guide coat black?
Posted 20 December 2009 - 06:51 PM
I am no panel beater so my question is this my plan is to undercoat a panel at a time as i have been doing with primer/putty and have been coating with some lacquer black but this is pritty deer considering its only going to get sanded off anyway can i use the cheap import aresol cans from supercheap for the guide coat ,that way i can cover the section and get a gloss to make sure i have completly straightened the panel.
I think its only enemal but not sure wether I can use it or not??
thanks in advance
forgot to mention the car is going acrylic lacquer
Posted 20 December 2009 - 07:40 PM
Just make sure you get it all off or it will surely fry.
Posted 20 December 2009 - 08:41 PM
FYI, guide coat need only be lightly dusted on, I usually buy a can of propper black acryllic for the job, one spray pass over the panel about a foot away at is more than enough, this way a can lasts for ages.
_Yella SLuR_
Posted 20 December 2009 - 09:30 PM
I use acrylic matt black pressure pack guide coat myself, as it isn't worth cleaning the gun for a 30 second guide coat.
_2runa_
Posted 20 December 2009 - 09:51 PM
This is a dry black powder and a powder puff like
applicator. You wipe on a light coating of powder
on sanded filler then sand more to see the high and
low spots. This can be a real life saver for folks that
difficulty feeling the highs and lows of bodywork or
when you're working a panel that is more complex
shape than a flat panel. If you want it right this is the tool.
Can be used for both wet and dry sanding. Contains no solvents.
So its no good for glue sniffers
_2runa_
Posted 20 December 2009 - 10:14 PM
this is what it looks like....works great
and no need to wait for it to dry
_Pete_
Posted 20 December 2009 - 11:05 PM
This is also my preferred method for guide coat, most spray on guide coats not only clog your sandpaper they also only sit on top and they dont get down into the sanding scratches
Dye based ones like these powdered forms or the "purple haze" style spray on dye from CAM will get into the sanding scratches giving you a better and more accurate surface on which to paint.
_yldlj_
Posted 21 December 2009 - 10:32 PM
_Yella SLuR_
Posted 21 December 2009 - 10:37 PM
You learn something everyday, I might give that 3M a go. Thanks fellas.
_yldlj_
Posted 22 December 2009 - 07:52 PM
Posted 23 December 2009 - 01:11 PM
I finish off with a coat of primer to be sure I have all the little scratches I guide coat and wet rub this before colour coat.
