What causes bottom end noise?
19 replies to this topic
#1 Evan
Evan
  • 1,287 posts
Posted 26 October 2009 - 07:42 PM
Heya Guys.
Put a new 355 motor is the Torry and it has a bottom end noise when its running.
It is a really bad noise like the big ends are slapping. (like no oil pressure)
This motor has been herd running and had only a few 1000 km's on it. (the bores still had the hone marks on them)
My neighbor who is experienced with performance holdens came over and had a listen and seems to think that the crank is hitting on the sump or oil pickup.
The only thing is that it has been herd running sweet before with that sump and pickup.
Also there is no noise when i crank it over with the starter motor, its only when it starts.
I have packed the pump with grease and have got a Stewart Warner mechanical oil pressure gauge on it showing about around 40psi.
It is running a solid cam and the rocker clearances are good. Certainly coming from the bottom.
Just want some second opinions on what it could be before i rip the motor out and have a look.
Evan.
#2 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 26 October 2009 - 07:54 PM
So it has good oil pressure? Did the noise just start or has it been getting progressively worse. Worse hot or cold?
#3 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
This is probably optimistic,but pull out the dipstick while its running and see if the noise goes away.
#4 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 26 October 2009 - 08:21 PM
I had a mate who had a problem similar to yours. It was the crank hitting the sump. It was a pro-stroke 360 stroker. Very odd. A quick hit on each side of the sump with a block of wood soon fixed the problem...it was a bit backyardish but effective..
#5 rodomo
  • 18,055 posts
Posted 26 October 2009 - 10:21 PM
Too much oil in the sump and you can hear the rods slapping the oil.
Maybe the wrong dipstick?
Drain the oil and measure in 4.5 litres and see what happens.
Cheap and easy to try first.
Loose flywheel bolts can also sound like bottom end.
#6 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 26 October 2009 - 10:54 PM
If you can get under it when running, place your hand on the sides of the sump. You'll feel it if its slapping.
#7 _rorym_
Posted 26 October 2009 - 11:07 PM
Hmmm...I would pull it and look anyway...You will never feel confident in the motor again unless you do...Just my 2cs.
#8 _NZ Toranaman_
_NZ Toranaman_
Posted 27 October 2009 - 04:27 AM
I had a knocking noise in my old 6 and found it was the cam moving very slightly back and forth and hitting the end of the block. it sounded like a loose rod and sometimes was in harmonic which concerned me until I spoke to a HQ racer engine builder and he advised me nothing to worry about unless I wanted to pull it out.
Maybe similar and worth a check?
#9 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 27 October 2009 - 06:28 AM
I agree with A9X, if part of the rotating assembly is hitting the sump you may be able to feel it knocking. Also try progressively disconnecting plugs with the engine running, if the sound disappears or is reduced on one cylinder then its more likely a bearing or noisy piston.
#10 Evan
Evan
  • 1,287 posts
Posted 27 October 2009 - 08:57 AM
Thanks for the quick replies guys!
It looks like it has got good oil pressure and the noise is when its cold. I haven't had the motor warm as i tun it after about 6 - 8 seconds of running.
Ill give it another go with no dipstick
The feeling the sump idea sounds good. I will give that a go and if its hitting on the sump ill rip it out and give it a massage. But it has been running with the current pan.
I payed careful attention when i torqued up the fly wheel bolts.
Too much oil in the pan may be on the money as it has a high energy (Viper pan?) sump on it. I'm not sure how much oil they take, but i put 5lt in and it wasn't showing on the dip stick. So i put another 2lt in and it was full on the dip stick.
With high energy pans , do they have to have a custom dip stick?, as i just used my old one from my standard sump.
I have attached some photo's of the oil pickup and the pan to give you an idea of the size of it.
Ive over filled my old 253 before and didn't notice that it made any more noise than normal. It used to leak heaps and i was taking it on a 200k trip so i thort i had better put extra in. :) I only realized when the cops pulled me up cos it was smoking heaps. It later fouled the plugs.
Ill give the pulling the plugs a go too.
If i cant get rid of the noise i will certainly be ripping it out and will check the cam movement as NZ Toranaman suggested.
If it is big end noise they will have to be replaced anyhow so i could run it for a bit longer than i currently am.
The only thing i am worried about is that it has a new cam in it and my neighbor says if i keep starting and stopping it, i can snap a cam lobe off. I don't know how that works but that is another thread i will start as i would like to find out more about it.
Evan.
Attached File  19052009056.jpg   937.69K   33 downloads
Attached File  21052009062.jpg   713.6K   26 downloads
Attached File  21052009063.jpg   948.7K   14 downloads
#11 _UCV80_
_UCV80_
Posted 27 October 2009 - 09:33 AM
Sounds like Piston slap, caused by too much clearance between piston and cylinder wall. If it goes away when it warms up then its shouldn't cause any problems.
I had this knock which is exactly what you described, I checked all my bearings, all of my lifters (everything was perfect). and it still doesn't go away till the engine warms up. Turns out its just piston slap. my motor has done about 3,000kms. Some people think synthetic oils can quieten the slapping/knocking.
Just something to think about, its still possible that you could have a different issue than this.
Edited by UCV80, 27 October 2009 - 09:35 AM.
#12 _mumstaxi_
_mumstaxi_
Posted 27 October 2009 - 10:51 AM
Especially the case if your engine has had Forged Pistons fitted.
MT
#13 _beergut_
_beergut_
Posted 27 October 2009 - 11:04 AM
oh how gen3 owners love that noise
#14 Evan
Evan
  • 1,287 posts
Posted 29 October 2009 - 09:49 AM
Thanks for the idea Nathan.
Surly piston slap cant be good. Wouldnt you loose compression? , or do the rings take up the slack until things expand?
Im not sure if the motor has forged pistons.
I'm away from home atm but will bring this thread back up next week when i find out what the issue was.
Ev
Edited by Evan, 29 October 2009 - 09:50 AM.
#15 TerrA LX
Posted 29 October 2009 - 11:42 AM
I can't see someone assembling a fresh motor that loose ( i have seen some shockers tho) I would tend to think it is loose flywheel too, even tho they torqued up does not guarantee they are tight or haven't come loose due to stretched bolts, damaged flywheel or crank etc.
Does it get louder or go away with revs?
Is it the whole motor or just one cylinder?
You could short the plug in one cylinder that is suspected, shorting the plug takes the pressure off that cylinder, it will usually go quiet if it is a loose big end.
#16 Evan
Evan
  • 1,287 posts
Posted 29 October 2009 - 04:59 PM
Hey Terra
It does seem strange that a new motor would have been assembled loose, It has been herd running sweet before.
The fly wheel bolts are new ARP bolts, I didn't trust the old ones.
I haven't revved it, so ill have to get back to you on that one after i give it a few blips.
It sounds like the whole motor. like the whole thing doesn't have oil pressure
I ran the torque wrench over a few of the big ends to make sure they were ok , but not all of them. It also has 4 bolt mains.
Apparently performance mods did the machining and ive herd they are pretty good.
Ev
#17 _cruiza_
_cruiza_
Posted 29 October 2009 - 05:20 PM
After reading the tittle I was thinking of posting how a good curry can get my 'bottom end' making funny noise's but having now read the thread I have nothing to add ggod luck with your bootm end:blink2:
#18 Evan
Evan
  • 1,287 posts
Posted 09 November 2009 - 09:57 PM
Well!!!!
I happy ending to this saga! Hand on the sump revealed that the crank was hitting the sump at the front near the harmonic balancer.
Thing was that this sump has run successfully with this bottom end. So i backed off the sump bolts a bit and starred it and no more noise.
So with it running i tightened them up and its all sweet!
The sump bolts weren't super tight originally, so all i can put it down to is that it was previously assembled with a thicker gasket.
Chers for ya help guys! The forum is always a great help.
Ev.
#19 Heath
  • 18,401 posts
Posted 09 November 2009 - 10:07 PM
Yeah I was gonna say must be gasket thickness. Nice to hear it was no big deal!
#20 76lxhatch
  • 7,218 posts
Posted 10 November 2009 - 06:42 AM
Maybe someone sat it on the sump while out of the car?
