLR_
Posted 10 October 2009 - 11:25 AM
any ideas what causes them to lock up? ive heard of this problem on here b4 i think
Posted 10 October 2009 - 12:57 PM
If you are trying to brake lightly but it's all there at once, this would normally be the culprit.
Posted 10 October 2009 - 04:13 PM
You too the original calipers off and put on different calipers... on the wrong sides... using hoses that seem the wrong length... and I'll tell you now they have the wrong threads as UC are metric so you need to get some new hoses made regardless
Pics please of setup as it sits now
Don't use worn pads.. your wasting your time
I'm guessing aswell that the calipers haven't been rebuilt... so there could be issues with them too
#10 _JadeGreenLHSLR_
Posted 12 October 2009 - 06:18 PM
caliper.jpg 1.43MB 36 downloads
took the old ones off, put these UC ones on, brake line thread matches the caliper, got them round the wrong way to fit the brake line. took them off and bled them. then put them back on, they bled well. put them back on and went to drive it and the front calipers we stuck on. there is also a slight whooshing sound when u push the brake pedal.
Edited by JadeGreenLHSLR, 12 October 2009 - 06:19 PM.
Posted 12 October 2009 - 07:44 PM
Also sounds like Rodomo is on the money with the booster.
Posted 12 October 2009 - 08:36 PM
Hoses have wrong threads and wrong length (they screw in but they are wrong)
Discs need machining
Pads need replacing
Whoosh as in air noise from under dash ?
Booster pooped
Why did you take other calipers off ?
Posted 12 October 2009 - 08:54 PM
#14 _JadeGreenLHSLR_
Posted 13 October 2009 - 05:57 PM
UC claipers look better, are alloy (wont rust) and are bigger, and have wider range of pads. thats why we changed them.
put new pads in it tonight and pedal feels better, whoosh appears to be coming from manifold hose.
discs have been machined recently.
Do the hoses have to be made or are there any other models with longer and same threads?
Posted 13 October 2009 - 09:03 PM
They are 10x1 metric threads on the caliper end
3/8 unf on the body end
What did you grease the slides with ?
Never use any petroleum based products near brakes
#16 _mello92_
Posted 13 October 2009 - 09:16 PM
Booster pooped
I have been experiencing this ever since I've had my car, and the brakes seem to be working fine.
Pull the car up friggen quick when necessary.
Locks up the rears in the dry.
Should I be worried mate?
Sorry for the thread stealing Warren.
Edited by mello92, 13 October 2009 - 09:17 PM.
Posted 14 October 2009 - 07:06 AM
#18 _mello92_
Posted 14 October 2009 - 07:51 AM
Like I said, everything seems to be working fine, but yeah, I'll get it checked out.
Could a mechanic do this job, or should I take it to a brake shop?
Posted 14 October 2009 - 08:26 AM
#20 _JadeGreenLHSLR_
Posted 16 October 2009 - 08:22 AM
#21
Posted 16 October 2009 - 09:47 AM
#22 _JadeGreenLHSLR_
Posted 16 October 2009 - 11:01 AM
so new brake lines are the
only way forward?
#23 _stu.slr_
Posted 17 October 2009 - 12:51 AM
#24
Posted 17 October 2009 - 12:17 PM
You are reseting the brake light switch or at least leaving it unscrewed before going out on a test drive?
#25 _JadeGreenLHSLR_
Posted 19 October 2009 - 07:56 PM
so it couldnt return.
problem caused by worn pads got new pads in and will let you know soon.
thanks for the help so far.
