Holden V8 loose Double row timing chain
_Brad1979UC_
Posted 16 January 2010 - 08:54 PM
putting my 330 stroker together now and upon dialing in the cam, when we have found desired lift@tdc, we put the double row timing chain that was on the engine when we got it back on. However as it sits, it has alot of slack, we have the dial guage hooked up and there is .006" play in the cam gear measured from the dial indicator guage to the lifter. Does this mean that the chain has stretched, and also is it advisable that I get a new timing chain?
many thanks,
brad.
Posted 16 January 2010 - 09:40 PM
Personally i would be replacing.
Posted 16 January 2010 - 10:14 PM
Posted 16 January 2010 - 10:18 PM
Is that play in the locating pin on the cam gear or are referring chain stretch?
Im not a expert either I would suspect there always gonna some slack in the chain.
I suppose as long you dial it in rotating the crank the clockwise direction,
Experts please shed some light.
_Brad1979UC_
Posted 16 January 2010 - 11:18 PM
we actually devised a possible reason to what happened, when the previous owner had to fit peter jackson timing gears and screwed the cam timing causing the valves to stack onto the pistons, it would have put load on the chain which has stretched it we think. Will check repco or like tomorrow for a new double row chain.
Posted 17 January 2010 - 08:58 AM
I have pulled some 253/308's apart that have had extremely sloppy timing chains and have still run. The real problem is what this does to the cam timing (ie the looser the chain the more retarded the cam timing). I have reused timing sets on budget builds as long as they are not too sloppy and advance the cam timing to compensate. If you need to advance the cam more than 3 or 4 degrees you need to buy a new chain.
Hope this helps.
Posted 17 January 2010 - 09:45 AM
_outer control_
Posted 17 January 2010 - 09:53 AM
The chains do stretch and usually in the first 20 min of running the engine.
Hope this helps.
Also use an Iwis chain for sure thats what i,ve always used [i think thats how its spelt,but good suppliers will know]
Edited by outer control, 17 January 2010 - 09:53 AM.
Posted 17 January 2010 - 09:54 AM
But if its a performance build and your going to rev it reguarly then you should be using new components.
_Brad1979UC_
Posted 17 January 2010 - 06:05 PM
Heath the teeth look fine, if you actually rattle the links in the chain you can feel its stretched im v sure its the chain
Posted 18 January 2010 - 12:01 PM
Posted 18 January 2010 - 01:16 PM
This rings a bell?????
Isn't there a method of measuring wear by the amount of curve in the chain?
Posted 18 January 2010 - 07:02 PM
Posted 18 January 2010 - 08:03 PM
Posted 18 January 2010 - 11:02 PM
Posted 18 January 2010 - 11:19 PM
^ Yes rodomo, it is the same method as for a fan belt, use one of those spring scales, just couldn't think of the kg's to answer, will have to dig it up sometime.
I agree, I would just replace it as well for the price.
But the wear method I was refering to was not as described with spring scales.
Hard to explain but it was laying the chain flat on it's back and then bending it in an arc.
The amount of deflection from parallel gives the wear limit as it measures pin wear and plate wear if that makes sense?
I think I saw this in an old workshop manual?
_oldjohnno_
Posted 19 January 2010 - 06:03 AM
Posted 17 July 2010 - 12:41 AM
The holden block is similar so I might try this method with the next motor I do soon and see what results I get.
The chain would need a bit of play otherwise the cam and crank would ride on the bearings as it was dragged around by the chain.
Another one that comes to mind is with the chain installed, push down on a roller with something while you try and lift the link.
_Gunmetal LH_
Posted 17 July 2010 - 04:11 AM
$800 car, not looking at replacing it yet...
