Turbo Steam pipe exhaust manifolds...
_Viper_
Posted 02 November 2009 - 09:23 PM
So should I use 40mm ID steam pipe for the manifold? or is there benefits making the runners on the manifold bigger or smaller?
I found a place that sells Steampipe bends... but they didnt sell straight sections? :S anyone know where I could get them?
Posted 03 November 2009 - 12:13 PM
You need to maintain air speed so make the tube as small as possible without being a restriction. Making it too large will only hurt.
You can buy the tube from any metal merchant, it is now black wall steam pipe with about a 3.2mm wall.
Hope this helps.
Posted 03 November 2009 - 07:52 PM
Yeah good point, but since the port will be a little bigger than the diameter of the pipe i would flare/grind out the pipe just at the start of the pipe where it butts on the flange/port.I can't remember the exact sizes available but 38mm ID will be fine.
Hope this helps.
Edited by Bart, 03 November 2009 - 07:53 PM.
_Viper_
Posted 03 November 2009 - 11:42 PM
He did say he did some back to back testing and he did gain 5hp from the larger runners but it did have more Lag... And for a street car ill take the less lag over 5hp....
Posted 04 November 2009 - 12:23 AM
No port matching required
No point going bigger than the ports really ...
_Viper_
Posted 04 November 2009 - 07:45 AM
http://en.wikipedia....ki/Nominal_bore
So 1.5" NB schedule 40 is actually 40.8mm ID and 1.25" schedule 40 is 35mm ID :S So its either i Go slightly smaller or slightly bigger
The guy I spoke to (who also has a 9 second gemini) said I would find the Turbo housing will be more of a restriction then the runners themself.
Edited by Viper, 04 November 2009 - 07:54 AM.
Posted 04 November 2009 - 09:23 AM
And let me know the price of the bends
And where to get them from
Have a similar thing to do for someone on a datto engine
_Viper_
Posted 04 November 2009 - 11:03 PM
Posted 05 November 2009 - 05:40 PM
Will most likely need cast iron strait pipe then.
Cast is a bit of a prick to weld with a Mig.
You can weld cast iron to mild steel, but with the different expansion rates and the extreeme heat changes in a turbo manifold im not sure if its a good idea.
I wouldent reccomend using a thick mild steel because of one other thing you may not have considered....Thicker metal conducts heat quicker.
You would be better off making it out of thin walled exhaust tube, if you can make it strong enough to support the turbo through all the heat changes as thick steel will conduct the heat out of the system (you want it to stay in there remember) a lot quicker.
Cast doesnt conduct heat as quick so if your using that you will be ok.
