Gooey Shit
_Yella SLuR_
Posted 21 February 2010 - 08:19 AM
Anyways, just wondering if anybody know what the permanently gooey stuff is inside the doors that you attach the waterproof plastic panels over the access panels on the back of the door to stop damaging the door cards from water ingress?
Hope that makes sense to somebody. Seems to be some sort of glue that never goes hard, so you can pull the protective panels off, work on your doors then put them back on.
Any ideas most welcome.
_CraigA_
Posted 21 February 2010 - 08:25 AM
I've used spray glue in the past and that works OK.
Posted 21 February 2010 - 09:57 AM
Posted 21 February 2010 - 10:58 AM
Posted 21 February 2010 - 11:09 AM
The rear doors were hardly used and the heat got to it and it ran down onto the rods that run the length of the door.
_beergut_
Posted 21 February 2010 - 11:43 AM
I would have said mastic but yeah same shit different smell.
mastic?
that the same as silastic?
think the trade name for that black stuff is stikaflex never dries and never comes off your hands either
Posted 21 February 2010 - 12:09 PM
Just a non hardening sealant or caulking compound.
_Yella SLuR_
Posted 21 February 2010 - 01:25 PM
Bit like me asking what cereal you like, and you say Kellogg's or Uncle Toby's.
Edited by Yella SLuR, 21 February 2010 - 01:33 PM.
Posted 21 February 2010 - 01:36 PM
http://www.septone.c...=283&page_num=5
Mastic is that non hardening stuff thats kinda grey in colour and stiff like plasticine.You find it usually around tail lights.
Sikaflex is a brand name.They make a heap of different sealers to suit various applications ,just like Selleys do.
You do not want selleys windscreen sealant.That stuff is basicly the same as the silicone you use to seal your gutter on your house.
You want windscreen sealant.
Posted 21 February 2010 - 01:55 PM
mastic?
NO, NO, NO, Mastic, silastic and polyurethane (silkaflex is a brand name) are three very different things.
Mastic is like plasticine and stays soft.
Also under front guards and sealing fan motors and ducts etc.
Edited by TerrA LX, 21 February 2010 - 01:59 PM.
Posted 21 February 2010 - 02:18 PM
I thought selleys do mostly silicon and silkaflex do mostly polyurethane.
Posted 21 February 2010 - 02:58 PM
_yldlj_
Posted 24 February 2010 - 07:32 PM
Edited by yldlj, 24 February 2010 - 07:33 PM.
_Yella SLuR_
Posted 24 February 2010 - 10:00 PM
They use a Non-Hardening sealing compound, every automotive manufacturer uses a different type and coloured version, some are more of a pain in the ass than others.
I'm kinda of the opinion unless your trying to recreate something for a pedantic restoration something like Windscreen sealer will do the job adequately and is cheap and readily available.
Thanks Pete.
_SableMet7/73_
Posted 25 February 2010 - 12:51 PM
back together in the late 80s as it was recomended to me to use
even said non-hardening on the tube but today I wouldnt say it
is anything like soft or non-hardening.
Posted 25 February 2010 - 05:43 PM
_freddy_
Posted 15 March 2010 - 07:34 PM
_Yella SLuR_
Posted 15 March 2010 - 08:30 PM
You need stuff called body sealer for your guards.
<Walks away hitting head on a brick wall>
Edited by Yella SLuR, 15 March 2010 - 08:31 PM.
_freddy_
Posted 16 March 2010 - 03:50 PM
Grrrr..... Mastik is a brand name, like Kellogs!!!
_Yella SLuR_
Posted 06 April 2010 - 06:08 AM
Did my door PVC access panels with Selleys Buttnyl Mastic.
Label says froms a tough skin, is paintable, but stays soft under. I'll let you know how it goes when I have to pull them off in a few weeks to fit new door belts (hopefully).
