Help Removing BCM Code Off VS 304 PCM
_showoff_
Posted 04 January 2010 - 10:19 AM
Can any body on here take the security code off.
So far i have found on the net
http://www.marks4wd.com/products/engine-parts/BCM%20Simulator.htm
MFKSIM01 VR-VS BCM SIMULATOR
BCM Simulator, labelled wiring loom, Installation Hardware and instructions to suit Commodore V6 & V8-VR and VS. $365.00
http://www.v6conversions.com.au/LH-UC%20V8.htm
Body Control Simulator VR - VS - $300.00
http://www.castleauto.com.au/hs_dbase/efilh.php
MEMCAL-VT/V8 Re-programmed Memcal to Delete Vehicle Anti-Theft System (VATS) & Calibrated to suit conversion. $450c/o
Iam in Perth WA but if it works out cheaper im happy too post it.
Cheers John.
Posted 04 January 2010 - 11:23 AM
Posted 18 January 2010 - 04:45 PM
If you could run a VN-VP computer and harness auto or manual wont make a difference. There alot cheaper than $400
Chears Neil
_showoff_
Posted 18 January 2010 - 07:42 PM
Can i buy a vn memcal and put it into my vs manual computer. The vs memcal that i have has a piggy back chip on it too run with the vortech i have, so i dont wont too remove the bcm signal off it just yet as it wont run right without the blower on it, and its going over the pits without the blower.
Posted 19 January 2010 - 06:09 AM
Posted 12 February 2010 - 10:27 AM
What is the 4 letter code on the current Memcal?
Posted 12 February 2010 - 11:24 AM
His username is greenfoam.
_beergut_
Posted 12 February 2010 - 04:47 PM
Posted 10 August 2016 - 08:09 PM
Is it easy to remove the VATS from a VR auto memcal?
Posted 11 August 2016 - 08:00 PM
check out pcmhacking.net if you want a crack at d.i.y or to find someone nearby to do it for you.
