L76 (with AFM/DOD) + 6L80-E into LX?
_TankT_
Posted 24 January 2010 - 09:00 PM
As well as any info on the suitability of the conversion kit, I'm interested in hearing any other challenges that I can look forward to, not only in being able to get it all to fit, but also to get it registered in WA.
Cheers,
Chris
Posted 24 January 2010 - 09:41 PM
So yes, it will fit - as far as I know the block is generally the same as the LS2.
Grant..
_TankT_
Posted 25 January 2010 - 08:06 PM
Cheers,
Chris
Posted 25 January 2010 - 11:26 PM
To fit the 4L65e in an LX you will need to fabricate a new transmission tunnel. Once the transmission is as high as possible the oil pan is roughly level with the bottom of the chassis rails. The 6L80e is considerably larger, I doubt you will be able to get 100 mm clearance between the 6L80e and the ground without the car looking like a 4WD. In my opinion 4 gears are more than enough for a LX Torana.
Posted 25 January 2010 - 11:37 PM
_TankT_
Posted 26 January 2010 - 09:45 AM
The LS2 is just within the maximum engine size limits for a LX in WA. You should have not have any problems getting approval in principal from the WA Technical Section.
Thanks Andy, that's good info. The main reason I was considering going to the 6L80e was it was part of the package with the L76. But given the clearance issue, I agree with you. I've never wanted more than the 4L60e that's in it now, so no reason to change.
Cheers,
Chris
Posted 26 January 2010 - 01:10 PM
I notice some others (such as ls2lxhatch) use the CAE mounts, headers, sump etc.
I made the mistake of ordering the full Castle Auto Electric kit in Sept 06. I have not used any Castle Auto Electric components in my conversion.
My engine mounts, headers, starter motor and crossmember are custom made, the oil pan is a Moroso 20140. The engine position is the same as the Castlemain Rod Shop HQ-WB LS1 engine mounts, I just did not like the Castlemain Rod Shop engine mount design.
Edited by ls2lxhatch, 26 January 2010 - 01:19 PM.
_TankT_
Posted 26 January 2010 - 01:23 PM
I'm still planning to pick up the 6L80e with the engine as a package, so can compare the 2 when it gets here. I think sticking with the smaller 4L60e makes sense though. I'll probably sell off the existing 304 and the 6L80e once the job is done.
Chris
Posted 26 January 2010 - 01:43 PM
I wish I had built a 355 or a SBC.
_TankT_
Posted 26 January 2010 - 02:30 PM
It's not too late to convince me otherwise... I haven't forked out for the L76 combo yet
Chris
_showoff_
Posted 26 January 2010 - 02:39 PM
the 304 compared too the two ls1's sounded the best in raw form, the cam i had in the maloo was nasty and made up for that, but in stock
form the 304 pulled say 16lts 100k's the ls1 auto 12.5- 13 general driving, manual ls1 about 12, cam was awful 20 id say.
ls2 different kettle of fish much meater standard, auto or manual was between 11.5 too 13lt fuel and lower if u were nice too it.
and power makes the 304 cry, no matter how much money u chuck at the 304 even a 355, ls power is hard too beat, the money u spend initually
makes up with cheap power parts and economy
ls1/2 for the win
_TankT_
Posted 26 January 2010 - 07:46 PM
ive had a vs ss 304, a vu maloo r8 manual, vx r8 clubby auto, vz clubby ls2 auto then changed too manual.
ls1/2 for the win
My thinking as well. LS2 in an ~1800kg car giving 12-13 l/100km, should mean the AFM equal in a ~1200kg car should be able to give me 9-10 l/100km. So the package is a comfortable daily driver with a potential 11 sec time slip (after a tune, and traction permitting), then a cheap trip home
Chris
Posted 26 January 2010 - 08:45 PM
Once there is a good quality reasonably priced conversion kit available or you have the time and skills to make conversion components yourself then I would recommend the LS2.
Price the components required for the LS2, 355 and SBC and make an educated decision on which suits your needs and budget. Don't forget CAT's, fuel systems, engineering etc. Do not purchase a conversion kit from anyone unless you have spoken to people that have successfully fitted the kit and are happy with the result.
_TankT_
Posted 26 January 2010 - 08:52 PM
Cheers,
Chris
Posted 26 January 2010 - 11:37 PM
Engine
Gearbox
Diff
Fuel Tank
Brakes
Speedo
The approval in principal from the WA Technical Section did not specify a chassis kit as a requirement. I decided to fit one anyhow. The chassis kit will also need to be approved by the engineer.
You will find copies of the application and approval in principal documents here.
Posted 27 January 2010 - 04:42 PM
Grant..
_TankT_
Posted 31 January 2010 - 11:37 PM
Chris
Edited by TankT, 31 January 2010 - 11:38 PM.
Posted 01 February 2010 - 01:39 PM
Grant..
Posted 01 February 2010 - 02:19 PM
Getting the weight down further in a torana would save even more on economy... Light weight race seats, a BW diff over a heavy 9", a 6 Speed Manual, Light Weight Wheels, and maybe even some fibreglass bumpers/panels. You'd be lifting front wheels and using bugger all petrol!
_TankT_
Posted 01 February 2010 - 08:04 PM
What other sensors above the std ones on the L98? You may find that you are almost doing it all anyway.
Grant..
I'm told ABS, and I think traction control was mentioned amongst others. The indications were that it was likely that it could still be made to work, but unlikely to be perfect, likely to be expensive, and the worst case scenario was a poorly (or even non) functioning AFM. That sounded like more risk than I was interested in (really only to squeeze out the very best economy possible). The price of that extra economy is limited cam upgrade options, or expensive AFM removal if I want more power (and who doesn't
Chris
