Holden six gaskets, Where can we use a sealant?
19 replies to this topic
#1 Com_VC
Com_VC
  • 411 posts
Posted 02 February 2010 - 03:33 PM
Hi,
I'm putting together a 202 at the moment and it's got me thinking. Most of the newer motors these days use some sort of sealant instead of gaskets, that blue rtv stuff usually. Obviously you need to use gaskets some places like head gasket, manifolds, rocker cover and side plates.
I'm thinking maybe the sump, fuel pump, thermostate housing, waterpump and timing cover I should be able to get away with the sealant. I'm just trying to prevent leaks, not save $$$ as I have the cork gaskets sitting right here anyway.
On most 202's that I have bought they have been covered in oil on both sides of the motor. The current one I have I think it may be due to a busted oil pressure switch. Not 100% sure why the other side was so oily though? Probably a leak from the rocker cover gasket.
Also the timing cover was covered in oil as well, i'm guessing this may have been the crank seal.
Also i've noticed the bolts seem to work there way free easily, most of the sump bolts and rocker cover bolts very pretty loose. I'm thinking maybe a spring washer and some loctite would help here?
Anyone have any tips for a leak free Holden six?
#2 rodomo
  • 18,050 posts
Posted 02 February 2010 - 03:50 PM
I wouldn't use just a sealer on the sump, rocker cover or side plates (or any other pressed steel surface)
Basically anywhere where 2 machined surfaces meet would be O.K. with the exeption of the head, manifold and carbie...........................and here's the big one...........don't remove any gasket that prvoides a clearance or alignment, fuel pump, water pump, oil pump, timing cover.
Doesn't leave much on a Red 6............does it? :blink2:
#3 _oldjohnno_
_oldjohnno_
Posted 02 February 2010 - 06:56 PM
Everyone has their favourites. I usually use Wurth 250 on most stamped steel joints and Loctite 515 on close fitting machined surfaces. I always use a gasket with the sump and timing cover just so I know it will fit correctly against the cover and the rear main cap. If you use sealant on soft cork gaskets (and I do) just nip a few bolts down very very lightly until the sealant is fully set, and even then be careful not to overtighten. 202s are usually oil tight (except for the dreaded rear main perhaps) provided they can breathe.
The bolts don't come loose, the gaskets shrink and relax the tension over time...
Edited by oldjohnno, 02 February 2010 - 06:58 PM.
#4 Com_VC
Com_VC
  • 411 posts
Posted 02 February 2010 - 07:22 PM
Thanks for that so something like Hylomar should do the trick as well.
Is it worth using loctite on the bolts?
Also do any of the head bolts on a 202 go through coolant, I cant remember.
#5 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 02 February 2010 - 08:48 PM
as old johnno just said, the bolts dont come loose, gasket shrinks so loctite is pointless.
yes they do, i use some sort of black gasket cement on screw in studs and head bolts, (has dribbled all over the name so i cant tell you what its called lol)
#6 _oldjohnno_
_oldjohnno_
Posted 02 February 2010 - 08:58 PM
Dribbly dark goo sounds like Permatex No. 3.
I usually use Loctite pipe sealant (567?) cos it lets you retorque without leaks but permatex etc. is fine too.
#7 rodomo
  • 18,050 posts
Posted 02 February 2010 - 11:08 PM
I use contact adhesive to glue the sump gasket to the rails, the side plate gaskets to the side plates and the rocker cover gasket to the rocker cover.
#8 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 03 February 2010 - 09:54 AM
Speco make rubber rocker cover gaskets...I dont have much trouble with sideplates...but the day they make a 1 piece rubber/neoprene sump gasket I'll buy a dozen.
#9 Com_VC
Com_VC
  • 411 posts
Posted 03 February 2010 - 03:11 PM
yeah I loved the idea of those rubber gaskets for the rocker covers, but everyone told me they leak?
#10 _Drag lc_
_Drag lc_
Posted 03 February 2010 - 04:38 PM
well i know a good way of fixing all oil leaks on red motas fit a vac pump hehehehe...............
i dont use alot of sealant what i do use is 515 it is very good.
Cheers Hayden
#11 TerrA LX
Posted 03 February 2010 - 11:06 PM
If you do (and I try not to) use silicon type sealants make sure you either use it as per OEM (where they run a bead and let it dry before installation) or just a thin smear on gaskets.
Any overhang inside the motor will break away and most likely end up stuck to the end of the oil pick up or stuck somewhere else in the motor where you least want it.
They don't start leaking straight away (unless you done something wrong) so if you get a couple of thousand Km's out of it it is cheap enough to re do the rocker and side plate gaskets and nip the sump up.
Can you get the rubber one piece sump gasket like you can for the V8?
#12 Com_VC
Com_VC
  • 411 posts
Posted 05 February 2010 - 03:19 PM
Been thinking about this today, but why do you say that the water pump needs a clearance or alignment?
Also how about the thermostat housing that bolts to the head and the thermostat cover, these are machined surfaces are they not? So should be right to use a sealant there instead of gasket?
#13 rodomo
  • 18,050 posts
Posted 05 February 2010 - 04:46 PM
Yes, you're probably right about the waterpump not being so critical.
It would however put the pulleys slighly out of alignment and I would be checking the tolerance between the impeller and No.1 bore.
Having said that, and regarding the thermostat housings as well, these were good machined surfaces 30+ years ago, perhaps not so much now, and you are trying to seal hot water under pressure.
#14 Com_VC
Com_VC
  • 411 posts
Posted 05 February 2010 - 05:00 PM
Hehe, don't think the .25mm (estimate) would make much difference, there is probably enough movement in the alternator bracket to cause some alignment issue. I will check if there is a tolerance issue with the bore though.
I have a new kilkenny casting thermostat housing, it's the later VK type though. I think I prefer the earlier ones.
Any idea if the earlier style housings are available in aluminium? I have a cast one here, it's quite heavy. Maybe there is aftermarket available? Where they available on the earlier red motors?
EIther way I have all the gaskets here and probably a few spares.
#15 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 06 February 2010 - 10:25 AM
567 is the white stuff, we use it at work all the time, good stuff. the 577 is good too, dont think it would be needed on headbolts though
#16 TerrA LX
Posted 06 February 2010 - 11:05 PM
:threadjacked: Just thinking out loud here but if you used sealer everywhere and ran a composite head gasket it would make a hell of a path for the earth to travel thru for the cranking starter if you only had the one factory (underrated IMO) head bolt earth lead.
#17 _glennhailstone_
_glennhailstone_
Posted 09 October 2014 - 03:28 PM
I made up rubber gaskets for my sump, side plates and rocker cover. I just used the cork ones as templates. Make sure you get oil resistant rubber.
However, I had to replace the side plate and rocker cover ones with cork because they were slipping, but admittedly I did make the rocker one slightly too big. The first time I had it on it sealed mean!
There is still oil leaking out of my side plates though, anyone?… Should I use gasket sealant.
#18 Rockoz
Rockoz
  • 4,054 posts
  • Name:Rob
Posted 09 October 2014 - 04:19 PM
Terra. Reckon there would be enough continuity through the bolts for earthing.
Pretty sure the bolts will take the majority of the current in any case.
#19 EunUCh
EunUCh
  • 2,773 posts
  • Car:japos
Check that the side plates are flat/square on another block,tap to flatten out high/low spots where needed.
Once done,stick cork gasket on covers with contact cement and maybe even a little #3 left to tack off on gasket face
that touches the block,sounds like they may be warped a bit?..or not tightened up enough?
#20 _glennhailstone_
_glennhailstone_
Posted 09 October 2014 - 05:25 PM
Ok thanks, how much do you tighten them. Do you tighten them right down so that the plate touches the block, (where the screw goes in). It just seems like it flattens out too much when you tighten too much.
Edited by glennhailstone, 09 October 2014 - 05:33 PM.
