TKO600 to 304
Posted 27 November 2009 - 11:09 PM
I have 3 questions.
Q1 will the speed�O cable/drive from the Ause 4 speed fit ? or is there a option to run the electronic pick-up with a new speed�O head ?
Q2 has any one got any informasion on a crossmember to fit ?
Q3 Looking for a good flywheel and clutch combo ? I like the yella terra ultra light flywheel but the clutch not to shor 10�, 10�, button, no buttons, just not shor any good advice ?????
any info would be great. thanks, adam.
_AGGRO_
Posted 28 November 2009 - 11:53 AM
2. Mal Wood automotive is where I got mine from. You can get the speedo cable from there too.
3. I had a Yella Terra lightened flywheel and just a heavy duty 2800lb pressure plate and standard type clutch. Was fine for street driving. Could dump the clutch any time if i chose to and wouldnt fry the clutch. If you are racing it ALOT then I would go for a full button or a cushion button.
Posted 28 November 2009 - 04:26 PM
_Harris_
Posted 28 November 2009 - 09:47 PM
hi all, i'm currently building up a lh with a 304 and a TKO600. I also have the bellhousing and a McLeod slave cylinder.
I have 3 questions.
Q1 will the speed'O cable/drive from the Ause 4 speed fit ? or is there a option to run the electronic pick-up with a new speed'O head ?
Q3 Looking for a good flywheel and clutch combo ? I like the yella terra ultra light flywheel but the clutch not to shor 10", 10�, button, no buttons, just not shor any good advice ?????
About the clutch if money isnt a problem then i would go for a mallwood twin plated clutch that looks choice but then again only if money doesnt worry you. I will be goin for the ACE 11'' Premium High Performance Clutch in my tko 600 im buying from mallwood
Posted 28 November 2009 - 11:21 PM
So 11� clutch will fit on a holden fly wheel ok ? I thought 10� was about it.
Eveyone buys from mallwood but each time I have ring him the price is, well I think we can do a lot better.
Thank for the info great.
_AGGRO_
Posted 29 November 2009 - 09:38 AM
And as for my TKO 600. I love that box. It is the best box I have ever used in any car. Very nice to use and play around with or just cruise with. Shifts are great and direct and nice and close. As I said in the other thread I am looking at a T56 Magnum 6 speed. Its the newest version of the T56 that can hold 700lb of torque, so its stronger than a TKO 600 (not as though that is weak - a box capable of withstanding 800+ Nm of torque isnt what you would call weak) but mine will be behind a big block chev and a 6th gear cant hurt. But I imagine being a brand new box it will cost the earth so I probably wont sell and keep to my box im extremely happy with. Remember that it isnt power that kills boxes its torque, so you could easily put in a TKO 500.
_Harris_
Posted 29 November 2009 - 10:41 AM
You have to remember the gearbox alone is worth about $3500 - $4000 alone. Then he has to put on mark up to make a profit etc. And all the bits that go with it, crossmembers are made in house so there is fabrication and labour work. And lots of custom parts. Parts which aren't cheap. Yes his prices are up there, but for the peace of mind and the excellent service, technical help and quality of parts I wouldnt go anywhere else.
Hi
The old man just bought a t56 magnum for his bigblock comaro he bought it from america but in the long run the price is a little bit different but he orderd better things like a twin plated clutch and stronger stuff so its pretty good if u ask me. by the time he gets it here the price difference will be about 2000 if that. most definitely will be less then that.
Also what parts have you got in your tko 600 Aggro
_Harris_
Posted 29 November 2009 - 10:48 AM
Well money is the problem, but my goale is to get the best from my money for my cars ability. My goale is 500HP so I think the TKO is money well spent in the long run. My goale was a 10 year billed or less with 9 year left so if it takes more money to get it right so be it (just add a year) But all the info from torana .com can get you a long way thanks.
So 11" clutch will fit on a holden fly wheel ok ? I thought 10� was about it.
Hi im still learning my self about all these gearboxes so i couldnt tell you with being 100% shore. If u have 9years i wouldnt mess around with old stuff just bite the bullet and go buy a Billet Steel flywheel $495 off mallwood and be happy in the long run if you havnt already done that.
What engine do you want in this.
Posted 29 November 2009 - 11:49 AM
So my ears prick up when some one has a good ideas on torana.com. Your positive feed back on your TKO is good to, as I was wondering about how they change gears.
Posted 29 November 2009 - 02:05 PM
I've got a VN engine
_AGGRO_
Posted 29 November 2009 - 05:36 PM
Posted 29 November 2009 - 06:21 PM
[/quote]
I got some weld prostar wheels for my torana from a blokes work at naval base. He had a big block comaro and ways getting a t56 magnum from the US. Maybe your dad? Nice bloke
Posted 30 November 2009 - 08:10 AM
Posted 30 November 2009 - 07:49 PM
If it under the dash could you tell me the bore and stroke, as I need a � bore and just over 1 inch stroke. Good luck with the box
Posted 01 December 2009 - 07:49 AM
Edited by myss427, 01 December 2009 - 07:51 AM.
