Adjusting tappets
Posted 10 December 2009 - 10:44 AM
Posted 10 December 2009 - 11:25 AM
Posted 10 December 2009 - 12:52 PM
Not sure about the lifters the engine has done about 29 thousand miles. Hasn't been started for a long while was a bit noisy after running the engine for about 150kms that's why I thought I would try and adjust them. Thanks DaveSounds right but I would think more like 1/2 to 3/4 of a turn rather than 1 or 2 whole turns. Are the lifters good?
Posted 10 December 2009 - 01:19 PM
Edited by 76lxhatch, 10 December 2009 - 01:19 PM.
Posted 10 December 2009 - 01:44 PM
There is also another method you can use with the engine off which is how I always used to do it. Working on one cylinder at a time, turn the engine over to the appropriate point to adjust a particular rocker. Back it right off and wait several minutes to ensure the lifter has bled down. Now use one finger to rotate the pushrod back and forth while you slowly start taking down the rocker. As soon as you feel it take, that's your zero-lash. Now just go the further 1/2 or 3/4 turn, whatever it's meant to be to set the pre-load.
Edited by LXCHEV, 10 December 2009 - 01:45 PM.
Posted 10 December 2009 - 03:07 PM
Posted 10 December 2009 - 05:23 PM
It WILL miss as you are opening the valve.
WAIT until the lifter bleeds down and the miss goes away.
Then another 1/4 of a turn and so on.................
Posted 11 December 2009 - 08:06 AM
_threeblindmice_
Posted 11 December 2009 - 09:35 AM
