what ratio gears for 9 inch
24 replies to this topic
#1 mr5000
mr5000
    chief break-everything
  • 3,456 posts
  • Car:77 lx 4door
Posted 16 December 2009 - 05:09 PM
trying to decide what gears for the 9 inch will be the v8 up front and aussie 4 speed behind it wheels will be 14 inch for now just wanna run some good quarter times before i build up the 355 but dont want it to top out to early was thinking maybe 3.55 ratio would work?
Edited by mr5000, 16 December 2009 - 05:23 PM.
#2 Heath
Posted 16 December 2009 - 05:22 PM
Got lotsa options, I know they have 3.55 in 9" but is that actually a common ratio? I think 3.5s are very easy to come by.
I would probably go 3.25 or 3.5, or something in between like a 3.33 if you can find it. May as well put one on that you can use with both motors, and that can just hack the highways without being stupidly unpleasant
#3 ls2lxhatch
  • 5,335 posts
Posted 16 December 2009 - 06:21 PM
You can check out the different rations using Gearcalc. Tyre size and profile can have a significant effect.
I think the M21 ratios are.
2.54
1.83
1.38
1.00
#4 _scottya!_
_scottya!_
Posted 17 December 2009 - 07:26 AM
do yourself a favour when you build your 355. Run it on the dyno ,get all your peak HP and peak torque figures then work out tyre roll out then gear ratio. Just takes the guess work out of everything.
A few to many having a guess on this site.
#5 TerrA LX
Posted 17 December 2009 - 07:32 AM
Im listening, so what is the secret?
#6 MRLXSS
  • 12,419 posts
Posted 17 December 2009 - 07:33 AM
You'll want a 3.5 or 3.7 ask around at most carshows what people have in their torries, and most will tell you either of those.
If you are running an Over-Drive (5/6 Speed or 4-5 speed auto), Go 3.9 or 4.11!
#7 Heath
Posted 17 December 2009 - 09:15 AM
I disagree, it all depends on your driving style and what you want from the car.
Unless it is set up for a certain race track or a drag strip, I don't believe there is one "right" ratio.
#8 rodomo
  • 18,058 posts
Posted 17 December 2009 - 09:23 AM
But....but.....but.....
Ryan IS talking about 1/4 times.
I think what scottya! is getting at is calculating the mph over the 1/4 through the tyre/wheel size and ratios keeping the engine in it best power range.
#9 Heath
Posted 17 December 2009 - 11:09 AM
Sorry I thought Ryan was gonna re-register it. If you are just gonna race it again and then swap the gears then go shorter and work it out that way
#10 ls2lxhatch
  • 5,335 posts
Posted 17 December 2009 - 11:12 AM
The M21 will have a very short life expectancy behind a 355 on the strip.
#11 mr5000
mr5000
  • 3,456 posts
  • Car:77 lx 4door
Posted 17 December 2009 - 11:41 AM
i am re registering it and m20 will no be going behind the 355 not that silly and i am re registering it and i wanna run as quick as i can with out it being un driveable on the roads
#12 _threeblindmice_
_threeblindmice_
Posted 19 December 2009 - 07:15 PM
On road with a 3.5 it slows you down ,more than just revs higher ,as a result when you see a cop ,and look down to see what speed your doing ,it will normally be the speed limit . I ran a 3.7 for years .
#13 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 19 December 2009 - 07:39 PM
Buy a Moroso speed calculator. http://performancepa...oroso_89650.jpg
If you have already raced the car it will set you straight.
#14 _scottya!_
_scottya!_
Posted 20 December 2009 - 09:15 AM
What gearbox ya gonna run with ?
When you build the 355, dont get caught up in the quest for heaps of HP. Try ang gain as much torque as you possibly can. Dont worry about trying to save on weight in the car. Because at the end of the day, every 50kg you remove from your car, that equates to 1 tenth of a second gain over the 1/4 mile(not really worth the trouble)
WOT179 power calculator will pretty much sort it out spot on .
#15 Heath
Posted 20 December 2009 - 09:54 AM
:blink2:
#16 TerrA LX
Posted 20 December 2009 - 06:30 PM
So a 1500kg car with 300hp will only gain 1sec over the quarter if i take 1000kg out of it?
#17 ls2lxhatch
  • 5,335 posts
Posted 20 December 2009 - 07:40 PM
According to the calculator on this site a 1500 kg (3300 lb) 300 hp will run a 12.86 and a 500 kg (1100 lb) 300 hp will run a 8.919 which makes 1000 kg worth 3.941 seconds or 600 hp.
Taking 50 kg off a 1500 kg car with 300 hp is worth around 1/10th of a second. However the effect of weight reduction on 1/4 mile times increases as the vehicle gets lighter.
Kg Pounds Time Diff
1500 3300 12.86 ----
1450 3190 12.72 0.14
1400 3080 12.56 0.16
1350 2970 12.41 0.15
1300 2860 12.26 0.15
1250 2750 12.10 0.16
1200 2640 11.94 0.16
1150 2530 11.77 0.17
1100 2420 11.59 0.18
1050 2310 11.42 0.17
1000 2200 11.24 0.18
#18 _scottya!_
_scottya!_
Posted 20 December 2009 - 10:49 PM
Starting to get away from topic a little bit.
But if you didn't take any weight out of your torana , and then added weight into your torana by way of roll cage you can go quicker again. Anyhow,this could go on and on. In general for a street car that gets a bit of 1/4 mile action , go a stroker more torque you can produce the better ya 60ft times the quicker ya ET's are going to be.
#19 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 21 December 2009 - 07:29 AM
2 seconds,mate.
50kg =1/10. Ive always known it as 100lbs=1/10th
It only a ballpark calculation.
as is "if you can pick up 1/10th to the 60,its worth 2/10s in the top end."
Its not gospel,but its pretty close .
#20 Heath
Posted 21 December 2009 - 08:28 AM
He said it was a GAIN of 1/10th of a sec, I just realised how I misinterpreted that
#21 _the gts_
_the gts_
Posted 04 January 2010 - 10:45 PM
wouldnt smart people be trying to do both increase HP/torque AND reduce weight?
e.g aftermarket alum heads do both
lighter weight would do more that just reduce times, it would improve reliability wouldnt it??
Edited by the gts, 04 January 2010 - 10:48 PM.
#22 ozyozyozy
ozyozyozy
  • 953 posts
Posted 05 January 2010 - 08:11 PM
i agree with MRLXSS, if street driving 3.5 or 3.7, depending on tyre size may want 3.25, depends on how much you want the engine to rev when sitting on 100kmh roads. m21 with 355 uuummm ok. maybe look at other gearbox options.
#23 _scottya!_
_scottya!_
Posted 05 January 2010 - 11:07 PM
Just out of interest, i changed from cast heads to aluminium heads on my clevo engine.
Weight difference between a bare 2V open chamber head (26kg) and a bare CHI 3V aluminium head 218cc(14kg).
Approx. 24kg weight reduction probably would help a fair bit over the front end i would imagine.
#24 _showoff_
_showoff_
Posted 05 January 2010 - 11:38 PM
I put 3.9's in my Vz clubsport 6lt with a 6 spd close ratio from the states, it was perfect, but with only 4 gears 3.5's id say would be the go.
Problem is if you go too tall it will make first real low, and traction at the track is always more slippery, so
ull find yourself spinning off the line into rev limiter instantly and breaking traction into second, so yeh i dont think anything higher than 3.5's with a 4spd.
because your trying too get it off the line right and use the power and ratios for the rest of the run too get you a good time.
My old maloo in street trim at the track and 400rwhp was all spinning. youve got too start spending more money getting suspension and tyres right too got your launch right before i would have even thought about diff ratios.
mmmm dribble dribble
#25 _TUFF75LH355_
_TUFF75LH355_
Posted 05 January 2010 - 11:45 PM
i run a toploader behind my 355 and 9 inch with 3.55 gears im happy with them
