Questions about rebuilding a Banjo diff
33 replies to this topic
#1 Heath
  • 18,394 posts
Posted 26 February 2010 - 09:27 AM
I've swapped axles here and there, swapped centres etc but I have never rebuilt a diff before, so I've got heaps of questions to ask.
I just got my hands on a course spline LH 3.36 rear axle assembly, drum to drum to yoke.
What bearings should I replace? Should I just replace stuff without knowing what the gear in there is like? Or should I inspect them all individually or do some other sort of test? And how difficult is it to replace them? Do the axle bearings need to be pressed on and off? Will these bearings cost a fortune, is it worth replacing the pinion bearings etc.
If I want to change a centre from course spline to fine spline, are the spider gears and the splined area that drives the axles the same component? Like is that one cast piece or two seperate bits? I've never pulled a centre down lol
Any special tools I need? Other advice?
#2 76lxhatch
  • 7,209 posts
Posted 26 February 2010 - 11:05 AM
Unless you're expecting it to last a long time (yeah right), don't bother replacing bearings unless they're obviously shot. Check for pitting/wear in the hard facing. Yes you need a press and possibly other equipment to replace them, and it can be costly.
The best way to change from coarse to fine spline is to remove the centre and swap the crownwheel from one to the other. Don't upset the spider gears if they're in good usable condition. The good thing about a Banjo is that the back lash is adjusted with a screw type piece behind each bearing shell which means no mucking around with shims - do you have a workshop manual with the procedure for setting the correct back lash and bearing preload? From memory I believe its 3 slots of preload and the backlash should be around 7 thou. Preferably match it to what the back lash was before disassembly though; if you've already pulled it to bits then perhaps check the tooth markings.
You're not planning on removing any pinions are you? Not worth the hassle if the one you want is in a good carrier.
#3 Heath
  • 18,394 posts
Posted 26 February 2010 - 11:43 AM
I do have access to a press but if I need to machine up specific tooling to get the bearings out with the press, then that is a big hassle.
All I've done is pulled the centre out of the housing and had a little look at it.
Why does the crownwheel have to be swapped? This is the only 3.36 ratio centre I have, but I thought I could just swap the other stuff over so that it was fine spline
Yes I have a GM LH workshop manual, and I was planning on trying to get this thing to last
Edited by Heath, 26 February 2010 - 11:46 AM.
#4 Heath
  • 18,394 posts
Posted 26 February 2010 - 12:11 PM
Ohhhhh I think I get what you mean. When you say remove the crownwheel you mean remove the whole crowheel * differential assy. and swap it over from one carrier to the other or something.
I would have named all these part differently!
#5 76lxhatch
  • 7,209 posts
Posted 26 February 2010 - 12:19 PM
I have that hassle all the time with naming bits - yes keep the crownwheel but swap to the fine spline centre (which means removing the assembly, swapping the crownwheel and re-setting backlash and bearing preload upon reinstallation)
#6 _torana_umunga74_
_torana_umunga74_
Posted 26 February 2010 - 12:20 PM
i got a spare 336 coarse if u want bits man. the drive gear is stripped but i think the rest is ok.
#7 Heath
  • 18,394 posts
Posted 26 February 2010 - 02:14 PM
Maybe when i come up to Toranafest? Postage would kinda kill the fun in that but it may be good to grab it as a spare. Cheers
#8 _darrenmark1_
_darrenmark1_
Posted 26 February 2010 - 06:36 PM
You drive me nuts Heath.
#9 Heath
  • 18,394 posts
Posted 26 February 2010 - 07:41 PM
It did seem very perculiar to see you as the last poster in a thread where I was asking for advice, good thing I didn't expect it to be anything remotely helpful or I may have been disappointed!
lol anyway excuse my ignorance - what have I done wrong now to make you complain again?
#10 Heath
  • 18,394 posts
Posted 28 February 2010 - 04:37 PM
Righto good thing not everyone has the same willingness to assist my learning as Darren or I may have been in strife!
I took the centre over to rodomo today and pulled it apart in-front of him, he gave me some good tips about things to look out, some analysis and things to do to make it easier to set it up when I put it back together. And now I know I'm up for a set of bearings & a seal for the pinion anyway :P Thanks again
#11 TerrA LX
Posted 28 February 2010 - 09:03 PM
One thing you have not learned about banjo diffs yet but some things are only learned from experience.
#12 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 28 February 2010 - 09:57 PM
The first thing i learned about banjos...is dont play with them.
The second thing is they are a good diff...if you don't shock them.
If you ask me centres for these things are too cheap...you can pick up good centres for as little as $30....but not when you have busted one and need one....thats when they all seem to be $70-80...which is still cheap when you are stranded.
#13 _mello92_
_mello92_
Posted 28 February 2010 - 10:35 PM
I second that.
I have been told by a local Torana enthusiast who has quite a record with Banjos, that they are a fairly decent diff, if you dont drop your clutch much or jerk them in any way.
But feeding the power in is perfectly acceptable. :P haha
#14 rodomo
  • 18,042 posts
Posted 28 February 2010 - 11:45 PM
Bathursts were won with banjos.
#15 MRLXSS
  • 12,415 posts
Posted 01 March 2010 - 08:05 AM
Weren't Bathurst's and championships lost because of banjos?
Edited by MRLXSS, 01 March 2010 - 08:07 AM.
#16 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 01 March 2010 - 08:34 AM
if ya gonna get a new set of beaings and seals go to bearing wholesales they did me a kit for mine for like 80 bucks i think came with a real nice rubber sealthat hasnt leaked at all since i got it
#17 _chrome yella_
_chrome yella_
Posted 01 March 2010 - 11:36 AM
as Meatloaf said....TWO out of THREE aint Bad....
#18 Heath
  • 18,394 posts
Posted 01 March 2010 - 04:24 PM
Thanks Ryan that's what I wanted to hear mate! Any other notes? Have part numbers or anything I should know when ordering? Cheers
Edited by Heath, 01 March 2010 - 04:25 PM.
#19 TerrA LX
Posted 01 March 2010 - 09:08 PM
I second that.
Cough bs cough.
They had detroit lockers, I would run one again if i could get one, at a price which would make a BW look expensive.
#20 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 02 March 2010 - 07:39 AM
Sounds like you are a diff thrasher :burnout: hehe
I've never broken a centre...I've worn a few out (one from oil loss, another from a bad setup) and I've snapped 1 axle. If you drive "normal" they last forever.
I know they aren't super heavy duty...but its not like they are made of glass
How many have you broken?
Edited by FastEHHolden, 02 March 2010 - 07:46 AM.
#21 TerrA LX
Posted 02 March 2010 - 09:50 PM
7, broken everything at one time or another accept the crown and pinion.
Each time was with a stock 253 and stock trimatic.
#22 76lxhatch
  • 7,209 posts
Posted 03 March 2010 - 07:04 AM
My best effort took several teeth off both the crownwheel and pinion, twisted an axle, smashed both bearing caps, gouged out the back of the housing and split the bottom of it open... I may have been doing something silly at the time...
#23 _Gunmetal LH_
_Gunmetal LH_
Posted 03 March 2010 - 07:13 PM
Had a banjo destroy itself while slowing down from 50kmh. Locked up with a huge bang! Split the carrier, snapped the pin, gouged the crown wheel, some big dents in the housing and the small gears literally exploded. 14 chunks of gears, a handful of filings, and what looked like glitter through the oil. I was only 3 blocks from home. (Lucky me)
Apart from that, no real problems except for backlash noise. Coarse axles moved 1/2 a groove around but haven't snapped one.
Burnouts kill open banjo's. Not usually during but when letting off/ending. Lost count of how many people I've seen do amazingly huge 'one wheeler squealer's only to end them with a crunch, and no more drive. One wheel still and one wheel spinning at double speed- lift off and the spinning wheel stops and the pinion gears explode from shock loading. Same sort of shock as dropping the clutch. No gears no drive. A couple of turns to fling around the oil full of bits and, completely junk one diff...
I have never 'overpowered' a banjo. Mind you, that's with autos. Plenty of loooong drifts and left some impressive (single) lines but avoid burnouts.
I haven't ever rebuilt a banjo, just replaced the whole thing from being too noisy to trust. Be 'nice' and they'll last ages. Abuse, and walk home.
I have learned that the pinion gears should be shimmed up to provide ALMOST no lash. I would like to know if this is correct or not? <-Anyone know for sure?
#24 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 03 March 2010 - 07:47 PM
I'll have to drag out the old trade books...I'm sure I was taught to set crownwheel preload first and then calculate pinion height.
Edited by FastEHHolden, 03 March 2010 - 07:50 PM.
#25 76lxhatch
  • 7,209 posts
Posted 04 March 2010 - 06:17 AM
Sounds right to me, you need some lash or the gears are effectively locked together but this doesn't need to be much, and finer tolerances mean less impact from shock loadings you were talking about. This applies only to saving the spider gears of course (edit: which is what I assumed you meant when you said pinion gears, not the actual pinion)
Edited by 76lxhatch, 04 March 2010 - 06:18 AM.
